Originally posted by tecknomancer
This is how the physicists of yesterday did to get those billions for building those useless particle accelerators... hehe i'm joking,.
You need a switch because otherwise the dipole will keep killed all the time, so would never be able to recharge.
Tutanka the sun is only for theoretical atmospheric scale device... I represented because is the source of the sky's electric fields. just an idea..
The sun is what creates the charge separation in the atmosphere case.
The main idea i want you to understand is that you just need to use a charged rod and a switch to create energy. Create not generate
Just a practical demonstration device.
A practical use device would involve more and more things... like coils, caps, electronic switches...
Important is to understand that when charges are neutral they can be separated to a certain degree when you apply an electric field. Electric field interacts directly with charged particles without getting consumed as it is only a force. Magnetic fields instead holds charges in its fields. Thats why when you move a magnet over a wire you create a current.
I'm just using the electric field, so energy can be created and it can be done using no work. Creating energy from nothing but forces. No work. Just the way i like
A transistor can switch a power many times bigger than the needed power to open or close the switch.
Hope you think is worth thinking.
