Captret - Perpetual Light with Dead Batteries
  • #61
    Originally posted by Jbignes5 View Post
    Listen I am very sorry Doctor. In my haste I did not see the link below your post because many many others have personal links there. Once you mentioned the link I quickly looked at it and saw what you were referring to. Like I said I am sorry.
    The thing that separates the two is that one you were using a somewhat more complicated setup then IBpointless is. I guess it doesn't matter in the strict sense but I would think that the type of power either pulsing or even standing wave generator is a very different effects or outcomes.
    Seeing that IB is not using any power modifications does bring to mind that there is something odd happening here and that it involves laying an ac signal over a dc component with no real device to do this (oscillator) besides a setup of two capacitors and a diode plus a static source of potential. I'll have to look at the circuit again but I think this goes beyond the scope of your device (sec).
    @Jbignes5
    Apology accepted.
    Have you seen any of the video's or postings in my thread on the SGATE? The SGATE is a structure using a three plate (although in many configurations hard to see plates) capacitor where one is 'parasitic'. Granted this does not match what is going on here with the simple configurations, yet I feel comfortable that it is taking place for the same reason.
    • #62
      So i just built the circuit above, it uses the negative resistor circuit but the capacitor has been turned into a captret and the captret part charges a AA battery, or at least i hope.
      I was trying to pulse charge the AA battery, every time the capacitor discharge the captret should too and it should dump that into the battery. but i think its all wrong. The LED shuts off when connecting the AA battery.
      Further testing needs to be done, thought i would post what i got so far. Suggestions are welcomed!
      • #63
        Heres a better picture of my last post.
        • #64
          May try a higher Resistor as 100ohm or the 100 ohm and a Pot in Serie.
          I supopse the Led turn off because the Diode inside the Transitor blocks,
          when the Voltage goes over 1V or 0,7V.
          • #65
            captret replication test
            Hi ibpointless
            Thanks for this idea
            I tried a replication and here my results.
            1- I tried the circuit you proposed just above and get a nice blinking led but very poor result at the *top captret".
            2- i replicated the circuit that i found in Artisan's post link , the circuit with 2 transistors (PNP and NPN). And it works much better. See pix of the circuit and the setup.
            3- But what intrigues me is that at the beginning the Led conected to the 0 of the cap is bright and with the time it loose the brithness. Than i shorted the cap and redo the connection but the led did not get the original brigthness.
            As if the captret loose is efficiency along the time
            I have tried the system with many electrolitic cap and it seems that the more voltage and less capacitance is better. My last setup is with a 22 micro F and 450 volts.
            Ofcourse all this need more testing.
            In this respect i would like to thank Dr stiffler for his great link on his work, very interesting , and i tested a Slayer exciter and a AV plug to cap and Ground connection. Wowww the voltage just jump up in seconds.
            OK for tonight
            Laurent
            • #66
              Originally posted by woopy View Post
              Hi ibpointless
              OK for tonight
              Laurent
              Hello,
              Please find attached the derived circuit. I hope this helps (esp. in response to ibpointless' last post).
              I hope to be replicating with all of you in the near future
              Best regards,
              • #67
                Originally posted by Artisan View Post
                Hello,
                Best regards,
                Great work!
                I really like the idea, this is what i was trying to make; all i need to do now is make it.
                To keep things more interesting I've added something quite interesting to spark a few peoples minds. The LED is light, a form of energy, so why not put that to work? I've added a simple solar panel so that you can place it above the LED to recollect the wasted light energy. It puts no extra load on the circuit but it may need a transformer hooked up to it, i'm sure the voltage will be in the millivolt range but that something small can add up quick!
                • #68
                  It Works!!!
                  @ Ibpointless, Dr. Stiffler, & All
                  I worked on this today and got good results. Dr. Stiffler-- I studied your work on this at the link that you gave and did a replication using my SEC 15-3. I got hung up on the Joules calculations otherwise I would be posting those results. All I can say is that my results looked good but not like what you had. My setup just isn't adequate to do precision work with accurate measurements. What I did see was very impressive though. A big cap charged up super fast when it was hooked up to the SEC and the earth ground through an AV plug.
                  The testing with the Captret was very interesting and after I got it to working the original way, of course I had to mess with it a bit. This is the video of what happened.
                  YouTube - Captret replication.ASF
                  Cheers,
                  Lidmotor
                  • #69
                    Hello says a little bit crazy Swedish amateur.
                    it is very fun to follow all the experiments. and then try to replicate them.
                    Do not ask me why, just a thought I had Could it have something to do with orgone with this?
                    If you look at the orgone acumulator ............... hmmm
                    Roger
                    • #70
                      Oh yes...
                      @Jbignes5
                      Apology accepted.
                      I am very familiar with your studies. It is interesting parallel to your work but he doesn't seem to need the sec to get this to work. That to me is the most interesting development. The sgate is a very interesting concept and I know it looks the same but I think there is something more to this then just the sgate configuration although it is somewhat parallel to your work.
                      Heya Lid.. Excellent video! I am a fan of yours as well lol...
                      • #71
                        Last Setup with a 47µF/ 63V Capacitor and my 9V Batterie,
                        8 Hours run time, the Batterie climbed from 8.90 to 8,912 V right now.
                        The Led only dims now, its brighter when you connect it fresh to the Circuit.
                        But at last, no Voltage Drop, but a gain.
                        The Batterie should quit have some Capacity it was charged before,
                        so it is not a emtpy one.
                        Yesterday i played around with 22µF Caps and the 220µF,
                        but had allways loss, so i think the 47µF works at the range.
                        Also i tried to use a Cap bank as source, 3x 4300µf in parallel,
                        but it dont works that they can hold the charge.
                        Capacitors, as they are made are really bad Storages,
                        and still shows it again and again. Even, that they make a short at the first charge what they get between minus and plus.
                        Therefor are maybe chargeable Batteries or Accus the better choice.
                        • #72
                          Anyone else seeing the bigger picture here? the captret takes DC voltage and transformers it into AC. Its got to be the simplest inverter, enough voltage and you could run you TV on it. And its more efficient than the normal inverter due to its ONE component setup.
                          And those that wonder why i call it the "captret" is because it was a capacitor that acted like a electret. Charge the cap first, then test the top of the cap with a multimeter to the positive of the lead and watch the voltage go down, remove connection from multimeter and wait a minute and then reconnect to see the voltage has bounced back up just like a electret. I've been trying to tap that effect, and that has lead me to making the LED driver captret circuit.
                          • #73
                            but it don't works that they can hold the charge.
                            Your 3x 4300uf caps where to big, the bigger they are the longer the LED takes to turn on; my 1F super cap to 30 minutes before i could see any light. once full brightness you can disconnect them from the battery and have it run a good bit of time!
                            The light will get dim, but it find a spot and stay there. i do say the 47uf are very unique.
                            Something unique to try is to disconnect the led and just tap the lead, you get a short bright burst of light; that means that the captret part recharges it self in short burst. That burst is what we need to be focusing on.
                            • #74
                              Cheapo charger
                              this is a good little circuit. I hooked up flashlight leds to a new 9 voll battery. Ran lights for 1 hr. Start=12.5v Finish 12.9v 1 hr rest 13.6v
                              Hooked up to 2 x 200v 1000 uf caps in series.
                              Started with small 36v cap, very dim light, 50v, dim, 200v brighter, 250v is good brighteness.
                              I have some door knob 15kv ceramic caps from Russia. How would one use those. Will foil wrap outside work?.
                              Played with 1 x 250v 2400 uf and 2 x 250v 2400 uf works good too. Now gotta look for dead battery and try lidmotors variant
                              Lets scale em up boys, 12v lead acid battery. Need huge caps.
                              • #75
                                Hi,
                                My 3x 4300µF been actually my Source,
                                there was no Batterie connected to the Circuit.
                                I did let it run with the 22µF or the 47µF Cap,
                                and charge the Bank to different Voltages, once up to 20V and more,
                                and let them run for a while.
                                But actually it was more a Reply to Dragon
                                A better test might be to use a 1 farad cap as the power source this way the energy could be calculated and compared a little easier.
                                Voltage is a poor indicator of the batteries state of charge, it will consume amp/hours while maintaining voltage until it can no longer sustain voltage as it is depleted. There really isn't any way to calculate the actual charge in a battery.
                                And well, the 9 Volt Blocks may are in that case good enough,
                                because they dont have that much Ah (more mA) as a Lead Batterie,
                                and you can see pretty fast, if there is a Voltage drop,
                                when you take Energy out.
                                47µF seems it a good choice now, there are 80µF and 100µf,
                                but i dont have any of them right now.
