Paralleliing output of hall switch
  • Paralleliing output of hall switch
    Hi Group,
    I have a basic question regarding hall switch . Can one hall switch be used to trigger multiple circuits ?
    Is it as simple as adding a parallel wire on the output leg or is there more to it....
    Iam trying to use 4 window motor bi polar circuits and want to trigger all of them with only one pair of hall switch . Any other example circuits or suggestions would be great ...
    The second basic question is about zener diodes. What is the significance of the resistor value before a zenerdiode . Iam using 3.2kohm resistor in series with a 12v zener for regulating a 48 v input to 12v. The output is fed into the above stated hall switch . Will different values of resistor have an effect on the current conducted by the zener diode and possiblyon the current output of the hall switch ?
    Have fun,
    Bhargav
    Last edited by Bhargav; 01-13-2011, 06:14 AM. Reason: Resistor value was wrong earlier
