Hi Asad.
My recent tests show that it is very well possible to get clear light yellow green fuel from PE on the first run. To do this you need dried clay pieces in the refluctor chamber so that the vapors pass through it. This way I got great results on the first try, no waxes, just clear fuel. The lower the temperature of the reactor, the lighter the color of the fuel. If the temperature is too high, many of the heavy fractions pass through the refluctor, turning the fuel more yellow and darker with the tendency to darken a bit after a while and some wax sediments collecting on the bottorm. But still, this is a very neat method of dealing with waxes. Here are the results:
Depending on the temperature you get different colors and fraction ranges. The smaller the temperature the lighter the fuel. Almost no filtering is needed, comes out very clear. The one on the right was done at 420 degrees, the middle one at 400 degrees and the left one with 380 degrees. I can go as low as 330 degrees with good results, but the process becomes longer. Also the lighter the color, the more light fractions are inside, I determinated this by freezing all three samples. After 1 hour in the fridge the right one was already completely solid like wax. The middle one just a bit misty, the left one still clear. And over night, the middle one turned into kinda liquid souce, but the left one still clear and bright with no signs of waxing.
I have tried blue clay and red clay in the refluctor, both work very well.
Hope this helps.
Hope this helps.
