Exciters = OU from Mass = semiconductors
  • #91
    thank you lamare, I'm going to study this further.
    sorry to be off-topic
    Just wanted to understand more about the subject.
    I still think that in real medium electromagnetic waves travel slower than speed of light, and also under influence of magnetic permeable materials but i need this to be confirmed, by calculations and experimental results.
    Getting back to the topic,
    semiconductors are great because they can allow the flow of an electric field in one direction while blocking in the other, and also its abilities to open or close a switch at million times for second also makes possible to switch a small gain per cycle with a smaller energy than the gain is, this is OU.
    Electric field forces don't get consumed in an electronic circuit as long as amps is blocked or restricted. think about this.
    What amperage a diode in reverse configuration conduct? uamps
    If you apply a field that move more electrons than this uamps you are in the ou range.
    I repeat tesla capacitors in the drawings were some times representations of semiconductors.
    A capacitor made of aluminum and water is a semiconductor. Water alone is a semiconductor too. Aluminum oxide allow current to go only in one direction.
    • #92
      Hi Goldfinder and all, I just fixed some links in this thread not exactly same pics but good enough.
      So while i was here I thought i would add a post to see if anymore idea's had arisen in this area.
      I've been thinking on it some and I think when my free time come's around in a couple of months, I will try some laminations of different materials as a plate "p" collector and some different circuit arrangements as well as some different geometrical plate coil configurations. After some more research into Aether theory, Pyramidal collector-capacitor arrangement looks worth a try, for a direct tap with natural oscillations.
      • #93
        Goldfinder? Still out there?
        Goldfinder? What happened? Giving up already?
        We still need good ideas, we still need free energy and we still don’t have it!!
        I keep on wondering, what if I don’t read these threads here anymore and come back after 5 years, will we still be in the same situation? It seems we already have the technologies to generate all the energy we need for a really long time but we still can’t or are not allowed to use them and if you talk about it at work among friends or somewhere else, you still get the weird looks … Most people do not read over here (or other similar sites on the Internet) and only know and trust what is written in the newspapers! Nobody is taking you serious, you can't prove a thing and if you insist you will be the towns nutcase!
        Wiki leaks about political issues all over the place (nothing we really didn’t expect or knew) As if the Russians, the Israelis or the Chinese are any better! But what you don’t see is a Wiki leaks about energy systems, UFO’s, crop circles etcetera... They apparently have way better control over that and not much leaks out.
        Anyway, what I wanted to say, don’t give up so easily!
        Sjalom,
        B
        • #94
          Degenerate Semiconductor Material
          Goldfinder, you may be interested in my thread about Degenerate Semiconductor Material, as I was in yours.
          http://www.energeticforum.com/renewa...-material.html
          Very interesting posts all
          lamare, big thanks for the link to the article "AETHER CONTROL via an understanding of ORTHOGONAL FIELDS" 8/2/98 by Rick Andersen
          sebosfato, about the semiconductor capacitor, it's very interesting. It reminds me of the testatika, where nobody was allowed to look inside the capacitors. Makes one wonder what was inside?
          ‎"It's all in the MIND"
          • #95
            Semiconductor isn't the magic. Znidarsic's quantum transition speed is. YouTube - Driving LED, No Battery and No Transistor
            i won't comment here further, just thought i'd point out the above.
            • #96
              That link you gave takes you to a youtube page but when you click on the video it is an invalid URL. It's an odd page and the link seems odd too that you gave.
              Okay I figured it out. You had an 'm' in front of youtube.com that is not supposed to be there - this will work : click this
              • #97
                " All mass is formed by a contraction of the electric poles of the generative cones of energy to the point of north of it's gravicative center and by an expansion of the contours of the radiative cones untill they disapear in the plane of the equator."
                Looks and sounds like Walter Russell's wording What are/were you trying to do, make out what the text said from the image? The Secret Of Light, page 245 ish might explain it a bit. Though that particular diagram isn't in that book.
                • #98
                  Yes at the time I was unaware of Walters Books, all I had was a few diagrams that were very poor quality and hardly readable. I now have the books and I can see I got the wording slightly wrong. That is a good diagram it is in "The Universal One".
                  This is an old thread. I have gained much knowledge since.
                  • #99
                    Excellent stuff
                    • Semiconductors and radioactive materials
                      Originally posted by Goldfinder View Post
                      To all you would be OUO researchers:
                      Mass is aether trapped in a vortex. See - Besant and Leadbetter, Lucas and Bergman, Global Scaling, Stowe, and others. The only truly stable particles are the electron and the proton. The next most stable particle is the neutron which decays in seconds to an electron and proton. The neutron is obviously a proton and electron pressured together within the nucleus. The rest of the particle soup are just transitory decays of the initial stable particles.
                      Electric fields are stresses in the field, Gravity is GRAD E, and magnetic fields are vortexes in the aether. EM energy are synchronous moving electric and magnetic fields.
                      The proton and electron are resonant structures and tuned into the standing scalar waves as well as an infinitude of others. See Global Scaling. These structures of mass are already sustained and supported by the gravitational/scalar standing waves that run the universe. They are tapping the aether directly.
                      Stifflers exciter is creating a disturbance in the aether and then taps this disturbance. So how does the tap work?
                      After playing with the exciter and plowing through the tons of videos and associated work there is a great scarcity of anything other more variation of these circuits and no real discussion on HOW they are tapping the ZPE/aether/whatever.
                      It looks to me in my limited background that the AV plug is really where the secret lies. The other thing is the transistor itself which seems to be limited to certain special ones. So what is common to AV plugs and transistors besides wire and containers - answer - semiconductor material...
                      It reminds me when I was at Lockheed back in the 1960s. One of techs I who worked in the semi lab said they had been testing a transistor that put out energy with no inputs and it had gotten classified TS very quickly. He wouldn't discuss it further.
                      When I met Dr. T. Henry Moray back on the early 1960s he showed me the progression of his radiant energy discoveries and how he went from giant Tesla towers outside his lab to a box that would fit into the trunk of a car to tap the aetheric forces that put out 100 KW. However, he stated that his greatest discovery was the use of semi conductor material. He was actually the first inventor to build a transistor and the device was stolen by Bell Labs.
                      Space has this seething energy blazing through it. Various estimates go as high as 100 KW per cubic centimeter. The Dr. Stiffler exciters and other similar circuits tickle this standing wave field creating a disturbance in the aether and then trap the disturbance. Why not tap the seething field of energy directly? If the Lockheed free energy transistor and Dr. Moray's cryptic statement have some weight it looks to me the way to go. Not being a semiconductor expert (yes I have a number of the college courses on the material) maybe there is someone out there in lala land that could contribute.
                      So if anyone else wants to contribute to this thread - lets have it !
                      Goldfinder
                      BTW mass particles, the whole of the periodic table are resonant structures in the aether.
                      Hello everyone this is my first post on any forum ever, a benchmark day for me. I keep my energy device secret because I have had 1 invention stollen from me and I don't want it to happen again, but after reading this post I have been compelled to add my input. If we all work together we will free each other at least from the power company.
                      I don't think T.H. Moray was tapping any so called zero point energy field he was doping semiconductors with radio active material like radium. In my opinion he created a very efficient electron cascade device. This is why he went from a massive antenna down to a small box that would fit in a car trunk, he discovered that the free energy was not coming from the air it was coming from the device he had created. The antenna merely excited the effect that was creating the energy. Mabey he found a way to use the triboluminescence effect of quartz without having to put stress on the crystal.
                      Well thats my input what do you guys think.
                      • to the forum. I think you are quite correct from all the research I've followed on Moray (much of it from Perreault) that he did indeed have a low level radioactive source (radium most likely) and with proper resonance tuning was able to generate a lot of power. I'm not sure about the crystal reference but I've often thought there is a reason to look at them. I've got a lot of crystals and it would be great to find a way to use them as a source of energy.
                        • Ok lurker here about to make a big post, as far as I can tell this thread is pretty far off topic so maby this will help. First off I have replicated Stiffler devices and built several joule thief circuits successfully and because of my experience with electrodynamics I'm pretty sure I know whats going on with these circuits. It has little to do with induction and all about time changing magnetic fields.
                          Read this link(Faraday's law of induction - Wikipedia, the free encyclopedia) the part about Maxwell-Faraday equation and if you understand this it will be all you kneed to know.
                          The part I'm talking about is "The Maxwell–Faraday equation states that a time-varying magnetic field is always accompanied by a spatially-varying, non-conservative electric field, and vice-versa. This means that any time you turn a coil on/off it generates a non-conservative electrical field. The non-conservative part is a big deal, this somewhat means that if we absorb/use all of that energy there is no effect on the magnetic field that generated it, now think about what this means for a OU system, we can extract as much or as little energy from the field using AV plugs, capacitors, or just plain conductors with no effect on the magnetic field that is supplying the energy.
                          If this is interesting I have more Levi,
                          • Sorry but, any standard transformer proves you are wrong....
                            The primary creates the time varying magnetic field.
                            The secondary extracts energy from the electric effects that this creates in its conductors.
                            Using this energy draws more current through the primary...
                            Or are you talking about something else?
                            Ernst.
                            • Originally posted by ;
                              Ernst.
                              That doesn't prove anything wrong Faraday's laws are correct, a standard transformer transmits power with a time changing magnetic flux in the core of the transformer. Stiffler's devices work with two different coils that are not magnetically coupled therefor the electrical fields they create are in the surrounding air and that is why when you hold a florescent light near a high Stiffler coil the bulb lights. Not to burst your bubble but Stiffer devices aren't doing anything strange or new but that doesn't mean we can't figure out new and useful ways to use this effect. Levi,
