Xee joulthief inverter with relay coil
Hi.I had a go at Xee's Joulethief/inverter today and I did not have the right transformer but I did have a twin 120v input,twin 12v output one which is quite easy to convert into a joulethief by just connecting the two inner pins on primary and secondary so i tried that and it worked but the output was not too high,probably due to the turn ratio of my transformer so I tried a trick which introvertebrate and myself have tried on Bedini motors which is the addition of a small relay coil to the base circuit and that changed everything.The first thing that happened was the output increased significantly.The additional bonus is that 2 more sources of HV appear across collector emitter and also the relay coil.Both of which could be used for lighting or charging.
The circuit will light cfl bulbs quite nicely and i hope to get hold of some LED bulbs which I think are the best form of lighting for this circuit,judgeing from results posted here.
I also tried running a mains powered radio which is 240v in the UK and it worked quite nicely so I will try and find a 5 pin transformer next and see if output increases.
Here is a circuit diagram and vid.Thanks Xee .Jonny.
Xee2 Joulethief inverter with relay coil - YouTube
