Hi bugler
The dimensions of the reactor container does not really matter, it is like boiling water, if sufficient heat is applied to the container, it will boil the water no matter how tall or wide the container is. I would suggest using something like a propane tank, like this:
The metal cage is not where the plastic goes, it just prevents the reactor tank touching the bricks and coils. The plastic goes in the modified propane tank and this tank then is fitted inside the cage. The cage is a bit smaller in siameter than the brick cylinder so that there is about 1-2cm of space between the cage and the bricks. In my case the internal diameter of the brick ring is around 34cm, but that will vary depending on the reactor container size. I would suggest first to get a 20-25 liter container, something with thicker walls would be preferable. then you measure its diameter and make a cage inside which the container fits nicely and firmly and then you measure the outer diameter of the cage, add several centimeters for the gap between cage and bricks and you will have the needed diameter for the brick ring. Then you just see what size bricks you have available at your local kiln shop and calcilate how much you will need for a ring and at what angle the sides need to be cut for a ring shape when assembled. At the moment I can't tahe more detailed pictures because the reactor is at my friends house and he lives several hunderd kilemeters from me.
I can't show you the insides of the condensing containers as they are welded shut and only have an inlet pipe and an outlet pipe, but there is nothing fancy in them, just a metal reservoir that cools the vapors coming out of the reactor, thats all. I will draw a better schematic later.
The shredded plastic looks like this:
http://www.emuprim.lv/jetijs/plog-co...lastic-002.jpg
but might also be more white or gray in color. The main thing is that the plastic should be polyethylene or polypropylene and NOT polyvinylchlordide (PVC).
I can't post more pictures of the lid, but I will make a 3d cad drawings tomorrow.
Hope this helps, will post more later
