Tesla a very intelligent guy thought of something:
How many volts there are between the clouds and the earth?
How much charge there is in the clouds?
How long do the discharge takes to discharge?
How much energy there is on each discharge?
And finally how many discharges there are per second?
He found that there are 100 million volts in the sky
He found that that a discharge could have a density of 30 kilo amperes in 20ms
He found that the energy in mega watts / hour than is at least 1,6 megawatts/hour
Than he found that there are 50 discharges per second on earth.
He thus thought to him self what if we could harvest around the earth the energy from lightning?
He thus found that using a resonant tank he could actually accumulate all that energy and transform into useful energy cause its very high capacity and impedance.
His "tower" was insulated from the ground forming a capacitor, it was than connected with a copper bar having iron around it and other bars around the iron, to make a wire wire transformer.
Than this resonant tank oscillated the charge of the all "antenna" Creating a force on the charged particles around the all earth...
On other places on the earth other antennas could be placed in sync with the original signals to control the rate of discharge of the electricity in the sky.
And If you have a "collector of force" connected to a tuned tank you would induce an oscillation in the tank thus receive energy...
The fact is where is the circuit?
Why the charges in the sky have a potential difference from the ground?
What keep the water from going into space? The gravity only? How about the electrostatic attraction? How strong is this force?
My theory say's that the starting potential of lightning intra-cloud is caused by the separation of the ions by the gravity force and sun action. As the discharge becomes very strong intra-cloud it thus accelerate particles to speeds close to the speed of light and than this accelerated particles ionize the air allowing the lightning to occur simple as that.
My problem is to understand why in hell the earth is aways one side of the capacitor?
Maybe is related to the nucleus of the earth being hot so being positive.
And being the soil conductive probably assure the charges will never be distributed in the center. No charge shall exist in the middle of a conductor.
Wet soil.
Basically i'm saying that the ground negative earth is about electron emission from the magma in the nucleus of the earth.
This would explain so many things including gravity it self.
The planets spin and some things in astronomy.
The earth suffer a strong centripetal acceleration even if the radius (one year) is so big, so is the speed and such is the mass.
We on earth suffer the gravity acceleration force witch actually is bigger than 10m/s*s the fact is that as the earth spin we also suffer a centripetal acceleration that cancel the gravity.
Thats why the gravity resultant depends on the mass and on the spin of the planet and its radius.
This would explain why solids are on the ground and air floats over it.
So now we ended with three forces acting in the clouds.
Wet soil.
