Here is my time trials for 60 hours (3 or so days)
For a higher resoloution please click here captretfinal | Flickr - Photo Sharing!
Yellow line is "Black"
Green line is "green" (glad calx got that one right)
Red line is "White"
Blue line is "Silver"
Brown line is LED.
"Black" is a 17r8h NIMH Rechargable 9volt battery, connected to 3, 2uF 200 V electrolytics, in the captret fashion with no load.
"Green" is the same 17r8h NIMH Rechargable 9volt battery, connected to 3, 330v 80uf electrolytic caps in the captret fashion.
"Silver" is a non rechargable 9volt ray-o-vac heavy duty 9volt connected to 3 330v 120uf Electrolytics with no load in the captret fashion.
"White" is a 200mAh NiMh 8.4v rechargable battery connected to 3, 25v 4700 uf "supercaps" in the captret fashion. no load.
"LED" is 2 dead 17r8h NIMH Rechargable 9volt batteries connected to one 1uF 50v electrolytic tiny capacitor in the captret fashion, with a LED as a load on the + and - of the capacitor, ALA the original schematic.
Review.
LED starts at 10.95 ends at 11.51 and still climbing.
Silver starts at 8.80 and ends at 8.96 and slowly climbing.
Black starts at 8.57 and ends at 8.20 and dropping........
White starts at 8.66 and ends at 8.79 and fluctuating up and down.
Green starts at 8.60 and ends at 8.33 and dropping....
I also hooked up capacitors only (25v 4700 uf) with one being the "battery" and the 3 being the captret. No load. Constant loss from 1.340 down to .475 over 3 days.
The results are "LED" has grown in charge, "silver" has increased a little, "Black" has constantly dropped, "White" has increased a little as well, "Green" has decreased, and my "quad" as in the 4 identical caps have decreased ever since the start.
Now, i think this warrents further investigation, however the right capacitor and load are needed to observe the charging effect. What the right capacitor is, I would imagine something high voltage... but who knows. "White" used 25v caps and is increasing in voltage very very slowly. The highest gain is "LED" which uses 2 really dead 9volts and a LED as a load. this light is so dim you couldn't use it as a nightlight in pitch blackness, but you could use it as something to find maybe a lightswitch in the dark... like a dim indicator or something.
I agree with Lasersaber's video that this arrangement prolongs the life of a load more then usual, so my recommended path to progress toward is replacing the LED in the standard circuit with an oscillator or JT or something that can run on very small watts and produce more light. Almost no current but some decent volts and run time this way.
Some thoughts...
Battery bounce back might take place the first 24 hours after a load or charge, while this recharging effect is constant. There is a drain on the battery larger then what I would imagine as soon as the cct is hooked up, larger then just filling the caps in the cct... Like the current is burning a new path to the O connection inside the cap. Once the path is set up, then the magic happens.
Usefullness 1 out of 10.
Interesting properties, 7 out of 10.
Maybe this could be devoloped further to do something more then have a dim light. Its a good charge controller for a power source in higher voltage then the LED could normally take.
Anyway. Thats my findings. 3 working "ou" circuits and 3 "duds" all hooked up similar, with one being different.
-->Skeptics notes. The inductance changes while the circuit is running, so thats why you see the voltage climb. (But when I disconnect the CCT the voltage remains high..) (And why would an inductance be changed in a CAPACITOR...??? )
--> My notes . I still believe that a NP OR PN or NPN or PNP junction is being formed by the passage of current burning the elements in the capacitor at high enough voltages. I have no scientific grounds to back this up, its just conjecture. Phantom diode..... The Dr. finds his Phd in a capacitor :-)
Who knows. Its milivolts being put back in, its not like entire watts. Baby steps...
At the end of the (midweek), there is a larger voltage on some of my batteries then others.. Perplexing.
Thanks for reading,
Peace.
Red line is "White"
Brown line is LED.
Review.
Some thoughts...
Thanks for reading,
Peace.
