Has anyone else experienced this?
You take two batteries or two capacitors and hook them up positive to positive and negative to negative; one battery or capacitor is bigger than the other and has a higher standing voltage. Once everything is all hooked up the Lower voltage battery or capacitor will go up as the higher voltage battery or capacitor will go down until they equal out. So let’s say the higher voltage battery or cap has 12.54 volts while the lower voltage one has 12.36 volts, both together have a total voltage of 12.54 + 12.36 = 24.90 volts. So when you hook them up positive to positive and negative to negative the voltage on both becomes 12.45 which makes since because their combine total voltage is still the same 12.45 +12.45 = 24.90 volts.
So here comes the crazy part, leaving it connected for some hours and it will start to climb up from the 12.45. Letting mine sit for 24 hours brought both batteries up to 12.50 volts with a combine total voltage of 12.50 + 12.50= 25 volts. 25 volts is much higher than the original 24.90 volts that I started with. So where does this extra power come from?
How to steps
1. Get two batteries or capacitors, one bigger than the other and make sure the bigger one has a higher voltage then the little one.
2. Allow both batteries or capacitors to sit for at least 12 hours not connected to anything so that they can get a standing voltage in them.
3. Measure the standing voltage of the big and little battery or capacitor, and then disconnect the meter.
4. Now hook them up positive to positive and negative to negative, see diagram below.
5. They should start to level out quickly, measure the voltage across both batteries or capacitors and when they both have the same voltage record that voltage. Disconnect meter.
6. Allow it to sit for 24 hours, you can check the voltage throughout that 24 hours but don’t leave the meter connected.
You can combine a battery and capacitor together if you want. The battery must be at a higher standing voltage then the capacitor. You would connect it up the same way, positive to positive and negative to negative.
How to steps
