Welcome, dedooo. It looks like you have a proper flange on the top of your retort, and your gas burner setup looks well done as well. What did you do for insulation? It looks like mud, or something liquide, and poured in then set?
Cleaning out the retort can be a real problem, so a flange top and bottom can help, so that you can scrape from the top, and debris can fall through the bottom flange.
Another option for cleaning out the retort after your cracking run is, if you are absolutely sure that your retort has fully cracked and extracted all of the liquid hydrocarbons, so that there is only coking remaining, then you can introduce air into your retort, by cracking open a valve and carefully watching the retort temperature. The temperature should rise to 1200F (650c) as the carbon burns. You can keep adding air, while carefully watching the temperature, and keeping it at 1200F (650c).
NOTE:
At this time you will want to valve off your retort to your fractionation column, and vent it directly out.
At this point you can turn off the heat, because the coke will keep the retort hot until all of the coke is burned off. When all of the coke is burned, then the temperature of your retort will start to drop significantly. When all of the coke is burned you will just have ash to remove. That ash can be used as catalyst for the next run.
The activity of the animal beings has become acutely active everywhere on this earth. Bodies do not get time to booty a blow for a while. With the accretion use of altered gadgets of Gps Jammer, the possibilities of accepting the aboriginal of blow accept absolutely finished. The adaptable phones or the corpuscle phones are some of these accessories that accumulate the bodies consistently in blow with the alfresco world. The adaptable building are additionally accessible about everywhere these canicule and due to this the accessibility of the signal jammers for sale has become alike added quick and authentic. Today, you cannot break out of ability of these adaptable building as their signals can bolt your about anywhere. The bearings of bodies who accord to altered business professions has become actual analytical of wifi jammer as their authorities bolt them anywhere any moment.Last edited by AlicaReik; 04-23-2014, 03:04 AM.
insulation
thanks beyond biodiesel great home made insulation keep it up
Originally posted by Excalibur View PostJonathan, BB has touched on a very cheap, affordable solution for your needs. DIY refractory firebrick... Also BB has done a lot of testing of various affordable solutions. See pyrolysis section at BB website...
retort problem
woww soo thanks l will google it and check bb website thanks all
I suggest to Google the topic: How to make refractory brick, Homemade Castable Refractories, DIY fireclay, etc. Also BB has done a lot of testing of various affordable solutions. See pyrolysis section at BB website.
Two types of firebrick for consideration is the dense firebrick and the porous firebrick. The dense one is known for being a storage of heat while the porous lightweight one will be an insulator and not store heat well at all.
Porous firebrick can be made by adding organic or combustible material to the brick recipe which burns out during firing. This makes for thousands of tiny air pockets throughout the brick.
Hope this helps.
pyrolysis fuel types
thanks all of you l work on my burner today l have bigger flame now.some more work and try again thanks alot
Originally posted by jonathan View Postthanks excalibur and beyond biodiesel my proplem is that in malta is dificult to find insulation and when l find its very expensive l will try waste oil maybe its more easy then plastic to heat it to 425Originally posted by jonathan View Postthanks its a good idea to find insulation from ovens but l need a lot. my pyrolysis take about 40 litres of oil. to fill about 3/4 of it l will try about 25 litres.l find on ehow that if you heat waste oil to 60 degrees you have petrol distillate.is this true? everyone say 425 to crack plastic or waste oil thanks
Note on insulation:
Adobe makes a perfectly useful high temperature insulation. Also, volcanic ash works very well also as good high temperature insulation.
Really, it's not that simple. A mixture of two different hydrocarbon fuels/oils will start boiling at a temperature somewhere between the boiling points of the two components, depending on their relative proportions in the mixture.
A quantity of waste oil should always be considered to have a variety of different components. It depends on what is thrown into the oil dumpster.
My retort has started producing fuel long before even 400°C. As I've said before, as much attention should be paid to the bubbler activity and sight glass drip rate as to the retort temperature.
How to Distill Used Motor Oil for Diesel Fuel | eHow
Originally posted by dedooo View PostPlease help, reactor his 30-liter gas cylinder Propane old around insulator wool thermal, and placed inside the 5 kg plastic, but the stove was a torch Propane, after an hour it seemed diesel drip for an hour, then slow down very, toll 3 liters of diesel, I am not satisfied with the the result because the output is very small, Is there a way to increase the output per hour, thank you
