stuck on theory
Are you telling about a kind of transformer?
So in a transformer you need ironcore or metglass as a magnetic
media. so the air coiled trifilar cannot deliver enough energy to the 300W light bank.
300W -> my Trifilar will melt away !
240 turns of magnet wire 21 is not very much.
even if you use the tesla patent "Coil for Electromagnets," patent #512,340
(bifi selfcircuited)
you cannot transfer 300W
So the only part is to use the CASE of LR as an Ironcore.
but rotating fields destroy / shifts the phase of magnet flux away ?
this will really weird but maybe a key to the function.
So you need to transform the 12V AC to 220V AC for the bulbs ?
we need 10 times more windings on L3 than L1 to shift the voltage
from the generator to the bulbs, with 12 V trifilar you will see not even
a glow in the bulb.
A relay to switch the light bank as an ballast to the generator
not to burn the gen coils ?
Attraction to what or whom ?
could you be please more precise, i´m not sure what you mean .
So if you "held" the flux in the case, you cannot "consume" it to the bulbs
instead you have to shift it forward , round by round ?
always add a little kick ?
The magnetic Diode is very clever ! Wow
Impressed me. I didn´t test this out, but soon i will test it.
Yes you could. But the magnetfield arround the trifilar will interferere with
the rotating field in the GenMo (Generator/motor combo).
An OpAmp is fast enough to do an PID , measure the resistance and
instaneous output a difference signal to the MOSFET driver -> adjust L properly.
but in resonance the losses in the coils are almost zero. Xl=Xc=0 (in theory)
so drop in Amp from the power supply at constant rpm (when you feed constant Voltage to the motor)
or rising RPMs with constant current supply.
another approach: (not tested, but inspired from JB SG Cap Discharger)
charge a capacitor (diode) inside the Resonance loop.when you reach the 30V then you can "click" an relais
to push the joules from the cap to the Motor. (KICKMode)
say "in the right moment"
Resonance is short lost, but the motor turns further (momentum)
the resonance should reestablish and the cycle repeats.
Ismael Aviso:
He find a way to short circuit the motorcoils at the right moment to
(on the peak of the sinus wave) and charge insteanous a cap without
"lenzing" the generator out !
so you could use 2 Coils of the generator and close them
with lowest (!) resistance at the peak (when rotorfield approach the statorwinding)
so you recycle power and say bye to Mr. Lenz
No Lenz no Drag on the generator. perfect
OK Mr Brown.
I will shortly forget the resonance mode.
So if there is no LCR system at the moment.
how will you connect the parts to get a working model ?
What I have overseen ?
The lockridge appears to have this configuration. Remember you do not have to drive that second coil, by using it as an output current flows and impedance changes. In a motor generator configuration like I have done, the lowering of impedance causes the device to draw more current. By drawing current from the generator coil when supplying the device with AC we get acceleration. Acceleration under load. This was using a simplified armature but even worked a little with a standard armature.
I dont know if your idea about how it works is the same as mine, but you seem to be looking at similar principals
As for resonance and using it as an LC circuit, it seams to be leading me away from that, but we just dont know.
I use the reverse engineering approach and let the device teach me, and it has taught me a lot.
a glow in the bulb.
Robert49 did report a "clicking sound" here. A possible clue to a missing component. What makes clicking sounds? A spark gap maybe? I also heard about the resonance sound from another source who I just can't remember. JB or Mark McKay? Not sure.
If I am correct, and it works in attraction, the flux will be held within the case and very little will leak out. This would mean that the reason the the trifilar coil are wrapped around the case for only one reason, convenience.
I still believe it is possible for the trifilar coil to be used in a way that Babcock showed us, as a choke to store energy. This coil would then impedance match by supplying whatever voltage is required to maintain current in the motor.
The Idea of resonance in the motor is not without merit, but suffers from problems. The bigest being that the inductance in a motor constantly changes as it rotates, and as load varies. How to make a circuit respond to this is problematic and I was unable to do it.
From resonance we get voltage gain and not current, until we discharge the resonant circuit. My attempts at tapping the circuit to draw power were unsuccessful as it killed the resonance. Maybe you know how to do this but I don’t
Ismael Aviso:
OK Mr Brown.
