Totoalas:
I only filled 1/2 of the coil with 28 gauge, and the other half with about 14 gauge insulated stranded copper wire. But, I would recommend to fill the whole core with the secondary, and also fill the whole core with the primary on top of the secondary. That will ensure that more than just one bulb can be connected up to this inverter. The cost of wire is minimal. Remember to put something between the gap of the two halves, or you'll see why he named it "Joule Ringer". It may still ring in any case, but to separate the two halves didn't work for me.
My meter is not working on the higher mA setting so I can't tell what the draw is.
The MJE 3055 transistor is stone cold while lighting the 65 watt Cfl on 14 volts and one amp input from a AC-DC wall adapter. But, the actual draw is unknown. I do think that this system can take more voltage/current than I'm currently giving it.
Running this from a 12v 10 watt solar panel would be ideal, as each panel can output about 600mAs, and can be bought with free delivery for about $27 now. The battery and voltage controller would be additional.
