Originally posted by cornishscrimper
Originally posted by cornishscrimper View PostIs it possible to convert most of the output into gas rather than liquid fuels ? Say with the correct catalysts etc ? Have read through cannot see a mention of it.Thinking about off grid set up and using gas (not gasoline) to run generators, gas fridges , cooking and gas water boilers etc.
The bigger issue is storing the Gas. And this is where some caution comes in. There is a range of gasses that come off. The mix varies with the process. Methane tends to be a common one.
Methane lovely ! Was thinking of taking Methane from a Bio- digester too. As for storage gas bags as opposed too cylinders. At least a gas bag will just flair and not send shrapnel everywhere. l wonder what the free cubic metres of gas (at atmospheric pressure) would be produced from a Kilo of plastic ? I guess the specific energy would be the same also ?
Pressure relief valve
Hi Guys
What is the best mechanism to relieve pressure from the retort in an emergency?
A spring loaded pressure relief valve seems to be the best as it relieves the pressurised gas then snaps shut while there is still some pressure in the retort which means there is no chance for air to enter the retort while the valve is open, avoiding an oxygen-fuel mixture leading to an explosion.
I am looking for a stainless steel pressure relief valve, hopefully not too expensive. I want to avoid any brass/bronze/copper in the retort.
I was wondering if some other mechanism could be used - perhaps a column of heavy oil generating the pressure (far enough away from the main heat of the retort so it doesn't distill away). If retort pressure spikes, the excess pressure pushes the oil column up into a mushroom-plate/splash plate/perforated plate/scrubs within a compartment larger than the volume of oil used which allows the pressurised gas to bypass the oil and the oil to fall back down into the column re-creating the 'plug'. The oil-plug should be back in place while there is still pressure in the retort, similar to the spring-loaded pressure relief valves.
This could be used as a pressure relief valve but it is also susceptible to vacuum pulling air into the retort during shut-down. Anyone know what level of vacuum can be expected at shut down if not managed with purge gas?
Thoughts?
ColLast edited by Col; 12-30-2016, 10:45 AM.
I never fitted a relief valves to any of my prototype but I did seriously consider the pros and cons.
I recall an incident where a relief valve was fitted on a plant cracking plastic. It may have taken several runs but the valve was discovered to be plugged with solid plastic. Possibly vapor was continually condensing on the valve gradually building up reconstituted plastic.
The thought of a column of oil acting as a valve is an interesting idea. It would need to exceed the backpressure of any bubbler (if so fitted). Perhaps with a bit of thought it could be double acting, a relief for over pressure and vacuum for a cooling retort.
More a bit later as I recall the thoughts..
More thoughts..
Placement of the relief valve is something to consider. If placed on/near the retort vessel, the additional piping will behave as extra reflux capacity. Similarly if it runs off the reflux. It will be like having a larger reflux and possibly it will be cooler than the reflux vessel itself.
Positioning it downstream of the reflux has the benefit of not interfering with the reflux function. A downside to this location is if a blockage occurred upstream then the relief valve would have nothing to release.
Give some thought to the autoignition point of the vapor. For example diesel with ignite above 210°C if sufficient oxygen is added even without an ignition source. The oil column idea may cool the vapor enough but it's still highly flammable if it happens to "find" an ignition source.
Hope this helps. Be great to hear how you get on.
Thoughts?
Col
Pressure / Vacuum Relief
Great. Thanks for the input guys.
I have a large pressure gauge plumbed directly from the retort via a pipe-in-pipe jacketed cooler (maybe 1500mm long, been a while since I looked at it) as the gauge is not rated to 500 C. The smallest vapour pipe I have on the system (before a relief port made from a bath plug in the top of the bubbler) is 1 1/2" (2" pipes all the way to the chilled condensing tank). I will be experimenting with oil. So, big pipes, no plastic at this stage so no blockages expected for quite a while. Will need to check pipes later of course.
I'll give both the spring loaded relief valve and the oil column a miss and just rely on the bath plug. It is a long way down stream in the system but with 2" pipes all the way to that point I think I am safe from blockages using oil feed stock.
Am just putting together a pre-heating tank and centrifuge at the moment to get rid of the water and most of the suspended solids before feeding it to the reactor. I don't want to have to clean out that reactor very often as the design I have used is not very clean-out friendly. The commercial system I saw just filtered the oil through probably a 500 micron strainer then boiled / cracked it from there in a batching system so water content in the feed stock didn't matter. He only ended up with maybe 1 x IBC of dry carbon waste after his first 100,000L of feed oil. I think that is good going. But the less the better for me.
Col
Col
Good on you for trying things.
I hope the preheat/centrufuge experiment works well. I can see the motivation for wanting to reduce carbon buildup. That's horrible stuff and a real dirty job.
After initially struggling with suspended water I started preheating the feedstock to 110°C+ and held it for sufficient time to drive water off. My strainer was about 100 - 200µ though the oil was pre-settled so that takes care of much of the sediment.
Depending on how much preheat you use, there may be some steam evaporation. Perhaps a way of water vapor removal would save it recondensing and dripping back into the feedstock. The worry is, can you achieve water removal and satisfactory solids removal on a single pass? Of course you can slow the feed down to the to the centrifuge but to go slower than the reactor wants to process it, slows down the whole system. It will be interesting..
rozier56
Happy new year to all.
Excalibur, you mentioned previously that you monitored your liquid levels in the retort and the gas phase.How and were have you installed the temp probe in the retort?
In my case i am unsure as when melting plastics we end each burn with ash drop out.If the probe is not at the retort bottom you might get incorrect readings as the plastic vaporizes.My burners heat the retort at the base.This means the melt at the beginning will have different temp between top and bottom of the load.The probe must be encased inside a steel protective sleve?
Yes, best wishes to one and all.
My retort probe is pictured on my Blog side-page titled:
Test equipment, sampling, additives, instrumentation #7
It screws into the top flange.
I goes down to perhaps 50mm from bottom of retort.
Yes, there's quite a difference in temperatures between top and bottom of retort but then mine is very tall and skinny.
draining of fuels from various condensing tanks
Hi crew
It just occurred to me, how do we know when to drain fuels from the various condensing tanks? We need to drain fuel before the condensing tank(s) fills up and overflows to the next one but we don't want to drain the tank before the liquid seal created by the 'U' bend in the drain pipe is in effect or air will enter the system.
I suppose we do a batch and let it cool down to the temperature that air ingress to the condensing tanks is not a problem then open the drain. If no fuel drains out then we know the liquid seal may not be deep enough yet. If fuel does drain out then we know the liquid seal is in effect and we know we can drain fuel from that tank during processing.
Other than this I guess we would need to install sight glasses in each condensing tank.
Col
Col
My thoughts..
Sight glasses or sight tubes are the way to go. My diesel condenser tank has a simple clear tube with a ball valve on either end. By default and for safety the lower valve is always closed, opening it to take a reading. The tank is large and would need a particularly good run to fill it within a day session. There is no u-bend.
I've never considering air ingressing in a problem because my system runs a slight positive pressure from the bubbler and gas-jar. As soon as any drain valve, etc is open, liquid or vapor comes out so I don't think air can get in against that flow. Even if it got in, it still can't go upstream against vapor flow.
The petrol condenser has no site glass or u-bend. I drain every so often, perhaps hourly.
