Originally posted by crisaga
I'm working hard on machine as now i have more time on winter time, I'm upgrading and will put and 3th stage of oil processing next fire should give wanted product, corrosion was a huge problem, i was forced to dissemble heat exchanger and to rebuild heavily reflux tower, he will be tested before real test to be sure that i'm getting there 360+ temperature. for next test I will not use cyclone, and I will build new kiln around reactor, I'm not happy with efficient of this one it must be wider.
Now about your machine
I'm happy that you work hard.
In reactor your temperature must be around 420 and 450 everything bellow is not enough to crack heaver chains.if you don't have reflux tower with reflux material you do not need separator condensers as it is not possible to get fraction such diesel or gasoline, you get only heavy oil.
I will more often here, write about your project I'm very interested.
