Peanutbutter, I find we are on the same page!
I think the mains-grid at some point will be toasted, probably by EMP, and we want folks to have LIGHT. Maybe I'm being pessimistic, but when a super-duper bomb is built like the "High-altitude EMP weapon",
, then history tells us it's likely to be used... BUT we can prepare and help others too. Hence, running on 12V DC... prepared to do it, anyway.
Now -- I've made some progress today after the "honey-do's" were done.
The best I could do this morning was about 23 Lm/W. Well, I managed to double that. Here's how.
First, I finally rec'd a couple of high-efficiency bulbs I'd ordered, and these run at about 1 W using the mains and put out nearly 80 Lumens in the light box -- 80 Lm/W, which is great! So I used this bulb, and immediately the yield with the AIR core SJR-2.0 jumped up to about 40 Lm/ W. I varied the voltage; here is near the optimum voltage, 9V, with changing only the bulb from previous runs this morning:
9V in; 0.8 A, so 7.2 W in.
3700 Lux in the light box, times 0.08 (my calibration-conversion factor for this box) = 296 Lumens.
296Lm/7.2W = 41 Lm/W -- not bad.
PS -- freq = 157 KHz; V-rms output = 104 V with this load.
Note: at 12V, I get just 29 Lm/W... So there is some tuning associated with varying the voltage. A broad maximum -- from 7V to 9V input, the yield stays near 40 Lm/W.
OH -- note that the bulb says it is for 220V, 50 Hz -- but it works just fine with the above conditions! Someone asked about that; I think it was Jules. Here's the bulb I'd now recommend, Jules:
Cheap E27 1.5W 36 LED 252LM White Light LED Light Bulb AC180~240V;50HZ,5500~6000K | Everbuying.com
-- and only $8.93 each if you buy 2...
It does not put out the Lm/W advertised on-line, but at about 80 Lm/W measured in my light box, it is better than other LED bulbs I've tested (typically 55-65 Lm/W).
Next, I tried a trick used by Lynx earlier, I compressed the primary winding down to about 3" along the base of the coil -- so it covers now maybe 1/4 of the secondary coil... starting to look like a Tesla coil now.
Results -- my best to date -- follow:
9V in; 0.33 A, so 3 W in.
1990 Lux in the light box, times 0.08 (my calibration-conversion factor for this box) = 159 Lumens.
159Lm/3W = 53 Lm/W -- a big improvement from 23 max this morning!
PS -- freq = 178 KHz; V-rms output = 84 V with this new bulb and the primary coil concentrated at the bottom.
Whew!
(PS -- I'm not claiming OU at this stage!!)
For me, again. I really got into this relating to prepping and this is stuff part of it too. I am not normally a type to post, but I have a compulsion, from somewhere, to do it. I'm just hoping to help if possible.
![EEK!](http://www.energeticforum.com/core/images/smilies/eek.png)
Whew!
![Blowout Smiley](http://www.energeticforum.com/core/images/smilies/blowout.gif)
