Captret - Perpetual Light with Dead Batteries
  • Status update:
    After running till this morning the unit only managed to get to 10.16 volts. So this supports my earlier assumption that it will not recharge the battery but it doesn't discharge the battery beyond the filling of the cap.
    So that was with a 470uf 200v cap. I am now switching to a 220uf cap @ 200v to see if the run nets a charge. Again the battery started at 10.19 volts and is running 2 leds in parallel. I will give it half an hour to an hour to equalize and measure the voltage again. After some run time I'll try the current measurement as well to see if the leakage went down..
    • Try This
      This is what i was trying to describe. Maybe more Captrets can be added for better effect. Voltage still climbing and LED is brighter than before.
      • Originally posted by Jbignes5 View Post
        I have seen an 80 millivolt increase in standing voltage since i started playing with this setup. Been trying different configurations over the last 24 hours with the same 9v battery. Even if the battery didn't charge, you have to wonder why it wont discharge while it produces light.
        • I think it has to do with..
          Through induction we are setting up a standard voltage. This induction is different for each plate of the cap because one is being induced through each plate going twords the negative instead of the regular way of plate to plate. This allows the positive of the cap to operate normally and induces a lower voltage to the negative plate also. When we have the led across the positive plate and negative a current is drawn between the two points of positive to negative plate via the led which is of course a diode. this allows the current to circulate in the small area of the plates and diode and not through the battery.
          My new test setup is with a pair of caps in parallel to each other. The effect is much stronger and allows the led to full brightness with almost no current being drawn. I am about to do a test for the current.
          Ok this is what I got so far. 3.3ma current that was measured on both terminals of the battery. For the double cap setup in pair the draw is a little over the 2.3 ma I had with one. I moved back to the 470uf caps of 200v. The current draw from the battery I believe is from leaky caps. If I put more leds on the cap like normal it does not change the current draw and thats why I assume it is of a leaky cap that the current is even there. If they were perfect caps I bet there would be zero loss in this circuit.
          The one thing that sticks in my mind is that the leds work no matter how many you put on. I'm gonna try with a bunch of them in parallel and see if the current rises a bit.
          Ok went from 3 to 5 and it reduces the current to 3.2ma with the dual cap in parallel. *Scratches head* this doesn't make sense at all......
            Surely if the current you are measuring is leakage then wouldn't two caps in parallel double the leakage? I am measuring 0.05ma from the battery terminal on my setup.
            • not if...
              Not if they are in parallel. Series you would expect it to double. This is the sticking point in my experiment. Also when I put the caps in parallel mode the light is brighter from the leds meaning that they should be drawing more current and they do not. Of course they are in parallel as well so I don't have the right calculations to figure this out. Since leds are diodes they drop a voltage but as to the resistance of the leds when they conduct I don't have an answer for.
              What cap are you using for sub ma operation. Mine are big caps @470 uf 200volts...
                Well you are right about the parallel configuration. The LED is brighter and the current draw is lower. Very strange. I am now drawing 0.02ma - 0.03ma with a slightly brighter LED. I am using 47uf 16v caps.
                • Ok..
                  That is why you are drawing a lower current... Now if you have a few more caps parallel them one at a time. Next would be 3 then test it and next would be 4 then test it. Lets see if we can reduce the current down to nothing...
                  Note be careful that you are not going to blow that led as you add more caps in the setup. Measure the parallel voltage across the cap bank to make sure it stays withing tolerance of the led..
                  What I am wondering is if we add enough caps will the voltage going across the caps get stronger and maybe could be converted to a charge to be applied back to the battery via a real diode. But that means we would have to raise the voltage between the caps legs to above the batteries voltage if that is possible.
                  • It's going to need a few more caps to get to full brightness, not that bright at the moment but brighter than one cap. 2.4v across LED. I'ts a 3.3v blue.
                      Maybe there is enough to run a joulethief and use it's output to charge the primary
                      OR
                      I tried a cap in place of the LED and it measured 5.5v. If we have two captret circuits running from one battery, we might be able to series the two charging caps and charge the primary.. It probably wouldn't work but it's worth experimenting.
                      • Maybe not directly...
                        OR
                        What about dumping the voltage into a cap that can handle that voltage then dump it to the battery? I am also thinking we could parallel pairs of caps like you are talking about and adding the voltages together like a set of batteries then using a diode to funnel it back to the battery. I would have to use smaller caps prolly around the 16 v range like you.
                          Look LED's are forward conducting diodes which emit light. The have a forward voltage drop just like a diode, although it is much higher. LED's can have a Vf of from 1.2 to 4.0 volts and vary with type (i.e. color). A Red may have a Vf range from 1.2 to 1.7 volts and would depend on who and how made. Now when you connect LED's in parallel without a leveling resistor in series (equal value resistors) with each, the lowest Vf is the dominate Vf and no other LED Vf can be greater than the lowest Vf. Also the one with the lowest Vf will draw the greatest current and in most case be the brightest. When you do this all LED's that have a Vf higher than the lowest suffer. Even though most of the time a particular run will be very close, the manufacture specifies a range over which each can very, this is the reason for the series resistors.
                          Now if for some reason it makes a difference what the resistance for a LED when conducting is; measure the forward voltage Vf, measure the current in series with any one of its legs, If, now derive the resistance, Rf = Vf/If
                          • thanks for your response.
                            Originally posted by ibpointless2 View Post
                            The degrade over time is normal, i see it all the time with my LED's. But the good news is if you let the captret sit it will "self charge" back to normal and bring full power back. Its like humans needing sleep.
                            Great work so far, please keep us posted! Due you have the exact diagram of you setup i would love to replicate it.
                            Also I've posted a new diagram of the captret that can hold off the decay for a little longer, or at least it hold the LED for brighter longer, and gives a good feedback for recovering the primary battery. On this setup my battery went from 17.10 to 17.14 using a small 1uF 400 volt cap. I suggest using a 47uF or 220 uF as this is what other are saying works best. Usually when i leave the captret running on that small of a capacitor the LED is barely noticeable but today its light is nice and noticeable.
                            [ATTACH]6899[/ATTACH]
                            Hi Ibpointless2. Let me be the first to say that your efforts in this line of experimentation are far from "pointless".
                            Thanks for your interest in my device. It is very simple to build and revolves around the bedini self-osculating circuit. I have a link to my thread discussing a little about it in my signature.
                            What you see in my video(here it is on youtube as well) only one half of this circuit. You can see how it is duplicated and the left is mirroring the right or vice versa. I've used 3 watt components in the unit in my video as i find it makes for a more stable device. Note- I don't believe that there is a neon in this schematic and there should be one between the collector and the emitter as a safety precaution if your secondary bank becomes disconnected. If you have an output for the ignition coil (CFL bulf with guts removed) it will tend to absorb some of the radiant spikes as well. Under normal operation i can run the two batts in the video at 12.75volts for more than a month while driving that CFL bulb brightly without depleting below 12 volts. Very low consumption due to bulb using some of the radiant flow.
                            That is why when i saw the effect of your Captret i decided i needed to see if I could use it to improve over all efficiency or establish a perpetual result. So far my batteries haven't moved! My primary is at 12.56 and the secondary is 12.50.
                            I will begin working with multiple captrets as indicated in your new schematic and hope to post more results soon. Thanks again for your swift response and to all others working on this line of experimentation.
                            Love and light!
                            EnergeticTube.com - Where technology goes Live!
                            ETaffairs.com - Your Portal Here on Earth
                              Dumping one cap in to another will probably be 50% efficient at best.
                              • ok...
                                Well whats 50% of free?
