Captret - Perpetual Light with Dead Batteries
  • Sorry, false alarm!!!
    When I tested the capacitor for a connection between the case and the negative terminal, I got 0 ohms as the resistance. So, regretfully, things are just as bright because it IS a direct connect with the battery.
    Thanks Aaron for enlightening me about the possibility. My knowledge of electronic components leaves a lot to be desired.
    When I took another capacitor of 48000 microfarads which did not have a low resistance between the case and the negative or positive terminals of the capacitor, the light lit up as expected, but extremely weak. So, its back to the drawing board.
    Again SORRY for the false alarm.
    • You R welcome, my friend. And nevermind with the setback, everyday we learn something!
      • I took apart 3 caps. none of them looked like they used aluminum for anode and cathode. the thicker one was something else. maybe zinc? two smaller ones smelled like ammonia, larger one smelled like brake fluid (fine oil). In my experiments with earth batteries I noticed they act more like self charging caps than batteries......so now I want to roll one up with copper and aluminum foil with a third foil electrode spiraled around the whole thing. Will be using plain water or a light oil. It has been my experience anything added to the water increases current but is destructive. Thanks for sharing this effect.
        • Ok, H2O = H2+ O1- or water, it has a natural valence. if you split water, incidentally, two hydrogen cancel out one oxygen, but due to the amount of space they occupy individually, oxygen is the more prominent conductor thus water is a Negative potential carrier. Two hydrogens occupy more space, and the oxygen itself is more dense. Capacitors do not work the way you think. All energy undergoes the flow via Skin effect. Caps do not let energy flow through them but in fact energy envelopes the skins of the structure and bouncing off the dialectric like a superconductor via/skin/corona effect. If you want to avoid arcing or losses you smooth all the flat edges, flow does not like sharp edges. Also the way optical lenses work. Look at pictures of the egyptian lightbulb, they are disk shaped but rounded and slightly parabolic. Egyptians were very detailed. All these phenomenon are akin to the way crystalline/crystal structures behave. If you remove the water from them they get tighter and the energy flows across their surfaces faster and skips from point to point, in fact moving faster than energy could across a flat surface. This inspired tesla with his disk turbine. He referred to it i guess as a kind of surface tension or stickyness like water has when it runs off your windshield. When you make a capacitor out of two dissimilar metals you get a valence, like copper and zinc, the energy wants to flow towards the denser charge just like in a magnet. This is what causes decay, the smaller magnet is getting absorbed by the bigger charge, it wants to BECOME more powerful charge. So bigger purer portions will decay off while the impurities are the salts buildup or corrosion that we see.
          If you build a battery out of identical plates, there is even less mass exchange because the magnets are all the same charge/base/metal. Like aluminum plates or lead plates. Now the energy will either store as waves/ridges/mountains on the surfaces of the plates or if the dialectric is strong enough it will simply skip through the cap/battery as pure potential. Storing energy causes it to lag. It's like saying the more felxible your potential is the more of a frequency you can compound on it, then send it to a higher voltage less flexible cap and it will POP an WARP, look up Tom Browns Gravitators. Your captret effect is acting like a negative diode and if you can match the shape/flow of the bigger plat smaller plate you can direct which way you want that flow to move. + is generally the highest potential force, like the earths N magnetic pole. You can probable replace any all semiconductors/diodes/transistors with water/phantom/simplex circuit. If you use similar metals, you will experience little to no corrosion and if you match the frequencies that the materials naturally like, you should never experience any "Drain" or lag on the materials. I believe this is why crystal cells work soo well, although they DO decay, the effects are minimal and lifelong~close to. If capacitors are made out of half circles instead of square/rectangular plates you get different "effects." Look at the pictures of some vimanas. I really would like someone to experiment with some phantom/simplex circuits in place of diodes/transistors for these exciter circuits.
          The entire earth system is a free energy semiconductor circuit lol. Tubes/horns amplify sounds right? Perhaps there's a link between shape/sound/frequency/valence/numbers etc. My mind keeps going back to the wheel/tarot/zodiac/elemental/spirals/condensers/colors/tones. The compass of the universe doesn't have just NSEW, it also has UP and BENT/warp to the 90 Up. I guess we could say momentum/inertia, The Zero and the one, so a loop/spiral then a square cap with a Triangle or diode/transistor, each of them represent one of the fundamental shapes of the platonic solids. They say the hexagram is for levitation/carbon7 perhaps the way it is bonded will indicate a pathway/flow for energy to take. and we can mimic that in a circuit. Which shape represents illumination etc. I think we are still on the basics, which is fine lol, have to crawl before we can walk right. I've been trying to electronically find substitutes for the major things
          I also remember seeing victor grebennikovs bug wings, they appeared to be like triangular cells that fractaled into some zero symmetry. As they kept ascending and descending. Like our coils do.
          I always wondered why they found a human footprint in precambrian rock. IF humans landed here giligan style, with no life whatsoever, there must have been some simple way to do things. Perhaps energetically speaking things were different then as well lol. I believe as well, that the secrets are embedded in our languages, mathematics, geometry etc. These free energy devices do not create energy from nothing, they are soaking up the finest latent magnetic particles of the universe. Waves projected warp space in such a way it creates a fold/vortex that energy seamlessly centrifuges downward. If you example water and how it flows, should inspire some of us, nothing likes 90 degree bends except when it's squirting/propelling. Cogs like to go from smaller to bigger or bigger to smaller, so do condensers.
          Please excuse my ramblings.
