islander,
that`s why refineries have huge cyclones - to remove carbon particles from the stream. My reflux gets always nearly blocked at the end of the process, which is absolutely normal. I`ve got just a simple swirl tube in it which removes just a portion of particles from the stream. Small amount gets deposited in the condenser and the rest flows with the condensed fuel. I`ve noticed that for every 25l of fuel I regularly get about 1l of junk strait from the condenser. Luckily it is heavier than fuel and sits on the bottom of canister. So, that junk is black soot which can`t be mixed with the fuel and that`s why I get clear output.
Regarding your injectors - I don`t know why I`m not surprised and why it sounds so familiar
Centrifuge is a mast in this business, but it is not enough. You have to pass the fuel through 1micron filter as well. I`ve tried centrifuge alone and filter alone. You get good results only if you combine the two.
For your injectors - feel free to use double dosage of Valvoline or WURTH injector cleaner (or if there is anything better). A bit of paint thinner in the fuel will be very helpful as well but it depends on your car`s fuel lines as the thinner will corrode rubber and some sorts of plastic. Good luck
