Originally posted by rave154
Joule Ringer!
Originally posted by LaserSaber View PostYou may be right, but in my experience prior this I have never been able find the "right" circuit that could light a CFL like this. In fact I could never get a CFL to light for more than a couple seconds on one 10,000uf 10v capacitor. With this circuit I can easily light one for over 1 minute on a 10V 10,000uf cap.
can anyone else provide a circuit that keeps a CFL lit for 20 mins from just an electrolytic cap? (not even a super cap!)
I sure cant! I tried my exciter on caps and got nowhere.
Jonnydavro? Lidmotor? anyone else who manages to get things to work?......
I dunno about you Xee, but im looking forward to schematics from lasersaber. And I know, the guy just cant resist sharing
Merry Xmas and New Year to everyone!!!!
Inner resistance of supercaps
Originally posted by Jbignes5 View PostThe more you parallel the less resistance as you say. It makes perfect sense. The problem is why use super caps when the normal electrolytic caps work so well. Cost wise it makes better sense to use the normal caps.
I underlined in your text I want to answer. there are several types of supercaps manufactured for different purposes. Memory backup types has an inherent high inner resistance because the current draw demanded by modern memory chips is in the order of a few microAmper (say 3-10uA) or lower, hence the inner voltage drop of the supercap across their 50-100 OHm resistance is negligible. See such memory backup type data sheets in Page 43, at the bottom, for instance http://www.panasonic.com/industrial/...ide_052505.pdf
But other types have an inner resistance of under 0.1 Ohm or less like in case of a good rechargable battery and several hundred Amper may flow when you short the pins of a charged up supercap with a heavy wire piece.
http://www.avx.com/docs/Catalogs/bestcap.pdf
So make sure what purpose a supercap is manufactured for and choose accordingly.
rgds, Gyula
Ahhh... I see...
Still the question is cost and it seems the capability of the cheaper electrolytics are better suited to this application. Even with one cap he gets it to work but it takes three super caps to start the process. Cost wise this would make the electrolytics a better choice for this application, don't you think?
i think the main reason that super caps don't work as well for this application is the fact that they have such a high... well capacity. as you move up in capacity the ability to catch that low amperage flyback or ring is diminished. I think the super caps discharge so quickly and have such a little ability to catch that ring that it acts just like a battery in the circuit with a straight discharge, Cause super caps aren't the best at high speed operation and i would imagine even worse at charging and discharging high speed.
cost wise
Originally posted by Jbignes5 View PostStill the question is cost and it seems the capability of the cheaper electrolytics are better suited to this application. Even with one cap he gets it to work but it takes three super caps to start the process. Cost wise this would make the electrolytics a better choice for this application, don't you think?
Yes, cost wise I fully agree with you, though a supercap with high inner resistance like 75 Ohm is comparable in price to a 10000uF normal electrolytic cap, you have to buy several such supercaps and connect them in parallel to get similar performance as lasersaber showed it, this boils down to: supercap is more expensive.
Here is some 10000uF (0.01F) 6.3V normal electrolytic cap types and pricing at mouser:
Aluminum Electrolytic Capacitors - Leaded
And here is some supercap with innere resistances between 50 to 100 Ohm, 5.5V and with cap values between 0.1 to 1F:
Supercapacitors
However, supercaps in the range from 0.06F to 0.2F with comparable inner resistance to a 10000uF normal electrolytic cap are much more expensive, especially for 5.5V voltage: Supercapacitors
(Of course pricing may differ at another component seller, pro and con, tendency remains: supercaps are more expensive than electrolytic caps.)
All I wanted to communicate is that there are big differences in the inner resistances of supercaps, depending on what purpose they are manufactured for and what type you happen to have and then make performance comparison to electrolytic caps.
Respectfully
Gyula
Yup...
Supercapacitors
Respectfully
Gyula
I am wondering how Ultra caps would work in this.
Well, my understanding on this video so far has been that for lasersaber has no reason for using his present supercaps, unless he obtains a type with 0.1 Ohm or less internal resistance for 5.5V working voltage. He was unlucky to have types made for memory back up purposes, had he had just a better one I showed in the earlier mouser link, he would not have concluded his finding a much less working time with supercap as bizarr. With a 0.1 Ohm or better inner resistance supercap his circuit can surely work much longer than with the 8 electrolytic caps now (provided this supercap had a capacitance of say 0.47F or higher at 5.5V).
Originally posted by gyula View PostWell, my understanding on this video so far has been that for lasersaber has no reason for using his present supercaps, unless he obtains a type with 0.1 Ohm or less internal resistance for 5.5V working voltage. He was unlucky to have types made for memory back up purposes, had he had just a better one I showed in the earlier mouser link, he would not have concluded his finding a much less working time with supercap as bizarr. With a 0.1 Ohm or better inner resistance supercap his circuit can surely work much longer than with the 8 electrolytic caps now (provided this supercap had a capacitance of say 0.47F or higher at 5.5V).
Baby steps... I guess... Dang Laser when you gonna show us something to replicate.. I'm burning to do this...
I also go myself a 1.5 watt fluorescent light to mess with in the meantime. It's so tiny..
I have now been able to make successful replications of my Joule Ringer circuit! I reduced everything to the minimum number of parts needed. I found out the the number 2 coil can be an air core coil. I will post a DIY video with lots of new details and schematic later tonight after I get back from Church.Attached Files
Sweet!
Originally posted by LaserSaber View PostI have now been able to make successful replications of my Joule Ringer circuit! I reduced everything to the minimum number of parts needed. I found out the the number 2 coil can be an air core coil. I will post a DIY video with lots of new details and schematic later tonight after I get back from Church.
I spent many fruitless hours last night trying to get a capacitor to keep a CFL lit for more than a second on my exciter, but no luck. This is a really exciting development and i congratulate and thank you for letting us all know about it.
happy new year!
@ Lasersaber:
Have you tried to use Leds with this circuit, as it would seam more practical and more efficient than using the gutted CFL? And, do you think that a modified Joule Thief circuit can be made to work instead of the coil set up that you have?
I can see similar result when using the parts mentioned above, connected to a 10 capacitor Captret. Without the Jt in the circuit the Leds light for only a couple of seconds, (without a battery), with the Jt it last a few seconds longer, but still not like your set up. It does show some similarities, just doesn't have much run time.
I've seen that in your video you are tapping the batteries to the circuit, several times during the short video. If the device lasts for as long as 40 minutes, or longer, why is this necessary, or is it?
Thank you for showing your new circuit. It looks great. We are all waiting to replicate it...
Thanks again,
NickZ
