Joule Ringer!
  • Originally posted by ehsanco1062 View Post
    Hi Patrick
    I did what you said but i have a small question.
    Do you use any diodes from Emitter to collector?
    I appreciate your help very much
    Ehsan
    not on this build.
    I've used them in the past, but have not seen any advantage so I do not put them on, instead I keep the neon lamp there to protect the transistor. I am curious why JB put them in the patent...
    Patrick
      Hi Patrick
      Ehsan
      Ehsan,
      I was not paying close enough attention.
      the primary battery is backward
      flip it so the + is up
      leave everything else the same
      then take the bottom trigger coil wire and put it to the primary +
      Patrick
      • Originally posted by minoly View Post
        Ehsan,
        Patrick
        Hi Patrick
        Thank you for your patient with me for asking too many question.
        And i also try with your help draw the circuit to help the others to replicate your experiment so bear with me.
        I will change the drawing according to your last notices
        Ehsan
        Take the wisdom even from the mouths of the insane
        • xee2 - Just wanted to say you make the best diagrams of anybody on any of these forums. What program are you using?
            Hi Patrick
            Ehsan
            thanks eshan for your perseverance still cannot find the 2 x 10 nf 250 v any alternative for the big cap 3300 is it non polarized dc capacitor????
            were almost there
            happy experimenting
            totoalas
            • @ kcarring
              I replicated your 555 timer circuit using TIP31C and TIP32C. With 12 volts it draws 48 mA on high setting. The bulb is very bright. The transistors do not get hot. I like it.
              video >>> Carrington circuit replication - YouTube
              • Hi - here are my latest results with a flyback oscillator
                72W CFL . 35mA @5V
                UV tube 8mA @ 5V
                21W CFL 1 - 10 mA @ 5V
                current draw on flyback ringer - YouTube
                • Originally posted by totoalas View Post
                  were almost there
                  happy experimenting
                  totoalas
                  Hi totoalas
                  I cannot also find this cap in Sweden so I order it from Rick Friedrich web site and here is the link
                  10 uf 250V yellow capacitors
                  And it’s very cheap and I ordered 7 of them.
                  It’s non-polarized which means it can be connected either way.
                  I am trying to play with these caps.
                  Also don’t forget that Patrick using in his setup
                  1. 1k ohm pot 2W
                  2. 5k ohm pot 0.25W
                  3. 670 ohm line resistors 2W also I am trying to play with these
                  resistors value and powers I have many of these resisters 1W ,2W
                  and 5W.
                  4. Two 3300uf 350v but Patrick said as I remember that low
                  impedance butter and I have also many capacitors with different
                  values I also intended to play with it but one at a time.
                  5. don’t forget to use the neon if you want to protect your transistor
                  and its Ne-2
                  6. and the transistor he is using is MJE13009G I will stick with all the
                  parts he used and then I will use another
                  7. now I have all the parts except the 10uf 250v caps which I expect
                  to have it within two days so I already start working on Patrick
                  setup from yesterday
                  Good luck.
                  And many thanks to Patrick
                  Ehsan
                  • Thanks Patrick and Eshan,
                    Except for the caps , everything is ready for soldering....
                    Ive just wound around a crt toroid core a 6 wire # 23 50 meters
                    and using the MJE 13009 only 4 at the moment.....
                    My solar panel 60 watts 17 volts dc will arrive next tuesday .....
                    my 2 car batteries 70 AH - just filled with distilled water
                    Hope to get this going by end of next week
                    In the meantime , i will replicate my flip flop transformer using an amplifier toroid
                    happy experimenting
                    thanks again
                    totoalas
                    • Originally posted by seth View Post
                      72W CFL . 35mA @5V 165mW, if we divide 72W by 165 mW that wold be 436 times less power- very impressive
                      UV tube 8mA @ 5V
                      I did something similar too, what kind of transformer you are using? Одним словом круто.
                      Alex
                      • Hi folks, speaking of flip flops.
                        I'm trying out matts tesla switch and using the Basic Stamp 2 micro-controller, I just used one 12 volt battery, hooked up to a transformer and I am able to precisely tune the output for highest voltage.
                        So basically a flip flop, though using the basic stamp 2 circuit kit to turn on the transistors.
                        It is lighting a 34 string of leds at full bright using 1.8 watts, not sure if this string is supposed to draw 4.8 or 2.4 watts, probably 2.4.
                        The inverter aspect is useful, though what also interests me with using this stamp circuit, is the possibility of using it to pulse one transistor switch or multiple switches, since it has 15 output pins and one could make a radiant charger from it and then the pulse rate can be fine tuned and who knows how it might perform then.
                        Your thoughts welcome.
                        peace love light
                        tyson
                          peace love light
                          tyson
                          Very interesting Tyson. I'm running a PICAXE, but could I see your code? It'd be close, anyway. Have you ever played with driving an AD9850 or 51 DDS synthesizer with Basic Stamp for the purpose of creating a sine wave, high frequency? Been thinking about that. I bought a AD9850 little breakout kit, (cause SMD soldering is NOT my thing...). I think the AD9851 has better specs, not sure.
                          • Originally posted by xee2 View Post
                            @ kcarring
                            Nice! Runs better than mine. I've been fiddling around with mixing the source pulse with an amplified ground signal, in the middle of a darlington pair. I got some "flashes" but nothing stable yet. (like in a IMHOTEP CFL circuit) - trying to get away from that series filter. One definite advantage to this circuit is it's very low idle draw. It'd be a nice one to use for garden lighting / shed light.
                              Also want to address your standard signature comment, "Tar sands ? or... Sandy Tires? Ride your bike to work. Complete dependency comes from poor consumer choices."
                              The blame game never solved any issues, ...
                              Point well taken, I'm gonna change that up! Cheers
                              • Hi folks, Hi kcarring, thanks for reply.
                                It's a simple little code from Matts tesla switch pdf at 'use for the tesla switch' thread.
                                Do
                                Pulsout 1, 1250
                                Pulsout 2, 1250
                                Loop
                                The Basic Stamp 2 is 2 microseconds per unit, so 1250 is 2500 microsecond pulse and a picaxe uses 10 microseconds per unit, so it would be 250 instead of 1250.
                                The sine wave module sounds interesting, though wouldn't the output be limited to that little board.
                                peace love light
                                tyson
