Tesla Solar Oscillator/ MIT ORC hybrid - DIY low cost high effeciency
  • Tesla Solar Oscillator/ MIT ORC hybrid - DIY low cost high effeciency
    This is a hybrid of new and old to solve our increasing human energy needs.
    MIT ORC solar passive system intergrated with high frequency tesla oscillator. This can be adopted for battery charging.
    Tesla Oscillator - high effeciency
    MIT ORC
    http://www.shpegs.org/images/px.png
    Parabolic passive solar collector is made of plywood and mylar plastic, High deficiency at 90%. In addition to electricity generation, This system can also recycle heat for refrigeration in another module that ORC had developed.
    http://www.polskifiat.net/images/ORC.jpg
    cont.
    Tesla had built a simple device powered by the vibration of air and without valves with only one air inlet and a moving part. Not specify the energy, it was assumed that he used only a quarter horse to make it work. After connecting the camera to a metal pillar in the building where his laboratory and have operated for some time, he produced a resonance that shook buildings in the neighborhood and threatened to demolish them. What would have happened if Tesla had not stopped the machine by breaking with a hammer. Geoff Egel has not seen the device but imagine how Tesla was able to modify it to generate electricity from alternative high frequency in order to transfer without son. He thinks that the Tesla device was mounted on rubber to prevent the spread of the vibration in the neighborhood. So he knows, these ideas are not protected by patent.
    http://www.polskifiat.net/images/ORC.jpg[/IMG]
      ORC pdf
      ORBi: ORBi User License
      This is a paper written by Matthew Orosz, inventor of the ORC.
      http://www.labothap.ulg.ac.be/cmsms/...E_SQ010607.pdf
      ORC absorption refrigeration cycles.
      The Tesla oscillator will be powered by steam from the closed loop ORC, this system has been field proven but hampered by their chosen turbine which was an automobile air condition scroll compressor in reverse. Tesla had worked out all of the inefficiency in turbine and come up with his Bladeless turbine, this however is a much simpler turbine that converts steam directly to ac electric with no loss, which can be rectified for battery charging.
        Mainstream use of oscillator generator
        Shawn Frayne's Windbelt generator already uses this type of generator for Wind Turbine.
        www.rexresearch.com/frayne/frayne.htm
        Anyone got link to non linear generator that can be used for ths setup?, Non Lenz will have more output for charging
