Same Metal
IB -- Fascinating research. Thanks!
Just a thought on it: There's no reason Casimir Effect cannot relate to this. It is normally found at micron and nanometer distances between same electrodes and exists in capacitors, also. But, water is a very unique substance and lattice capable of amplification and extension of signals. When you're dealing with water and finding energy coming from it, it's generally best to start breaking away from the conventional world of physics we know. Water is like a portal to the other side and into the Ether. If you take water from a source -- such as a spring -- and split it, and take those two ounces all about the world...those are very unique, highly efficient, antenna able to conduct signals between them at beyond light speed through basically teleportation of signals through the Ether.
Study your water and same plates further. If you put a data logger to it for 2 weeks or take readings at the same time each evening....chart that data in relation to the waxing and waning of the Moon. You will find that water is always more active in the moonlight. More vital. More alive. More viscous. As the new moon comes, the water dies out. And thus the nature of your "electrolyte" there also changes with the Moon. But, as in crystal power cells, you are dealing more with lattice issues and detection of jitter from the Ether more so than electrolytic issues and galvanism.
Consider the sum of Casimir Effect within the lattice between the same rods, and then you can see how the voltage normally between two close plates can be present at greater distances due to amplification and maintenance of the signal.
Never think man knows all there is to know of water. It always has infinite mysteries to further explore. It remembers. It burns and makes fire. It quenches fire and cools. It freezes. It can fracture mountains or condense and shape them. And two drops descendant from one are the same portal a universe away while two drops pressed into one can tap into a universe of energy.
Enjoy!
Enjoy!
