retort
thanks a lot excalibur for this sharing very important.l having proplems but l am 100% sure l have tempreture proplem my retort is 24 inch heght and 12.5 wide as i say before l find plastic doesnt melt well after 1hour 30 minutes. l will try with insulation
jonathan, sorry you're having problems. Good insulation can make a big difference to efficiency. We need good economics for heat especially where energy is expensive. I started thinking about how much heat was required to distill hydrocarbons. I searched out a report from mid 90's.
Conventional atmospheric and vacuum crude distillation units require about 100,000 BTUs (British Thermal Units)of furnace energy per barrel processed. Since a barrel of oil contains about 6,200,000 BTU's, the required furnace energy amounts to about 1.6 percent of the processed oil.
One oil barrel= 42 US gallons, which is about 159 liters or 35 imperial gallons.
So therefore, 100,000 BTU or 29.3Kw per barrel.
Naturally, the figures are from some very efficient refinery plants where oil companies have been developing their processes over decades. Just how close to that 1.6% us DIY can get will be interesting.
retort
l try my pyrolysis system again after 1 hour and 30 minutes no gas come out from my system so l stop my system after it cools down l find about 300ml of yellow fuel and l light it and burn. l open my retort and find my plastic didnt melt well. my conclusion is it is very important to use insulation. l will try it with insulation
Originally posted by dedooo View PostOutcome after an hour and a half, diesel Excellent http://im63.gulfup.com/i9e2ri.jpg
Outcome after an hour and a half, diesel Excellent http://im63.gulfup.com/i9e2ri.jpgLast edited by dedooo; 04-02-2014, 09:11 PM.
Originally posted by dedooo View PostHello all, Mr. excalibu, I've pyrolysis process for waste oil used within the reactor, the result is a net oil smelly very pungent and color tends to Green, Is there any advice about it, thanks
I think the odor is hydrogen sulfide (H2S)
If it's H2S then Wiki has some good clues as to how to deal with it.
H2S is soluble in water. Could agitating the diesel with water reduce the smell??
H2S has a boiling point of -60*C. I believe the smell does reduce with some time exposed to atmosphere.
Otherwise there's some good reading on the subject The book refers to the smell as mercaptans.
Edit: I was just talking about this subject today with a friend. He said the Shell book quoted trickling across limestone as one method for smell removal?? Sorry I must read the book again when I get time.Last edited by Excalibur; 04-02-2014, 09:50 AM.
Originally posted by fox32 View PostVery nice design and very helpfull, i built a simmilar one, it is not ready yet, i will put some pictures soon, i see you have some nifty improvements, the Draw back arrestor is a new thing to me, it is there to prevent water to be sucked up from the bubler?
Originally posted by fox32 View PostAlso, the Flashback arrestor i had some dificulties managing to build one, since i can't find fine steel wool so i'we used some kitchen steel sponges, your design is something simmilar or you use other matterials? I was thinking a one made from a car exhaust catalyzer...!
Originally posted by fox32 View PostI see you have a heat exchanger/condenser, i was planning for my diesel trap to act as condensor , may i ask why you chose this design?
Thanks Excalibur, great work as always!
Originally posted by Chris@NL View PostIn a plastic injection moulding machine there is no oxigen at all in the barrel.
Once the plastic is melted the air is pushed out to the back.
If you had air trapped in the plastic it would give you a bad product in the mould.
A very small screw/barrel gives you up to 100 liters of plastic per hour.
These barrels are fitted on 75 tons machines.(clamp force).
The only problem with these screws is, you need a very strong motor.
Normally its driven by a hydraulic motor.
Col
FYI. Talk of LPG/propane cylinder wall thickness got me thinking, so I located a number of them which have been cut open. I measured each with an imperial micrometer. The thinnest was .085" and heaviest .125", others were in between. All were the 9kg variety except the .125" which was a 60L auto cylinder.
After numerous requests for schematic diagrams, I have initiated a series of them using Open Office Draw. The 1st is an overview of my plant while the 2nd is the turk burner head. Others are being considered. There is a new, dedicated page on my DIY Diesel blog Orion Schematic Diagram Library
I hope this helps.
liquid plastic feed mechanism
Originally posted by Beyond Biodiesel View PostOver the weekend I reflected on another idea for continuous feed system based upon pneumatic pumping. A large retort with a cone shaped bottom and a wide seal-able top could be filled with your feed stock, then the lid closed, then heated to the transition temperature of the plastic feed stock. The pressure vessel is pressurized using an inert gas, such as CO2 to about 5-10 PSI. Then a lower valve is opened and the now liquid feed stock will move into the retort at whatever rate you want, and you close the valve if you want to stop the feed.
The valve would have to be able to handle the temperature of your plastic feed stock at its transition temperature.
Col
