  • Sorry to create hot debate, but these are my figures,
    LDPE input--21.5 kg
    coke/waste--1.2kg
    diesel recovered--19.7 lt.
    You tell me the%?
    • Originally posted by rozier56 View Post
      LDPE input--21.5 kg
      coke/waste--1.2kg
      You tell me the%?
      Thanks, rozier56, and mjohnson1 for posting your results. Looks like you two are doing well.
      Welcome 69furball69, I have seen some of your videos on YouTube. It sounds like you have the right feed stock, so all you have to do is build yourself a pyrolysis unit. There is no single post here that sums up the process. I have built a forum around pyrolysis of hydrocarbons and organized it by topic, so you should easily find what you need to build a pyrolysis unit.
        LDPE input--21.5 kg
        coke/waste--1.2kg
        You tell me the%?
        19.7 liters * .832 ( density of diesel lt/kg) = 16.4 kg of fuel
        16.4/21.5 = ~76% conversion rate.
        Just like my test
        • 69furball69
          You're going to want a shredder or at the very least cut up the bumpers because trying to stuff bumpers like that into a retort is going to end up with a lot of wasted space.
          For your retort you can weld one up out of some mild steel or find a large empty tank. Make sure to test for leaks using water/air.
          • Thks mjohonson for the correction in yield,taking density into account, i forgot to do that in the excitement of the occasion.Still i feel goood!!!
            • Originally posted by 69furball69 View Post
              It's going to take me a while to read all the posts but what we have is car bumpers.
              I thought car bumpers were ABS, not sure if recycling them is as strait forward
              as HDPE and PP. Please read the whole thread. Good luck
              • Originally posted by mercedes 308 View Post
                69furball69, if the bumpers are indeed ABS, instead of PP, then you are definitely going to want to stay away from cracking it into fuel.
                Even if you succeeded in not killing yourself, and everyone else within 50 feet of your pyrolysis unit, then the fuel that you get out of cracking ABS, or any other halogenated hydrocarbon, is likely to ruin the seals in any injector pump that uses your fuel in excess of 3%. So, why bother?
                • high tempreture sealent
                  l find another high tempreture sealent on ebay it may be help for others l dont know if it is cheap or not for other country
                  1 x HIGH TEMPERATURE 1200'C ADHESIVE GLUE FOR EXHAUST FIREPLACE OVENS COLLECTORS | eBay
                  • Thanks, jonathan, for your recent links to high temperature sealants. It is very useful having such information on this thread. I find just plain old sodium works great as a high temperature sealants, and is usually the active ingredient in most high temperature sealants.
                    • sealent
                      Thanks beyond biodisiel
                      • Wow done all 98pages.
                        Thanks all for your input.
                        Now I will start collecting the parts and re reading.
                        Just one question please.. What about those new hot plates that heat with magnetic field changing. They seem to be super efficient. Is that not the solution for controlled temps.
                        One more. Is there no technology for compressing the gas to a liquid state like LPG.
                        If we can make the gas work for us then pyrolysis of tyres will be viable too? Or not.
                        • Originally posted by kvdb111 View Post
                          Good work
                          I have read of researchers using microwaves for pyrolysis, and perhaps electromagnetic heating might work, but I do not believe the consumer units are capable of withstanding 800F (425c). I use the coil from an electric stove as a hot plate, plus 2 band heaters and a line wrap heater, both of which were designed for 2000F (1000c) service.
                          Yes, but it is expensive equipment unless you can get lucky to find one in good condition surplus.
                          Yes, tires can be pyrolyized back into oil and fuel, and people do it.
                            The process is really simple, it is similar to how alcohol is made. If you heat plastic waste in non oxygen environment, it will melt, but will not burn. After it has melted, it will start to boil and evaporate, you just need to put those vapors through a cooling pipe and when cooled the vapors will condense to a liquid and some of the vapors with shorter hydrocarbon lengths will remain as a gas. The exit of the cooling pipe is then going through a bubbler containing water to capture the last liquid forms of fuel and leave only gas that is then burned. If the cooling of the cooling tube is sufficient, there will be no fuel in the bubbler, but if not, the water will capture all the remaining fuel that will float above the water and can be poured off the water. On the bottom of the cooling tube is a steel reservoir that collects all the liquid and it has a release valve on the bottom so that the liquid fuel can be poured out. Here are some pictures to better understand the design:
                            This device works on electricity (3 phase), it has six nichrome coils as heating elements and consumes a total of 6kW (1kW each coil). The coils are turned on and off by three solid state relays, one for each phase, the relays are controlled by a digital thermostat with a temperature sensor just a bit below the lid, so that the vapor temperature can be monitored. You need to heat the plastic slowly to about 350 degrees and just wait till it does the magic. Our device has a capacity of 50 liters and can hold about 30 kg of shredded plastic. The process takes about 4 hours, but it can be shortened considerably by tweaking the design a bit. As I said, this makes a liquid fuel that can be used as multifuel, that means it can be used on diesel engines and also on gasoline engines, but we still need to test it will work on gasoline. It works for diesel engines just fine, that has already been tested. There is a difference in what plastic you use, if you use polyethylene (plastic cans, plastic foil, and all kind of flexible non break plastics) you will get out liquid fuel that will solidify as it cools into paraffin, it is still good for diesel engines as long as you use a heated fuel tank, because it needs to be heated just about at 30 degrees celsius to be liquid and transparent. If you don't want that, you can put the paraffin through the device for one more time and you will chop those hydrocarbons even smaller and half of the paraffin will turn to liquid fuel and other half will remain a paraffin, but much denser and will melt at higher temperatures, this is the stuff you can make candles out of and it does not smell at all when burned, maybe a bit like candles. But if you use polypropylene (computer monitor cases, printer cases, other plastics that break easily), you get out only liquid fuel, no paraffin at all. All you need is just filter the fuel out of solids and you good to go and put it in your gas tank. We have made the analysis and it is almost the perfect diesel fraction. It has no acids or alkalines in it, like fuel from tires does. The unit in the pictures can convert about 60 kg of plastic into 60 liters of fuel in one day. Other methods of heating the reactor can be employed, electricity is just easier to work with and control. Some Japanese companies manufacture such devices, but their prices for this size unit is more than 100 000$, our home made device cost us 900$ max. We use aluminum oxide bricks to insulate the heat, they are light as foam and can be easily cut in any shape, but any kind of insulator can be used. The bricks make the highest costs for this device. It can also be made using liquid fuel burners to heat the reactor, this will enable to make the device self sustainable by using about 10-15% of the produced fuel along with the produced gas. A small farm can use a device this size and make fuel for itself by converting plastic waste to fuel, farms have very much plastic waste and it is a big problem, at least in my country. Our next goal is to make the same thing possible using biomass, every farm could then use old leafs, wet grass, saw dust and all kind of biomass and gasify it into tar like substance that can then be put through the pyrolysis device and turned into biodiesel. But we will see about that. Here are some fuel samples:
                            These are samples from polyethylene, in the first run out comes mostly paraffin like liquid that solidifies at temperatures below 20 degrees celsius, the other clear sample is from the same paraffin that is gone through the process one more time. Will post more pictures and a video later.
                            Jetijs
                            Hello to everybody and thank you for sharing your knowledge, in particular to Jetijs.
                            I'm going to construct a pyrolysis system and I would ask if an expansion vessel (closing the bottom part where there is the valve) can be used as reactor camber. Do you see any problems?
                              Jetijs
                              I'm going to construct a pyrolysis system and I would ask if an expansipn vessel (closing the bottom part where there is the valve) can be used as a reactor camber. Do you see any problems? The acting pressure inside the camber can determine a failure of the vessel that I want to use?
                              • Originally posted by NickTech View Post
                                Welcome NickTech, if you are going to crack solids, such as plastics and rubber, back into petroleum, then you will want a large enough opening at the top to get those solids it. I think 1ft (12"/30cm) is a good diameter. If you are planning on distilling waste oils, such as waste motor oil (WMO), then a 3/4" tapered thread fitting should work fine.
