Joule Ringer!
  • 12 120 volt LED'S.
    @Xee2,
    The French Inverter circuit behaves a bit differently then the base tank inverter. Both circuits light a 15 watt flourescent bulb, with the addition of a 12 volt relay coil on yours. Full brightness on the 120 volt LED'S, the inverter runs a little cooler. The battery voltage drops while the amperage remains constant when additional bulbs are added to both circuits. No free lunch! The inverter has the added advantage of chargeing my laptop battery. Both circuits are really neat. Now we have all the possible RC. LR annd LC base tank combinations tested out.
    • Originally posted by Allen Burgess View Post
      @Xee2,
      Thanks for the update. Do the existing bulbs have the same brightness when additional bulbs are added in series?
      • Revised results:
        1.5V 45mA and the xenon and 21W CFL run nicely
        I.5V 90mA and the 72W runs dimly.
        With a 9V battery the 72W will still draw just 90mA, but it lights up the room fairly well. 12V and 200mA and its what looks like full brightness (but isnt )
        Sorry again for the over-zealous measuring. I think i need a day off tomorrow....
        • LEDS in series.
          Xee2,
          I'll have to retrofit and gear up for that experiment. That's on the top of my list.
          • Originally posted by seth View Post
            Revised results:
            Hi Seth
            thats when i start catching up with you guys lol
            graveyard shift i n a hotel need some comfort zone and this forum is one of them happy experimenting
            totoalas
            • External triggering using 60Hz grid signal
              @All
              I have been working with another way to trigger the circuits----using a free signal from the grid. Basically you use the same Xee2 transistor and transformer arrangement but you set up a Darlington arrangement with three transistors. Two 2N2222s and the MJE13007 at the end. Doing this allows for a very faint signal to trigger the whole circuit. A clip lead attached to the base of the first 2N2222 with the other end of the clip lead just wrapped twice around any cord coming out of a mains wall socket does it. This takes the place of the trigger coil in the JT circuit. The circuit then fires at only 60Hz and saves power. You can also then use any four wire 12v transformer and it will run. On the five wire Radio Shack transformer just use the first two wires of the primary. Just something new and fun to try out.
              @Minoly
              Thanks for the link to the "Connections" videos. I have only watched the first set that he did. The first one "The Trigger effect" is perhaps the most well known. You can spends days watching all those videos.
              I like the way that you have your bathroom setup with LED bulbs. It is a great step in the right direction,
              @Seth
              I wish that I had a dollar for every time that I have been fooled by a digital multimeter. I have learned to check them by using something else if it doesn't look right. Most people are using an analogue meter when there is a doubt. When I see a low amp draw the first thing that I do is fill up a big cap and see how long the circuit takes to drain it. Sometimes the meter ISN'T lying and the circuit runs and runs and runs on the big cap. That gives me big smile.
              Slider
              I am trying to get things to work off ambient EMF but so far it has been somewhat dissapointing. I am not getting anything to happen like you are. I have a great deal of 60Hz noise around but it isn't enough to really power something directly out of the air. Hooking up my earth ground does nothing. I can drag power out of the grid with an induction link but that is really cheating.
              Lidmotor
                Ditto here.
                • [QUOTE=Lidmotor;169721]@All
                  Hi Lid,
                  Think that is the missing link in my set up below ????
                  One Wire Free Energy transfer Variant 4 090711.avi - YouTube
                  will try this @ home
                  thanks,
                  totoalas
                  • @Lidmotor...the coil around a wire to trigger at 60Hz sounds cool ! Looking forward to vids.
                    I'd like to try out what that brings and also to see if that bugging thing with ambient powering can be sorted through if related. I'll dig another Ground at the other side of the house and see if my own experiments change. No point in it just being 1 freak wire and I don't want to waste anyones time if something mundane is the cause. With being no trained up electrician there could easily be something about the location of that Ground.
                    This Ground is by the side of the house, comes in through the next room window, over the top of a disconnnected arcade machine (Pole Position needing a cap kit on the monitor and to avoid the wall outlets at its side), then around the corner to my workbench. It does pass by the front of the PC tower, but when pulled forward from there, after considerations of mains leakage, the circuit still ran
                    All I know is that it seems to be a uA expansion of the common LED lighting in the hand experiment.
                    The wall adapter was something addressed for such problems..but now the outside Ground itself seems a problem ! heck, well, I want it sorted and to know what is going on. It's not tuned up with test equipment of course, so I doubt there's any ringing in tuned coils or other such exotics.
                    Worst case would be if the electromotives from the house are being tapped as a source, that actually forms a drain. If no drain, then the thoughts on reducing badly shielded emissions to redirect them to cohered energy is the aim. Spinning all that around in a 1 wire system to make use of those energies. Thanks for the thoughts and tests.
                      @All
                      @Seth
                      Lidmotor
                      Hi Lid!
                      Thanks for the sympathy - I tried changing the digital for the analogue, but I put it in the same position (only on one of the positive rails) and so it gave me the same fantastically low current draw (which is abviously due to the massive resistance of the neon in my circuit). Even though my first reaction was disappointment, at least I can say that I understand the current running round my circuit a whole lot better and I wont be making that mistake again with the multimetre!
                      The good news is, the 21W CFL will still exhibit the ''ringing effect'' on a large capacitor, and so it does light CFLs on very low currents. Also, I know from many experiments with the flyback how difficult it is to get a Xenon to work on just 1.5V input - and this circuit will do just that, so I havent given up on it.
                      I've invested a few quid in a solar charger for mobiles. It puts out 5V and has a 1300mAh battery inside. It'll light up everything on this circuit, but doesnt seem to last long - Im leaving it on charge for a couple of hours, and then I'd like to see just how long it'll run some of the lights.
                      Good Luck with the ambient guys - fascinating as always watching all the interesting vids, so keep em coming!
                      • Seth, yer in England mate, it's December, are you sure about just a couple of hours ?
                        Just joking, I hope it proves to be a good addition to experiments.
                        An alternative use of the house radiated energies may tie into your thoughts and saying that the exact working method of the energies (especially at my house) can be ascertained...I know this circuit type can fill capacitors to 20V tested, though it takes some time for anything over 10uF (around 10 minutes on a 1000uF). A regular oscillator based trigger could dump those fill ups into a rechargeable AA. The dumping circuit would be similar to the present one that auto senses wireless loads, or maybe more similar to pulse motor based methods if it could use uA. That AA then is used at night to power a ringing circuit based on the flyback work of yours.
                        After all, there's the time when asleep and all day for it to trickle charge a battery.
                        To tie in with that, here are the charging results of one AA from a few days ago:
                        1.2V 120mA Ni-MH considered 'flat'
                        Test conducted while circuit running, as per Pigeon Loft video
                        12.33 0.840V
                        12.34 1.000V
                        12.35 1.100V - slow down in charge rate noticed
                        12.37 1.125V
                        12.48 1.185V
                        12.53 1.194V
                        12.58 1.199V
                        13.03 1.203V
                        Very small battery and the charge proved to be 'fluffy' unless left on the circuit for much longer. Hence cap dump thoughts.
                        • Hi folks, Hi minoly, I looked over your videos some more just to verify your circuit parts and such, though I did not notice any flyback diodes, i can see all the base emitter diodes.
                          Were you using diodes to collect the collapsing field of each of the coil strands, I just could not see them in your videos, thanks.
                          Anyway, I am going to be rewiring my large ferrite core with at least 6 strands of 24 gauge, though I need to get more transistors, so will not be using all strands right away.
                          Going to try and achieve similar results with my 7AH sla batteries. Charge 4 in parallel with one, we will see how it goes.
                          peace love light
                          tyson
                            @All
                            That is great Lidmotor! I have been wanting to find a way to do this... because... I literally, have an endless supply of free transformers of all sorts and sizes, from tiny step ups used in LCD monitors to large 10:1 stepdowns used in UPS systems... all tossed away sitting in a recycler's back room, which is a free-for-all - but they rarely are center-tapped! It'd be cool if this method worked from the output of a (running) commercial inverter, for example, someone living offgrid, running their "big inverter" to do "big jobs, i.e. run compressors, pumps, fans, appliances, etc.." --- and meanwhile, using that cable as a signal for the said Lidmotor method.
                            If anyone wants something... let me know... this time of year I have the time to get stuff. I will try this Lidmotor triggering with some of the stuff I have already and if anyone wants stuff, let me know, I would only expect that you pay shipping, that's it.
                            • Simple 60Hz trigger
                              @All
                              Here is a video showing what I was talking about using a clip lead wrapped around an extension cord to pick up a signal to trigger a four wire transformer circuit. It is a super simple way to make the LED light work on a four wire transformer. Won't work if the power goes out and you would have to get a signal another way. I found that a separate simple AA battery Joule Thief would also supply a signal.
                              Simple 60Hz Trigger.ASF - YouTube
                              Lidmotor
                                peace love light
                                tyson
                                Hi Tyson,
                                I'm using a 1n4007 on each of the collectors, everything else that I did not describe above is exactly as JB has in his vanilla circuit. you might be able to see them closer here:
                                Bedini Joule Thief - YouTube
                                A maybe not so interesting note... because of the cap and diode, the trigger coil works either way. That is, connected like a joule thief (JB's SS SSG), or straight on like his monopole.
                                Patrick
