Testing the fuel
First off
for the great info.
I had read your posts on these 3 tests before and there simple enough to do.
You mean turmeric, the plant ? Hummm... not sure where to find that here. since you state "a pinch" I assume just enough to get a noticeable yellow color to the alcohol ? Wouldn't stirring with plastic risk falsifying the results ? a glass stir stick would be better ? I guess we want the fuel to be as close to ph7 as possible but what would be a reasonable limit ? I also look into getting a more precise ph test for fuel at a reasonable price if need be.
Interesting, this test would give us a general idea of the degree of contamination, but nothing else. Should I but a lid on the pan or leave it open ?
I'll run all of these tests on fresh samples of diesel from different retailers in my area to make a baseline for me to work with.
Water, gravity and flash point are relatively easy to adjust. Even ph can be dropped by mixing with diesel from the pumps if it is not to much off and probably a simple way to lower the acidity. But what if the fuel is all good in these 4 tests but the copper strip test is way off, Want to do white the fuel ? How polluant will it be to burn in a furnace ? would re-prosseing it into gasoline clean it up ?
Lastly, I know the water and gravity test are also good for gasoline. I'll need to freeze the gasoline to do the flash point test. But the ph and specially the copper strip test worry me a bit more.
