I`m glad I could be of some help. This is a great forum and you are a very valued member Excalibur, I recon that you are one of the earliest members on this discussion that is still constantly contributing valuable lessons and knowledge.
Perlite is expensive here, so I was also thinking of using vermiculite instead as it is mined in South Africa and should be relatively cheap here.
Found another interesting article by someone who builds ovens, he also recommend ash instead bound by the sodium silicate, that may even be a more inexpensive way to go for me as we use coal extensively here in South Africa and it should not be a problem to get it at cheap cost.
Vermiculite insulation. What is vermiculite, how to use it?
It seems like it can withstand a great amount of heat. I will also like to use it to insulate the other vessels and pipes and because it is pliable to form, relatively easy to mold around bends. Just make sure it is cast in a way that you can break it into two pieces that you can just tighten by some wire or other means around the pipes.
Got all the fittings yesterday for the heat exchanger to connect the water, now I only need to connect the "gas jar" and fill the insulation, cure it , sandblast all the surfaces and give it a nice paintjob (the paint is rated to 700 degrees, don`t know if that will hold on the reactor, but the other parts should not be a problem) and start up the plant for the first time.
But first I will do a pressure test for a day to see if there is any leakage on the system. Despite it being made from gas cylinders, I rather value my life and will like to live a long time afterwards.
I just hope I did a good welding job on the heat exchanger, otherwise I will have to cut that open to repair. What a pain that will be!
I actually wanted to be up and running now already, but I am so limited in the time I can work on this. All you are seeing happened in a weeks time where I work for about 2 hours in the afternoon when I get back home and two days I was off and the sun was tolerable to allow me to work outside. In the meantime all the stores and factories are closed until maybe the 10th this month.
All in all, for this machine I would recon if you can work full day, maybe 3 days and it will be finished.
I saw that in Nigeria, they even use normal oil drums to do the same, but that is just tooooo risky and many life's are lost because of it.
Even though this is old technology and there are more advanced and better ways to do this now, this is still a valid technology that can change peoples life's, as long as we care about our safety first and the safety of others around us.
