Timing on motor fires @ 22.5 Deg. Need help with timing circut 120+ DCV . Magnets are staggerd on rotor see drawing.
Timing on Massave motor
Do you intend to use hall switches for timing?
Hi
As I have said already, we need more info on your motor, how is it supposed to be working, how are the magnetic flux'es switched ect. So far I still don't have a clue on how your motor should work, that is why I can't help you with the circuit.
Hi ssjjaaw,
I just got a notification that my email did not get through to you. Anyway, here is what I wrote:
Hi
Thank you for the diagram, but it is hard to understand the operation fully, please send more pictures of your machine so I can see how the magnets are positioned and where the armatures are. In the mean time I attached the circuit that worked fine for user scienculo on energeticforum with his 6 pole parallel path motor.Attached FilesIt's better to wear off by working than to rust by doing nothing.
other
Originally posted by Jetijs View PostI attached the circuit that worked fine for user scienculo on energeticforum with his 6 pole parallel path motor.
Index of /laboratorio/esploroj/rownolegle_strumienie
