Joule Ringer!
  • Hi folks, Hi patrick, thanks for sharing your latest video, showing that 7AH charging 500AH or so to a good level.
    Do you know the amp draw on that solid state charger when you have it tuned?
    Also, when you were trying to charge that 12volt-7AH, it was only getting a current flow between the two banks when there was a voltage differential, so it probably stopped charging it much after awhile.
    I would suggest using the solid state charger to charge up the 7Ah from the large bank.
    I tested my (french) flip flop inverter as a radiant charger after watching your video and it works real well also, with a diode off each coil.
    Though more tests will tell if it performs as well as what yours seem to be showing us.
    As far as the naming thing, were all one family and ultimately on the same team, so any creativity shared by others from whatever so called time they existed is for all to share freely.
    One can not own ideas anymore than I can own the space we exist within. Names are useful to keep track of things, though it can become a distraction to our progress and creativity.
    The substance inside is what is valuable, not the label.
    I look forward to more of your results and I hope to offer some as well.
    peace love light
    tyson
    • Magnetic Joule Ringer 281111
      MAGNETIC JOULE RINGER 281111 - YouTube
      The magnet ring limits the in current but brightens the output
      2 ckt 10 series led bulbs live plus xfmr body ground.
      1 ckt 8 led lamps xfmer body ground plus collector output
      60 to 120 ma
      cheers
      totoalas
      • Originally posted by jonnydavro View Post
        Hi.Just an update on the Xee transformer Jouleringer configuration that i stumbled onto last night doing tests for Xee.
        What is happening was the voltmeter was draining some voltage of the cap bringing it below supply voltage and the circuit could fire up so I replaced the paralled volt meter with 4m ohm resistance and this had the same effect with the added bonus of being able to vary the current draw from 100uA up to whatever you want.
        This test was done using 16v and the base capasitor was marked 334k ,0.33uf but i think a 10m pot would be ideal..
        Here is a quick vid of the test.Jonny.
        Xee2 Transformer Jouleringer - YouTube
        Very interesting. Thanks for the video.
          peace love light
          tyson
          Hi Tyson,
          in my first year of experimenting with the SSG I went through about 5 multimeters because of that spike - so I stopped measuring amp draw from the primary and amps to the charge battery. It works fine on little builds, but once you get enough wire and transistors, they always get damaged and act like they are working but give out false readings - only to be learned once I have fooled myself a few times
          Thanks for the insight on the charging back of the 7Ah. I also share your same outlook on ownership. it's too bad codification and the gold-rush mentality brings about the other stuff.
          patrick
          • Originally posted by totoalas View Post
            Patrick PEACE LOVE LIGHT as SKYWATCHER ALWAYS SAY
            I was once reminded calling Slayer a SEC or a SEC Slayer
            Anyway were going in the microamps and I dont want to miss the boat lol
            My dodoshlodo jt charger can handle the 7aH 12 v battery but yours is a leap further in real time...... CIRCUIT PLEASE IF YOU DONT MIND
            CHEERS
            totoalas
            must have been a hickup or some sort of reboot on the EF hosting server, thought I was being blocked out for a few minutes there.
            anyway -
            this is basically JB's solid state SSG, it is in his most recent patent User blackchisel97 has a schematic here:
            watch?v=f7bH-vdrCjc&feature=mf*u_in_order&list=UL
            I left out the CB diodes and used neons, I used 1n914's EB, and mje13007/9's(?)
            then added the cap across the pot and the diode to the base
            I think I have some decent closeup's in this vid -
            Joule Thief type battery charger - solid state energizer - YouTube
            even w/ all these changes it's still JB's and Tesla's work.
            • JB's and Tesla's work JB's solid state SSG
              anyway -
              Hi Minoly,
              thanks
              totoalas
              Uploaded with ImageShack.us
              • Hello All,
                I have been studying this neat little device and have made a few replicas. However I am still having trouble understanding its purpose. It seems to be just a home built efficient HV generator / CFL driver?
                I made countless JTs and Fugi mods that do pretty much the same thing. I almost fill a bit dumb asking what the goal is because I am sure I have missed something.
                I can run a 120v LED bulb from a 100 watt inverter with a 12v 7amp SLA battery for a very long time at full brightness.
                Can one of you kind folk please explain this to me in really simple terms
                -Altrez
                • When using a base inductor the capacitor is no longer needed. The use of just a resistor and inductor seems to work best for me.
                  video >>> Joule thief with 120 VAC LED bulb - part 5 - YouTube
                  • Originally posted by xee2 View Post
                    you can also make that a tunable inductor by winding your own coil and using move-able ferrite or rods inside the coil.
                    • Firstly, I wanna thank Xee for making such clear diagrams - its a real treat to have them just come up nice and clear on the page, and makes it real easy to try other peoples mods. I'll be trying those microhenry inductors in a few minutes.
                      The extra diode on the base of the transistor has certainly improved the setup. I can now light my 72W CFL on less than 200 microamps (5V from charger). Check it out!
                      Flyback ringer - 72W CFL on 200 microamps - YouTube
                      I wanna get it down to working with the 1AA (no charger), and then hook it up to an earth battery - CFL running on metal in garden sounds like fun.
                      • Originally posted by altrez View Post
                        Hello All,
                        -Altrez
                        For me, I try to build over efficient generators. lol I build, then I think about it, finding loop holes and argument/counter argument on why certain works like that. I check back with the book, do some predictions, experiment to see if I predict right, then think again, do revision and the cycle repeats. It's hard to find OU on the plate, but anomaly is not so hard. From anomaly, we keep grinding it to find a whole new world.
                        Right now I'm testing one of my own theory by having this circuit charging high impedance loads (several batteries in series). I really want to know if we can model an inductor's core as a pendulum. Really interesting.
                        • My goal is to power all the house lights....and then everything else.....on simple low power systems that are fed by earth batteries, solar cells, and anything else that looks promising and will save me cash on my elecy bill. And Im hoping Ill have a good time to boot, as well as understand the world around me just that little bit better.
                          The base diode KILLS any ringing effect. The microhenry inductor works fine in this position.
                          • Originally posted by seth View Post
                            Thanks, now I have to learn how to spell
                            • Hi folks, Hi patrick, thanks for the reply. The catch (trap) is, codification only applies to the fictitious PERSON they like to claim we all are.
                              Here is the radiant charger flip flop circuit I've been messing with, it works well so far.
                              peace love light
                              tyson
                              edit: oh patrick, could you maybe apply a regular load to that 7AH and connect meter so it loads it down to similar level, just to know a ballpark amperage, thanks.
                              • Originally posted by quantumuppercut View Post
                                quantumuppercut,
                                Thank sounds cool. Thank you for sharing that.
                                -Altrez
