Originally posted by sunilkm153
The issues you will run into is that a lot of Polystyrene in it's expanded form makes very little Fuel. So if you do a batch, a full retort produces very little fuel. If you melt the stuff down using acetone or even Petrol, to form a goop you will see what I mean by how much can be melted into such a small amount. But if you then fill the retort with that goop, you will produce a lot more fuel. Commercially, Polystyrene is crushed down in a huge Auger and so much pressure is applied that it heats and melts the stuff into a goo which squirts out the end of the machine like toothpaste, but on a large scale. It then cools into a solid to then be processed.
At 107 Octane, it will not run so well on it's own as a Petrol. But it can be blended with Petrol and will help raise the Octane but still remain in a usable level. Or you can blend it with Diesel and have it raise the Cetane Level.
Styrene (ethyl Benzene) is the proper solvent for Polystyrene and it dissolves the stuff quickly. So once you produce some, you can melt down more solid using what you produced.
Being a very lightweight fraction, you will need to cool the Gas output well so that you capture as much condensable liquid as you can, or you will lose most of it as Vapor.
