Originally posted by Turion
http://www.energeticforum.com/renewa...tml#post162546
I wasn't understanding what mbrownn's point was, but, now maybe I do.
Peter's design used two sets of brushes. The first set to pump current into the windings and the second set to recover the current.
You could do the same thing using only one set of brushes and a switch. During the first half of the commutation, you pump current in, then hit the switch and recover the current during the second half of the commutation. The only problem to solve is how to synchronize the switch with the commutator, i.e. to hit the modified windings with current at the very moment they make contact with the commutator.
Then, of course, it is possible to go down the path that mbrownn is going (iiuc) and think about using an unmodified motor with all of its (series) windings in place, pulsing the current in and recovering it at your pleasure. This method (probably?) doesn't require synchronization with the commutator, since it will always be in contact with some part of the windings (is this correct? I need to think about it more).
I still haven't sussed out what mbrownn is thinking regarding the trifilar coil (which was encased in the capacitor in the original device, iiuc).
A tangential point: while waiting for a flywheel to be made, I've been re-viewing Peter's video (some 20-ish times, getting something new each time).
It finally dawned on me that a very good flywheel can be made using a 20-inch bicycle wheel and gluing weights to its perimeter. If the weights happen to be ferrite magnets, you could drive coils with them and voila - a generator. If you go back in this thread, you should find my quickie experiment where I drove a single coil with a makeshift flywheel and used a shorting reed switch to pump a cap up to something over 100V.
pt
