Joule Ringer!
Hi folks, Hi totoalas, hmm, now I'm not sure to tune for highest voltage on resistor, as Bedini did say anything above 1 volt across resistor could damage the battery.
I checked the voltage across 1 ohm on my setup and at 400 microsecond pulse width, the voltage was 2.04 volts.
So I had to step back the pulse width to 60 microsecond pulses to get 1.02 volts across 1 ohm resistor and with the 13.8 volt power supply I'm using the amperage is 70 miiliamps at 60 microsecond pulses.
Whereas at 400 microsecond pulses, the amperage is 270 milliamps.
So, even though the charging is slower, I think I would stick with Bedinis suggestion, I think. Hope that helps.
peace love light
tyson
edit: I must say though, it sure is charging good with only 70 milliamps or 1 watt, not far off the charging that almost 4 watts was giving. Who knows, maybe such a short pulse can actually charge better, I'll have to play with even shorter pulse widths and see.Last edited by SkyWatcher; 12-18-2011, 04:38 PM.
12VDC -120VAC Mini Inverter Circuit for AC LED lamps 12.3V / 175mA (2.15 watts)
* I switched to a TIP42C, higher output -- but it seems to be a bit of a noisy circuit. Perhaps TIP31C would work well with this.[/QUOTE]
hI kYLE,
I am ahving heat problem with my flip flop 2n3055/ irf 830 680 0hm / 4. 7 k when used with 12 v dc supply ceklphone charger can light one led bulb maybe just wait for your design lol
One question on solar panel can a radiant energy from like slayer coil energize the solar panels ???? or how many incandescent lamp can simulate the sun rays to a 60w 3 a solar panel???
thanks
totoalas
Hi folks, Hi totoalas, If your talking about the french inverter flip flop circuit, then you will need to adjust the 4.7kohm resistors, if you lower the resistance the frequency will go higher and draw less current.
I used around 1.5kohm, though you'll have to test and see for your setup.
Also, if you exceed transistor peak amps, that can cause a kind of a heat avalanche and a heat sink prevents that.
After testing that Basic Stamp 2 microcontroller pulsing my 6 strand coil and then I went back to Bedini type radiant oscillator and it seems that the self oscillators are more efficient for whatever reason, compared to a digital square wave pulser.
I set up my radiant charger like bedinis, though with just a 22kohm resistor from collector to base and 1kohm base resistors and 2 transistors with the 3 strands per transistor, same as tests with stamp circuit.
With only 200 milliamps input at the same 13.8 volt power supply input, the flyback output across the 1 ohm resistor is only .246 volts or 60 milliwatts and charging seems about the same rate as the microcontroller at 270 milliamps input.
Though the major difference is that the output across the 1 ohm resistor was 2 volts at 270 milliamps input using the stamp circuit,
I think some of the reason the volt spikes are higher with the bedini oscillator, is that only one transistor per stage is used, whereas with the stamp circuit, I have to use a darlington type stage for the gain needed and this may slow down the collapsing field, giving higher current, lower voltage with the stamp circuit.
Your thoughts welcome on this long winded post, hehe.
peace love light
tyson
Hi folks, I switched over my oscillator setup from bedini style to joule ringer style using the tweaks that minoly is using, except for the diode, though I will try that also.
Using a 5.6uf-160vac/250dc capacitor from mbquart audio crossover, i have two of them, though using one now across what would be the potentiometer resistors before the transistors. Seems to be working well and usually with the joule thief at 12 volt input, the transistors get hot, though this capacitor may be helping prevent that, it seems.
peace love light
tyson
Originally posted by totoalas View Post12VDC -120VAC Mini Inverter Circuit for AC LED lamps 12.3V / 175mA (2.15 watts)
thanks
totoalas[/QUOTE]
There is no doubt it is a problem with this circuit and runaway current in my experience. I have tried many many combinations. The only way I can get "control of it" -- ends up having the lights flash, basically - that's the only way I can run it at 12v. For starters, maybe it should run at 6v, but I don't think that's gonna work either.
It gets back to my experiment with the PWM. Most modern inverters actually do you use a PWM, but not how I incorporated it. The way I did it was very unheard of, basically (to my knowledge) and any one with a great deal of electronic experience may laugh and explain exactly why the hell not to do it! Wouldn't surpise me. But, then again, it did actually work LOL.
Lidmotor used a rheostat, and I tried that with about a hundred different FET & NPN resistor combinations. Basically in my experience it is like opening the floodgates on those FETs, and you had better have a load ready. Note in the French video the big heatsinks. It was kind of scary how that stereo shutdown too, if u ask me. Magnetman seems to have incorporated a LM317 voltage regulator, but in my case that got screaming hot, as well. I will, one more time try supplying the FETS with a PWM, all built on the board for the hell of it. I dunno, to me it is a very unfinished and crude circuit suited to running a heater, or light bulb, but what do i know.----------------------------------------------------
Hi folks, Hi totoalas, yes 1.5kohm, though it will vary with your setup.
I drew a cleaned up version of patricks oscillator setup, it should be accurate now.
Uploaded with ImageShack.us
peace love light
tyson
JB Charger on a Toroid CRT Test results 201211
Originally posted by SkyWatcher View PostHi folks, Hi totoalas, yes 1.5kohm, though it will vary with your setup.
peace love light
tyson
My charger has the following Data Results
Input power supply 16 V dc
Input mA 246 mA
Output Load 3 yrs old battery 45 AH initial charge 12.46
No caps installed yet on the input output
0 min 12. 46 v dc
30 min 12. 62 vdc
45 min 12.63 v dc
Current 246 mA
test still in progress
totoalas
Excerpt from peter linderman on JB design Battery Secrets
Hi Mario, et al,
Thank you all for a considered discussion on these topics. The most important thing to keep in mind, is that we have all been learning as we go.
The terminology of "Negative Energy" and "Positive Energy" was Tom Bearden's first attempt to inform us all that there was a QUALITY DIFFERENCE between these two manifestations of electricity that the meters were saying were identical. This was a gigantic philosophical leap for most people, at the time, but as usual, Tom was right! Whether "Negative Energy" and "Positive Energy" are the best ways to characterize these differences is not the point.
If we simply observe the "facts on the ground" we can come to a reasonable understanding. In the case of the various chargers that John has been testing over the last 10 years, let us say that "Negative Energy" is that quality of electricity that comes from AN INDUCTIVE COLLAPSE. It is produced by a MAGNETIC FIELD in natural free-fall after the current that produced it has been discontinued (open circuit).
Its effect on a battery is unique. In response to the impedance (resistance) in the cells, the inductive collapse will produce an ever rising voltage to overcome it. Once this potential hurdle has been overcome, then it will produce current to complete the discharge. The higher the impedance, the higher the voltage will rise and the less current will be supplied. The lower the impedance, the lower the voltage will rise and the higher the current will be supplied. The response is completely self regulating, and the battery always gets as much energy transferred into it as it can receive, in the shortest period of time.
Let us also say that "Positive Energy" is that quality of electricity that comes from A CAPACITOR DISCHARGE. It is produced by a DIELECTRIC FIELD in natural free-fall after the voltage that produced it has been discontinued (short circuit).
Its effect on the battery is quite different. In response to the impedance in the cells, the capacitive discharge will produce a TIME VARIANT discharge rate, since the voltage cannot rise above its initial value. It is characterized by a current surge with a dropping voltage component. By contrast, the inductive collapse is characterized by a voltage surge with a dropping current component.
What John found, after exhaustive testing, is that both of these methods charge the battery quite well. Personally, I believe, from what I have seen, that the Inductive Collapse methods work a little better for restoring lost capacity in a battery and Capacitor Discharge works a little better for maintaining a battery. In other words, there are trade-offs.
The other thing John found is that the Capacitor Discharge method of charging a battery was universally compatible with other commercial methods, while the Inductive Collapse method was not. Batteries were just fine if they were ALWAYS charged with Inductive Collapse, but their performance was extremely poor if the charging method varied between Inductive Collapse and other commercial methods.
This is the reason why John eventually changed all of his commercial designs over to these universally compatible methods......so people would not blame him for ruining their batteries when they didn't use his chargers.
I hope this discussion of these issues of helpful.
Peter
Yes, this is correct.
I also have bridge rectifier connected to the output and pos/neg from the bridge going to the battery. You can charge off the diodes too, as per diagram.
Collector-emitter diodes are not necessary.
You can try with 200 -300 Ohm base resistors and 100 -150 Ohm common one or you can use 50 Ohm and 12V5W bulb in series. Bulb should barely glow. When gets bright than you have too much current going into the bases. I use MJL21194 and adjust resistors to have about 200 - 250mA going to the base of each one.
Don't worry about pins. If it doesn't work than reverse trigger wires.
My battery has been formatted with radiant chargers and they'll charge faster then regular ones. They will also climb up to 16 - 20V. New battery will not do that right away.Last edited by totoalas; 12-20-2011, 02:31 PM.
Hi folks, Hi totoalas, thanks for the information and I hope you get good results.
I am running some tests on mine, though as said, I'm only using two transistors, 3 strands per transistor.
Right now, I'm using the main diode going to all bases, then 4-1kom 1 watt resistors in series/parallel for 1kohm total, then these resistors are in parallel with two 5.6uf ac capacitors in parallel for 11.2uf total.
And I am using 300 ohm base resistors.
I am not using any diodes from base to collector yet, or from emitter to collector, just the neons.
Also I am not using the 10kohm and 20kohm resistors on first transistor stage.
Though I may implement these other components to see if they benefit the charging or not.
Though so far, the charging is very impressive and it is only using 280 milliamps input with the 13.8 volt power supply.
When I switch on the power, the coil makes a kick or thumping sound as if it's really getting a nice trigger pulse from the capacitors and such and transistors are cool to the touch.
peace love light
tyson
Originally posted by totoalas View PostThanks Kyle
Ill probably settle for the china made inverter 500 w for 400 HKD$
for now until we get rid of the heat problem ......
Hi Sky,
I ll see tomorrow if i can test with 1.5 K 5 w replacement for the 4.7 K
in my flip flop
totoalas
quote:
"Unlike bipolar transistors that are basically current-driven devices, MOSFETs are voltage-controlled power devices. If no positive voltage is applied between gate and source the MOSFET is always non-conducting. If we apply a positive voltage UGS to the gate we'll set up an electrostatic field between it and the rest of the transistor. The positive gate voltage will push away the 'holes' inside the p-type substrate and attracts the moveable electrons in the n-type regions under the source and drain electrodes. This produces a layer just under the gate's insulator through which electrons can get into and move along from source to drain. The positive gate voltage therefore 'creates' a channel in the top layer of material between oxide and p-Si. Increasing the value of the positive gate voltage pushes the p-type holes further away and enlarges the thickness of the created channel. As a result we find that the size of the channel we've made increases with the size of the gate voltage and enhances or increases the amount of current which can go from source to drain- this is why this kind of transistor is called an enhancement mode device."
What is a MOSFET, what does it look like, and how does it work? | techPowerUp
For these reasons, and more, the circuit is very sensitive in its crude (simple I mean) setup, so all of your components are going to potentially change everything.
My setup is just like a hammer and a fist... I need to use small FETs and I think I will switch to 6V battery and see how that goes.
For powering anything of value (beyond an LED light bulb), I agree... use a commercial inverter. I like Wagan Pure Sine Wave, for value vs. quality. They are not the best, but they work well, power anything, and are reasonably priced.----------------------------------------------------
Originally posted by SkyWatcher View PostHi folks, Hi totoalas, thanks for the information and I hope you get good results.
peace love light
tyson
Any way I wish that you can use a primary battery instead of using power supply because we are here to prove that battery with small AH power can charge bigger bank and by using power supply we can’t figure that and also Tyson you said that you used 280 milliamps and that is good, in fact I can never get that amp drown or even close and I am using seven transistors and my amp drown on the input is 0.98A and this is the sweet spot but I still did not use the 10 uf 250vAC cap because I don’t receive my order yet and I think that the whole story is in that capacitor don’t you think that ,I wish if Patrick can help us with that and Patrick said that he try this setup with mjl21194 transistor and he did not get the same result he got when he used the mje13009 so I use now Tip31c and its good but I will try the mje13009 tomorrow and I will build the circuit exactly as Patrick did in his setup except for the 10 uf 250vAC cap
And I thought that I will get the order in two days but it seems that something wrong they said that they shipped my order 11days ago and I did not receive the order yet.
All the resisters I used now are 0.25 w and less except for the 1K pot is 2w and I removed the 5K pot and put 250 ohm resistor and I tried to make non polarized 10 uf 250vAC cap by using two electrolytic capacitors and connect them in series either ways like this:
Or
Remember that that putting caps in series halves the overall capacitance though, so two 1000uF caps connected as above will give you the equivalent of 500uF.
So I connect two 47uf 350vAC cap the first connection and by this connect you will get half of the value this mean that I should get 23.5 uf 350vAC cap but I can never be sure that I get tis value but I think I don’t know how to get 20 Joules so I just don’t want to west my time sitting and waiting. I am still playing with different components and see how it will affect the charging rate and amp withdrawn on the input and I will post some result as soon I will get the cap 10 uf 250vAC 10 joules .
one more thing please tyson can you help me how to upload a picture with the post the same way you did with patrick digram .
thank you
good luck
EhsanTake the wisdom even from the mouths of the insane
peace love light
tyson
Or
One more thing
Please Tyson can you help upload pictures with post the same way you did yesterday .
Thank you
@skywatcher totalas et all
What sort of figures do you folks have on your coils... i see you are using 23 awg, what is the reading for ohm? Henries? number of turns / dimensions?
Thanks!----------------------------------------------------
Thanks!
Patrick set up 6 x 3.3 uf cap 6 coiler #23 50 m MJL21194
wound in an old crt ferrite cone 8 and 4 cm dia
will do the setup test w/ 12v 7ah batt on sat
JB CHARGER INITIAL RUN W/O CAPS 221211 - YouTube
totoalasLast edited by totoalas; 12-22-2011, 12:18 AM.
