Originally posted by Jetijs
I would like to recommed everyone in the forum to go through the book
Feedstock Recycling and Pyrolysis of Waste Plastics
someone earler recommended this book on this forum I went through it & it's worth reading . Wealth of info .
CHAPTER-15 of the book is the essence of the book .
Overview of Commercial Pyrolysis
Processes for Waste Plastics
JOHN SCHEIRS
ExcelPlas Polymer Technology, PO Box 2080, Edithvale, VIC 3196, Australia
5.6 STORAGE STABILITY OF PLASTIC-DERIVED DIESEL FUEL
As diesel ages a fine sediment and gum forms in the fuel brought about by the reaction
of diesel components with oxygen from the air. The fine sediment and gum will block fuel filters, leading to fuel starvation and engine failure. Frequent filter changes are then required to keep the engine operating. The gums and sediments do not burn very efficiently in the engine and can lead to carbon and soot deposits in injectors and other combustion surfaces.
Diesel fuel made from the thermal cracking of plastics is more susceptible to oxidation and polymerization than refinery-made diesel fuels. This is because plastic-derived diesel fuels generally have terminal unsaturation (i.e. double bonds) at the ends of the diesel chains as a result of the β-scission chain cleavage. Over time free radicals that form in the plastic-derived diesel fuels during storage cause the diesel chains with double bonds (α-olefins) to polymerize resulting in a sludgy sediment also known as ‘gum’.
Factors which decrease storage life of diesel:
• fuel composition, especially the presence of olefins and styrene monomer in the plastic-
derived fuel;
• exposure to high temperatures;
The ageing process can be accelerated by the following conditions:
• contact with zinc, copper or metal alloys containing them. These metals will quickly react with diesel fuel to form unstable compounds;
• exposure to dust and dirt containing trace elements, that can destabilize the fuel (such as copper and zinc).
The expected life of a diesel fuel is indicated by the oxidation stability test (ASTM D-2276). The test measures how much gum and sediment will be deposited after conditioning the fuel at 120◦C in the presence of oxygen for 16 h. It roughly corresponds to a years storage at 25◦C. A result of less than 20 mg/L of sediment and gum after the test is considered acceptable for normal diesel.
In order to improve the stability of synthetic diesels and biodiesels it is necessary to add free-radical trapping additives known as antioxidants (such as DTBHQ, IONOX-220, Vulkanox ZKF, Vulkanox BKF, and Baynox). Butylated hydroxy toluene (BHT) in particular prevents oxidation and radical polymerization reactions that can lead to diesel fuel ageing.
The nominal antioxidant concentration required to give diesel fuel an extended storage stability and suppress polymerization, is 1000 ppm (i.e. 1000 mg/kg).
HSD Stabilizer (Diesel Stabilizer) additive is a multicomponent, oil soluble formulation, specially designed to maintain the total sediments level in diesel fuel within the specified limits, as per ISO 1460:1995. The additive will ensure that the diesel does not deteriorate on storage and the fuel system is protected from deposit formation and corrosion. The additive consists of three major components, namely:Antioxidant. Fuel oils are subject to deterioration due to oxidation and this occurs both during storage and in service. Oxidation gives rise to formation of gums and sludge.
Olefinic compounds produced by cracking are more susceptible to oxidation. Gum is the product of a series of oxidation and polymerization reactions. Antioxidants function by combining with peroxide free radicals and by decomposing hydroperoxides into stable substances. The antioxidants used in the additive are a combination of sterically hindered phenol-type antioxidants.
Detergent. The detergent and dispersant, keeps oil insoluble combustion products in
suspension and also prevents resinous-like oxidation products from agglomerating into COMMERCIAL PYROLYSIS PROCESSES 403
solid particles. Thus they prevent formation of deposits on metal surfaces, oil thickening and sludge deposition. The component used is ethoxylated products of alkyl phenols.
Metal deactivator. Metal deactivator prevents precipitation of metal ion oxidation reactions and precipitation of insoluble metal compounds. Metal deactivator in combination with other antioxidants, shows strong synergistic effects. Oxygen and moisture present,
diffuse through oil film and cause corrosion. Amine derivative, used in the additive has good water-displacing properties. They impede sludge formulation, disperse sediments and reduce corrosion in various fuel systems.
I would like to hear community experiences about the above article.
CARBOGGER says fuel without any additive even after one years storage was still running the engines well ...
