Originally posted by VAST
I studied the gas storage topic (aka gas jar) extensively before deciding to go with the setup that works on a "displaced water principle". I also looked at compressing surplus gas into a cylinder however I didn't move ahead with that as my current setup worked well enough for my needs.
Firstly I recalled the floating drum idea that was common on biodigesters and I proceeded to look for suitable vessels. Failing to find a pair of vessels that fitted each other, was big enough and affordable enough forced a rethink.
Then I decided to use old tractor tire tubes, ganging them up perhaps in a stack. This also proved a problem with the lack of redundant tubes being available. A similar plan to use an old (10yo) waterbed bladder failed because the plastic had deteriorated.
Finally I hatched a plan to store the off gas by displacing water. I realized I could use any sized vessels by ganging them up. I started by using steel drums but it soon became apparent that rust was going to make their lifespan too short. About this time I acquired for free some plastic 200L drums and 400L stainless bunds. This setup can be seen on one of my DIYDiesel blog pages called "Gas jar and cylinder, Orion3". Also one of my Youtube videos features a short clip of it.
Should you research gasjar/gas storage with Mr.Google, be sure to add the terms floating drum, biogas storage, biodigester, gas jar, etc
HTH.
BTW, smart thinking to plan ahead with regard to reusing parts of the plant in later upgrades. My current plant is iteration #6 and it still uses a couple parts from as far back as iteration #2.
