  • Originally posted by dedooo View Post
    Dear Mr. Beyond Biodiesel Thank you for your interest, but is it reasonable to use the retort area of ​​100 liters to put inside an empty 10 kg of plastic to produce 10 liters of fuel? And what about you How much space you have and how much the reactor put inside plastic? Wait for your reply eagerly repeat my thanks to you, but Google translation
    Correct, theoretically it takes 100L of plastic to make 10L of cracked hydrocarbon liquid.
    My largest retort is only about 40L, but I am working with WMO, not plastics for now. When I move to plastics I plan to build a 220L retort.
    Originally posted by fox32 View Post
    From what i understand i reckon you want to know how much free space it reamains? If this is the case, you have to leave at least a quarter (1/4) from your reactor free, to avoid any boil over. You cannot fill it up entirely. Hope this helps.
    fox32 is correct, dedooo, so if your reflux is going to simply be the upper 1/4 of your retort, then you will need 125L retort with 100L of shredded plastics to crack into 10L of liquid hydrocarbons. However, if you have a separate reflux , then you need not do that.
    Originally posted by Col View Post
    In relation to the flame arrestor - does anyone think there would be a problem if the diameter of the pipe stuffed with steel wool was larger than required by the system? I want to build the system downstream from the retort oversized so that I can simply swap out the retort but keep the rest when I am ready to upscale. I think an oversized flame arrestor will let oxygen / air pass back up to the pipe to the bubbler but it would stop there so I can't see it being a problem in a normal operational scenario. But if the flame travelled back to the steel wool, and there was a lot of steel wool in a large diameter pipe I wonder if the flame could still maintain enough velocity to pass through the steel wool. Or perhaps a lot of steel wool is even better because the heat quench will be better. I think I'll submerge my flame arrestor in water just to be sure (not the end, just the middle part). I want to have 100mm diameter pipes running from the retort to the last condenser, then 50mm steel pipes from the bubbler to the flame arrestor. But at first the system might only need a 20mm flame arrestor. Any thoughts?
    Col
    I see no problem with enlarging the section after the retort, then replacing the retort later with an upgrade, as long as the enlarged pipe sections are no more than 4x the diameter of the retort exhaust section, otherwise you could end up with a non-positive pressure situation that could bring in air, but your bubble still functions as a barrier to oxygen.
    Presumably you have some kind of flame at the exhaust exit that will burn flammables? There is an advantage here in using a flame on the retort for heat, so that you can direct the exhaust gasses there to consume them, and reduce your need for additional fuel to run you retort.
    I have been running various blends of waste oils and unleaded gasoline in a 1983 Chevy G-20 van with a 6.2L diesel V-8 engine, with a Stanadyne Rotary DB2 IP since Feb, 2007. I have started the engine with no difficulty and no block heater on an 80/20 (WVO/gas) blend down to 0F (-18c). I have found that by blending as little as 15% gasoline in the summer, and as much as 50% in the winter, my engine starts and runs as if it was running on diesel fuel.
    • Originally posted by Col View Post
      Col
      Complex subject. Has been a while since I read up on it. Flame propagation speed is a known issue. One link below had a calculation re pipe size vs distance. Keep the arrestor cool. Obviously we are already excluding oxygen. Some saved links on the subject. Hope it helps:
      Kemp PDF
      About Flame Arrestors and Detonation Arrestors
      Flame arresters certified to EN ISO 16825/12874/ATEX - Flammer GmbH
      Originally posted by peterkyjovsky View Post
      I would like to ask for measure of reaktor as I need pass them to welder man. I need diameter and hight of vessel.
      I don't recall Jetijs quoting exact dimensions so make it to suit available materials aimed at the size of reactor you want.
      http://diydiesel.blogspot.co.nz/
      • Originally posted by Excalibur View Post
        Excellent, thank you Excalibur.
        Col
        • high temperature liquid level probe
          Hi guys.
          Knowing / maintaining the liquid level in the retort is important for any continuous plant. I am considering this ceramic level sensor probe capable of withstanding 800C. Price is $250.
          DRFK-98 RF Admittance Level Switch, View fuel level switch, Dongrun Product Details from Yantai Dongrun Instrument Co., Ltd. on Alibaba.com
          Has anyone had any experience with similar level sensing probes in this or other applications where the tank is bubbling / frothing? Do they sense the level of the liquid or the level of the bubbles / froth?
          For my small retort I am thinking I'll make it from a piece of 270mm diameter vertical pipe, intersecting another horizontal piece (making a 'T'), and keep the oil level at the half full mark for the horizontal piece. 200mm vertical, 500mm long horizontal. This gives a 25L capacity retort to the half full mark on the horizontal piece. The 270mm diameter pipe will suit a high pressure LPG burner I will use initially while I iron out the bugs before converting to a larger naptha burner later. I think the half empty horizontal section should serve as an expansion vessel and 'bubble-popper', increasing the available room and surface area for any boil-over to settle down.
          I also think that even if the probes are sensitive to bubbles, the bubbles should be able to be excluded from the probe by some baffles so only the liquid is sensed. Any feedback anyone?
          Col
          • I am not sure, Col, whether the probe will work, because as you say, the bubbles might confuse it. So, if you buy one, then let us know how it goes.
            For a continuous feed system I am more inclined to keep the boiler nearly empty and just regulate the feed based upon out put, such that if the feed rate is too low then the output will be low; however, if the feed rate is too great then the output will be low again, so there will be some sweet spot in between, where the output is maximized. Finding that sweet spot will take some fiddling and close monitoring.
            • Level sensing attempts
              Yes, sounds like a good plan.
              When the retort boils dry the temperature readings of any thermocouple located in the path of vapour flow will reduce significantly, right? What readings do you get at this stage??
              If you've been getting readings of 430C during distillation/cracking and the readings drop to 200C or something when the retort is dry we could use this as the level sensor information.
              If our feedstock has been pre-heated to 120C we can fill our retort until the high level TC reads 120C. During distillation/cracking we will get readings of around 430C until all volatiles are driven off and the retort is dry, then readings will drop to 200C or whatever that dry temperature is. Then we go again.
              Is there an advantage to a continuous drip feed system over this repeated batch system? I think the repeated batch system will be easy to master, yet it does expose the retort to repeated changes in temperature which may fatigue the steel, is a 300C change in temperature over and over enough to fatigue mild steel?
              One challenge to beat on the continuous drip feed system is how to determine the high level and avoid over-filling of the retort. A retort filled to the right level, but with only the heaviest fraction remaining will still have low vapour flow rate. At least with a batch system, filling with a lower temperature feedstock means we can use a TC to tell us when the high level is reached and vapour flow rate won't confuse the issue. Though the idea of a nicely balanced drip feed system is very appealing.
              Col
                Correct
                The temperature readings go up and down based upon what fraction is boiling; however, after the 425c peak, then the temperature will continue to decline. One just has to keep an eye on the temperatures and not allow the retort temperature to drop more than 25c before admitting more feed.
                Using temperature as an indicator of a dry retort is a good idea, but you would not want it to drop that much.
                I would not do it that way. I would find a small feed rate that just keeps the retort producing distillate at a given rate.
                What you are proposing is a repeat batch system, and I think it is reasonable, until you can get the continuous drip feed system to work. As long as you have reasonable metal thickness, then metal fatigue is not likely to post an issue.
                Col
                Well, this is a probably for the repeated batch system. A drip feed system is never going to fill the retort. All it is going to do is provide a stream of feed that flashes into vapor instantly at its maximum efficiency.
                • Hi!
                  I use waste oil, with pp. I get one forte liter fuel liquid, then installation rough-hewn vibration so I stopped. The end I get so far a bit fuel in the first condenser but it was plastic granulous. In the second condenser was “clear” fuel. Now the first condenser it does be full of plastic (: Why?
                  • Hello Samot, post some pictures so we can better understand your problem. DO you have a reflux? it sounds like boil-over, but i can't be sure, some pictures will help.
                    All the best!
                    • pyrolysis oil
                      l try my pyrolysis again l have trouble with burner sometimes nozzle block. after 45 minutes of heating bubbles stops but begun the first drops after 15 minutes l find little fuel. l dont know the tempreture. l use waste oil about 30 litres.why bubbles stop and the fuel begun coming out? it is normal? l dont have catalyst.just empty reflux.fuel burn easy maybe diesel and petrol
                      • Good thoughts about retort level devices. Also continuous feed into near empty retort vs feed into liquid at a maintained level. Great food for thought!
                        My thoughts on feeding to empty retort is that very tight control of temperature and feed would be crucial. Feeding to a maintained level gives more of a buffer. Both approaches would work. I'm using the latter otherwise I'd have built the retort much smaller. For me a level indicator is a key piece. I hope to try another level indicator prototype within the next few weeks.
                        Samott, as fox32 says, it sounds as though you don't have any reflux or you had boil-over. Please post some good, clear photos so the problem can be identified.
                        Jonathan, Initial bubbling at around 100°C can be water vapor making steam. WMO can be a mixture of different oils, kero, petrol etc, each with its' their own boiling point. The lighter fractions start to boil early. If you haven't got any thermocouples, then you need to get some. Otherwise you are blind to what the reactor and reflux temperature is.
                        If your fuel ignites then it will have a volatile content. If you want stable diesel, then you need to hold it at enough temperature to evaporate the volatile off. These volatiles can be condensed in a separate condenser. Again temperature sensors on these condensers is worthwhile to refine the product.
                        • retort problem
                          thanks excalibur maybe tempreture proplem i will check my tempretures next time.are this probs good?.l meant i dont want to use blind hole.thanks
                          RTD PT100-K Temperature Sensor 2m Cable Stainless Probe 100mm 2 Wires T5 | eBay
                          • Hi!
                            I use waste oil, with pp. I get one forte liter fuel liquid, then installation rough-hewn vibration so I stopped. The end I get so far a bit fuel in the first condenser but it was plastic granulous . In the second condenser was “clear” fuel. Now the first condenser it be full of plastic (: Why?
                            Here is some picture:
                            [IMG][/IMG]
                            [IMG]
                            A képet a Képfeltöltés.hu tárolja. Képfeltöltés.hu - korlátlan ingyen tárhely képeidnek, regisztráció nélkül[/IMG]
                            The reflux column was empty.
                            • Archives
                              I have gone through all the posts up to page 110 , broken them up into 15 categories and saved them as MSWord tables as my aide memoir.
                              It’s now a big ask to get people to read all the posts from the beginning, which is not all that helpful anyway if your memory is getting as bad as mine has over the last few years.
                              Many of the early posts have lots of useful information, notably Jetijs details of his early electrically heated setup as well as the evolution of plastic pyrolysis, as recent contributions mainly involve Waste Motor Oil as a raw material, with lots on continuous feed.
                              I have seen the same questions get asked repeatedly, again and again and again, so hopefully to avoid this I would like to make the posts available to members of the forum at a nominal cost but am not sure how to approach this. I have limited download per month, so emailing is out, I don’t have a website, so all I can think of is to copy them onto DVD’s or memory sticks and post them – Australia Post is pretty good but I don’t know about others. There is also the problem of covering my expenditure, say in the region of $10-$20 and how to get it. No amount of money could repay me for the time spent on this, so it’s not a business proposition - more a labour of love, and to say thank you to all the contributors.
                              What do the moderators think of this proposal? Is it Legal?
                              Any ideas, comments, suggestions or criticisms are welcome. I can be contacted by email: tremanag@hotmail.com
                              John
                              • Originally posted by jonathan View Post
                                An RTD is not the sensor to use for the range that pyrolysis occurs. It is better to use a type K TC (thermocouple).
                                Originally posted by Samott View Post
                                Hi!
                                Thanks for the photos, they help diagnose your problems. It sounds to me like all is good, but cracking is marginal. Do you know your retort temperature? Thermal cracking occurs at 400c.
                                Are you using a catalyst? If not then if you add one, then you will get better results. If you can not buy zeolite, then just add a cup of ash to every 4L of liquid to be cracked.
