Toroidal Power Amplifier
  • #61
    I think this is the one i have, the 50V version:
    http://www.nuvotem.com/en/products/pdf/1000P1_1001.pdf
    And I think the core is GOSS (grain oriented silicon steel)
    /Hob
    Hob Nilre
    • #62
      Originally posted by nilrehob View Post
      i put a rectifier and a capacitor on the middle winding where there is no voltage,
      only current when there is load on the right winding:
      the "no voltage" part is not true
      my meter is acting strange not sure why
      I used the oscilloscope instead today and there *is* a voltage on the middle winding
      in my case approx 0.6v/turn
      i rewound the middle winding to around 25 turns to give me voltage suitable to charge a 12v batt
      i do get some current in the middle winding without the load on the right winding
      its not much but the 1.3Ah battery seems to charge somewhat
      if i add the load the current on the middle winding rise considerably as stated before
      this small current without the load on the right winding is what i was looking for
      I think maybe Thane's BiTT works by having a (each) secondary with two cores channeling the bemf-flux to the second core (the right core in my setup when the middle winding act as secondary)
      so without the load on the right im perhaps doing a first small partly BiTT replication?
      I have to do more tests
      /Hob
      EDIT: BTW i did a middle winding with only two turns using the thickets wire i had
      when shorting it and the right load on it made 45A and some smell...
      Hob Nilre
      • #63
        Nil,
        thanks again for doing those tests with limited time
        your two-turn result makes some sense in that.....less turns generally is less voltage = more current.
        hmm...this is kinda getting interesting
        EDIT :-
        yes thanes BITT, seems to get its gain not only from having the BEMF flux NOT intereferring with the primary flux ( and therefore making the primary draw more current )....but also due to the "geometry" it allows the 2 secondarys to feed each other
        2nd EDIT:-
        yes i think you have a sort of 2/3rds BITT.....do you have any other toroids of reasonable size.( or just ANY toroids with a winding )....that you could add in ?
        • #64
          well, its freezing outside, reluctant to go out
          Yes, i was surprised when i got no voltage, which was false, this does make more sense.
          Sigh, I just ordered one, wife mad, not in stock so it will arrive in 2 weeks.
          This is what im planning to do when it arrives:
          /Hob
          Hob Nilre
          • #65
            /Hob
            That diagram is exactly what i was thinking !
            also, with 3 toroids, it opens up a few other possible configurations too
            • #66
              whats inside
              Hi,
              today at work i came across two, 240V CFL ballast's.... there were two inside each holding for one cfl tube. they are very heavy, about 7-8 inches long, 1 & 1.2 inches square, 4 wires.......resitances of 18 ohms & 28 ohm ( i think ).
              so, anybody know whats inside them? ( id cut them open but they have little welds & rivets and i dont feel like filing right now )
              • #67
                ok, i couldnt wait, i managed to chisel one of them open, yukky inside....sealed in....wax i think, and.....im not sure "what" they are exactly
                • #68
                  I got my third toroid a while ago,
                  had two extra windings done (blue & green) on top of the original windings:
                  put power on,
                  lamps will not light properly unless the other lamp is there,
                  and not unless both primaries are powered.
                  any gain?
                  not sure yet,
                  probably not
                  i have been using two 15W bulbs
                  the two primary-cores unloaded consumes 10W at PF 0.7
                  with the two bulbs its 32W at PF 0.87
                  but the number of turns i did was too few,
                  i did 300 on each when it should have been 400,
                  as i only got 180V and not 240V
                  another thought
                  the two primary-cores (if using the topology as in pic)
                  should perhaps have less area than the secondary-core
                  /Hob
                  Hob Nilre
                  • #69
                    Wire Core / perpendicular windings
                    I just finished winding my toroid that I plan to use for a hho cell. It has perpendicular windings and uses copper coated steel for the core, which is also the secondary.
                    I will use pulsed current in the primary ( red ) and hopefully the secondary will carry an alternating magnetic flux, that will be delivered to electrodes in
                    the cell.
                    check out:Bagel coil pictures by felaudet1 - Photobucket
                    • #70
                      Please be careful and breath very shallow and carefully while working with this material,
                      and wear latex gloves too !
                      The material in that ballast may very well be a high-level carcinogen type of insulative and thermally conductive potting material !
                      • #71
                        Since you have mention a chisel - maybe you'll find this useful - Compact fluorescent lamp There is a balast for CFL.
                        Vtech
                        General D.Eisenhower
                        http://www.nvtronics.org
                        • #72
                          the cell.
                          Is it a kind of TPU?
                          /Hob
                          Hob Nilre
                          • #73
                            I finally wired the third winding,
                            but the test so far has been unsuccessful in replicating Thanes BiTT
                            so i guess next step is to pulse them ;-)
                            /Hob
                            Hob Nilre
