Originally posted by SkyWatcher
Hello Skywatcher
You are correct with your analysis of the circuit principles.
It was very important to completely isolate the coils from the battery when feeding the EMF back to the source.
The circuit works just as well with a NPN 3055 and a PNP 2955. I have tried both FETs and transistors; you only need to calculate the Base resistors as apposed to FET gate resistors.
There is still a load being created when the magnet approaches the core, even with the isolation. A load is still present in the system, But that load is power going back to the battery and adds to the charge effect.
I am going to add another semiconductor to negate the current being generated by the approaching magnets before switch. Just not sure if it will help of not need to make full test before I can post results.
As it is at the moment it runs as no change and no discharge there appears to be parity of unity 100 % efficient all circuits run cold and no lose or gain most amazing results. That is for the drive coils.
There are a few LEDS on the generator coils pulling 20 mill Amps but I don’t count that
as part of the experiment at this point.
