Energy By Motion
ozone.bz
Hi back at it, Tomorrow I will run more tests with a load and post results in a few days
Look at site interesting
Originally posted by WeThePeople View PostI have thought about this a bit and I have resolved one thing
(Besides either multiple commutator connections and/or windings)
is that the required brushes would have to one half the standard width
of the commutator spacing overall to allow seperate
driving and collection of magnetic interaction in the first place.
Another possibily to harvest is to have a double-long commutator on the rotor,
and adjustable slightly altered recovery brushes.
But they would have to have brushes very slim for recovery,
to not waste it shorting to the next winding pair sequencially,
because the brush contacted the next winding sequentially.
This thread is not really the Lockridge device its more like how to build a better motor however there are many principals used here that I believe are an important part of it.
I understand exactly what you are saying, maybe you should read some of the related threads on the subject and much work of that nature is being done.
It seams that no one as yet has put together a device including all the principals. I don’t have a thread on this forum covering these but I do have one here Imhotep's Lab Interactive FAQ - View topic - The lockridge device I am still in the early stages but making progress.
because the brush contacted the next winding sequentially.Last edited by WeThePeople; 04-17-2011, 04:53 AM.
Originally posted by Dave Michael Rogers View PostI believe John did see one of the original German generators running whilst he was on security detail in Germany in the 60's. It nearly got him court marshaled.
A couple of years ago I heard another account from a totally independant source about such a generator with the claim that an original German Bosch unit is here in Britain...
by at least someone, I deleted all the above dribble as well.
My point both is and was that simultanious carbon brushset's
that both supply and capture from a rotor cannot possibly
occupy the same commutator no matter how shaven,
so there must have been cross-wired rotor windings...
Or seperate capture windings staggered from supply
are wound on the same supply rotor poles,
and stagger-wired to the commutator for recovery
A duality of pole wiring in identical fashion
wound on the same poles in dual,
but wired, say, 90-degrees out of each,
would allow the windings to be both supply and recovery,
with proper spacing of commutator brushes.
It would sure support the need to grind the brushes
to a narrower width to space function required.
Leading grind for supply,
lagging to collect collapse.
Just like all tesla patents observing the concept of using a rotor to convert DC to AC really,
he didn't say we couldn't toss a FWBR to make usefull recyclable return-to-input fodder...
Thank youLast edited by WeThePeople; 04-17-2011, 04:37 AM.
Originally posted by Dave Michael Rogers View PostHi Matt,
Was this to me?....
Sorry for the misunderstanding.
Hi Matt,
Was this to me? Of course I build, and test which can be seen on my Youtube channel.
I've tried building a Lockridge device, and was experimenting with back popping genny coils on my SG a couple of year back, again which can be seen on my youtube channel, but this was more akin to a Watson setup.
At present I have a set of armature laminates that were going to be for the next Kromrey setup, but I may use them as part of a Lockridge type device instead.
The whole point was not to replicate it to detail, the point was to start looking for a better horsepower to watt ratio in conventional motors. See if this is even possible before going on and trying to push a generator to resupply the charge to the source.
I personally haven't come to a final conclusions. So much has become possible lately, that the testing just continues. Are you testing? Or are you just too opinionated to try?
Unfortunately building something is the only way to see.
Originally posted by WeThePeople View PostI have pointed out without corrective response,
both Peter and John have NEVER SEEN ONE RUNNING !
But you are right to question why there hasn't been any surviving units from Germany or from the device Lockridge produced in the US.
A couple of years ago I heard another account from a totally independant source about such a generator with the claim that an original German Bosch unit is here in Britain, but when dealing with people who are NOT on the internet, how do you chase it down? Unfortunately, belief doesn't equate to knowledge.
Reggie's self runner
Matt suggested adding a couple ammeters, after all power is I*V. Did you build a couple motor types then, one using a starter? The SRM looks like the razor scooter motor.
So it the same schematic as I posted here.
http://www.energeticforum.com/renewa...tml#post127907
I doubt seriously there is any justification for calling it a self runner. You'll figure it out when you actually look at the the Watts and not just the voltage. Your just lowering the input to the system from the battery by charging the cap with the output of the coils, so the battery pops back up a bit.
A long run to measure battery voltage before and after will most likely show a loss in battery voltage.
small electric motor
Hi
1)The hook up is Red wire + from battery to + cap1 to + input motor
2) Black is - from battery to - cap3 to - input motor
3) Green is recovery from motor to rectifier to cap1 - to cap 2 +
4) Yel is recovery from motor to rectifier to cap 2- to cap 3+
Meter on left is hooked to battery
Meter on right is hooked to center cap.+ -
when I get a digital amp meter more will follow on readings
I have a few motors rewound the same way
with 3 caps 4700uF 450 vdc each if one wants one let me know Thanks for input
Originally posted by goreggie View PostHi I reposted the small motor for testing.
YouTube - self running motor start.wmv
YouTube - reggie's self running electric motor.wmv
I do not have test equipment to test this so this time I'm not saying self running motor until it can be shown to be true. Thanks
You need some explaination on the second video, I'm not quite sure what I'm looking at.
