Pi is a reflection of the the infinite.....how? think of it like shells of numbers, the point being the center...the first shell is ones, the second shell twos etc...all the way out to the shell of nines...in Pi 3.14 the decimal point is reflected..... .314 is reverse Pi or Ip....the infinite point ....this model will show how hydrogen the lightest element, atomic number 1 at the center and all atoms fit this model....the infinite aspect of gravity and the finite speed of light will be explained to absolution ....in decimal math .314 x 3.14 is equal to .314x.314....the difference is the direction.....to or away from the I. [infinite point]...try this OK so if the theory holds true, a direction, a ray, a line, must exist..... .7129 and .6105195 are points on that line ....Edward Leedskalnin showed us these points.....here is what i know , the I. is the center, .314, .7129 and .6105195 will correspond to the diameter of a spike at those points.....look at it like this looking straight down at at the bullseye ones are the first orbit, twos are the second all the way down to the diameter of nines, which equals the event horizon of a black hole.... make a few calculations and see for yourself this model fits!......david
Pi paradox solved
how many 9s = 1 ???
square root math.... .1 squared is.316... .2 is 447.. .3 is .547 .4 is 632.. .5 is .707 .6 is .774 .7 is .836 .8 is .89 and .9 is .94 why? the value of the sum is more than the number ?? and then .99999999999999999999999999999999 squared is 1 ? OK the nines are a spherical reflection of one. think of it like this....an infinite light source or infinite point[I.] out from the . is a .Line....the .L is bi directional rays out from I. <.I> since . is I it is also >.I< these are equal mathematically....so are >.><.I< so is >.> ........are you following this? permanent magnetism is >.><.< , >.> is super conductivity ... so can you visualize how magnetism is a reflection of the infinite?...also if [ is a mirror, <.< [ >.> = >.> also >.>[<.< and >>.[.<< and >.[.< , <.[.> = .> = . this clearly shows a quadratic expansion math shows this....now i will show how light and magnetism are a 4 part stream with one infinite part only the I> is highlighted...so this explains why the math says they are equal....they ARE equal!....physical evidence;....ferro fluid in a rotating magnetic field assumes a 4 part design with one main and three smaller curls , reflections of the I>... YouTube - Experiment on Fluid Motion ...light follows this pattern [polarization] this is why gravity bends light [Albert Einstein] the math says light can be circular, [event horizon]....I gravity is a reflection of I velocity......the square root math shows this is correct....i can now show the mechanics , through math and physical evidence, of Edward Leedskalnin, John Hutchinson and the ancient stone builders, [Egypt, S. America, Lebanon etc.] i will show that EVERYTHING follows this same design... Mandelbrot's sets are a flat plane vortex..... http://www.salvolavis.com/wp-content...brot-large.jpg is an extraordinary depiction of what i describe.......david
Physics Model
sorry about the links...davidLast edited by david lambright; 01-26-2011, 03:55 PM.
Physics Model
these are overlays to show the relationship between the shapes of magnetism [Leedskalnin, cover of magnetic current] and the " crescent moon" at Coral Castle...the two shapes, [Ed] N and S are counter rotating fields while the "moon" is the two vertices rotating together moon = NN >SS or >>.<< = .>....or infinite.....the two shapes [Ed] are counter rotating...magnetism N > S and N < S = NN>.<SS = .> .....mathematically these equations are EQUAL these are a couple of overlays to visualize this model
....there is but one . that all emerges from... I. the . becomes .Line .L becomes .Disc [plane]......so we have a complete 90 degree change of direction.....90 degree linear to radial [line to disc] change that is equal so from . =.L =.D =.Rotating ring.....but the rings axis is off center [ 3 things cause this line + disc + expansion of I.]....this is the Fibonacci spiral.....or double helical spiral ..DNA....we know that DNA is two strands ...1 infinite and 3 reflections of!....back to the ring...a .Ring with .Spin = 0 = >.> =. .Spin on the ring gives rise to attraction and repulsion but in two ways.....a line = repulsion or disc= attraction ..think of it like a vortex on a flat sheet ....the big end attracts .....the little end repels on the ring, 2 vertices oppose each other <.> or/and >.< which is equal to >.> ...when the two vertices are running together [Ed says chasing their tails] is when the infinite part has the power.....davidLast edited by david lambright; 01-26-2011, 03:53 PM.
Mandelbrot overlays
Sign In Sign In these are the overlays i made to show how Mandelbrot's math is correct [mirror reverse] and this is a depiction of not only of quantum mechanics, atomic structure, molecular structure etc, all the way up to planetary, galactic and universe and universal. Edward Leedskalin knew these facts and he didnt know how to tell anybody about it. Try to describe to someone you have never seen before. We know the speed of light is 186,000 mps. This is a constant. The universe expands at that rate. Inside of the spheres infinite, outside the sphere speed of light. This is what gives rise to all forces. I will show in this thesis that all forces are phase shifted reflections of the infinite. I will also show that this infinte line exists in all forces we know. Magnetism has four parts, one infinite three reflections. The Fibonacci sequence Is the spiral of life. I will show also that the Torricelli trumpet is no longer a paradox. I will also show that this shape goes from an infinite point to an infinite circle, being the mathematical mirror of a black hole. in the overlays you can see the shapes of permanent magnetism (Leedskalin). I will also show the exact mechanics of everything that i state. I will show through experimentation that levitation is absolutely factual. The ancients knew this. the spheres overlay depicts the numbers one through 10 starting at a point. Layers of numbers, shells out to the number nine. Through square root math. We can plot a point anywhere inside the sphere. .9999999999999999 = 1. and vice versa. I will show through this model that hydrogen being the lightest model orbits at 1. The plot, 3.14, is a mirror reflection of .314. they are equal. decimal math shows this to be true. Think of it like this, an infinite number of lines form a point streaming outwards are the numbers .123456789123456789123456789. from anywhere on the point those numbers go out in a straight line. Check into this. Fibonacci's curves is a spiral vortex looking towards the infinite..... david.....ps...if this is not true it will break down and fall apart.....try and break it!
David, Your Pi theory for 3 dimensional worlds like Earth is interesting but there is some possibilities of other more difficult to understand 2 dimensional worlds yet to be discovered similar to a Möbius Strip , or black holes where parameters for any claims of galactic or universal understanding is a huge leap of faith about the mathematical equation Pi .
GlenOpen Source Experimentalist
mirror reflection
the first way we can use it is in predicting quantam events...events past the scales we use to measure time, space,gravity, light....we as humans are master manipulators of matter and waves. .duality... light is both a reflection and a source , the source being the infinite....light is a duality...if you have a particle it is also a wave, a mirror, spherical reflection is out of phase with the source, still equal to infinity...a mobius strip is a one dimensional reflection of an infinite ring.....paradox...sound travels in air or water but not in a vacuum ???like electricity and magnetic current like metal better!!!! wave phase change due to spherical reflection is the mechanism......the infinite part of sound travels in a vacuum a cancellation wave.....this relation ship is shown clearly in this Egyptian carving... ...this Hopi art is a depiction of the Universe, looking like my model.....look at this one...the disc and rotating ring are clearly visible....david...YouTube - Extraordinary Toroidal Vortices YouTube - Experiment on Fluid Motion ... YouTube - Quaternion Julia Fractal http://www.bibliotecapleyades.net/ci...vitywg047a.jpg ....david
thought expirement...
heres the thing...
anomalies....room temperature super-conduction and levitation... Hutchinson did it. but what are the mechanics behind this effect? Leedskalnin knew how...he just did not explain to absolution, HOW he did it....try to explain to someone something you have never seen??? many have tried to put everything in perspective.....many are very close....i am prepared to explain the MECHANICS/math/experiment AND results of ALL of Leedskalnins work...from quarry to placement, cutting and levitation...yes i did say levitation, and all of the physical mechanics, the theory and reality match...ALL FORCES UNIFIED....i am proposing a NEW PHYSICAL MODEL!....the model that quantum mechanics reflects...all of the predictions made, all paradoxes solved....it is so simple and absolutely elegant .....the same design from the singularity to the event horizon of a black hole......they are one in the same and mathematically equal, by the way.....try this thought exercise....two shapes, Torricelli's trumpet, a sphere, and an infinite line.....these three things are the most basic building blocks of MATTER .....this model shows the exact physical mechanism of all forces including and especially, GRAVITY....not just that but the number shell math,[square root] model is also a map if the infinite...frequency, spectrum, atomic weight etc.... i will show EXACTLY how and why my devices generate that heat type wave....i will show how the ancient Egyptians cut, carved, and LEVITATED their stone work...they left a complete description of the method IN STONE.... http://www.bibliotecapleyades.net/im...ithus05_03.jpg from the bottom up this shows all reflections, phase changes and how all forces have an infinite part....how sound does not travel in a vacuum shows that sound travels infinitely in a vacuum, its perfect reflection cancelling the wave, [the wave is there, just cancelled]....Tesla predicted a time when we would connect to the very wheel-work of nature...the time is now....we live on a planet, orbiting a star, in a galaxy, in a UNIVERSE expanding at the speed of light ....for this to be understood, the duality of a reflection is evidenced by a phase change....back to the thought experiment...2 shapes, sphere, trumpet and a line...we view our existence from the OUTER surface of our planet....imagine being on the inside of the sphere, the center being infinite....gravity is on the inside of the sphere...these are both mathematically identical.....the quadratic expansion shows a linear curve....the line being equal to the spherical reflection....does this make any sense yet?....there are some who will embrace this model NOW....for a great many, the absolution will be repeatable levitation.....room temperature levitation, in a controlled environment, LEVITATION....i am making a video to show this ALL in detail, ...the math will show that an infinite point is equal to any and every spherical reflection, 4 fold, 3 fold, 2 fold and 1 to 9 fold......the 99999s =1.......david
fuzzy tom cat!
i realize what you are saying...what you have to do is imagine a reflection... a spherical phase shifted reflection.....when working with the math, Pi, square root etc, you must reflect and phase change, depending on which plane you are on....Pi, 3.14, mirrored is .314 ...decimal math says they are equal.... ...this image of Betelgeuse, shows the Fibonacci spiral....the Aztec calender shows this same relationship....check out the HOPI blue katchina legend....ps, i will get those links up.....david...when using square root math...start from the point....forward and backward, [mirror image]....try this glen, you will see there are no more paradoxes.......thanks
I don't get it
Hi David,
thanks for trying to convey these interesting thoughts.
But please check the two last links in your postings (postings #8 and #9). You will find they don't work. Maybe you can edit the postings so that they will work.
I am sure the images would be interesting.
And also:
Originally posted by david lambright View Post....we view our existence from the OUTER surface of our planet....imagine being on the inside of the sphere, the center being infinite
Originally posted by david lambright View Post.... gravity is on the inside of the sphere...
whereas if we sit on the outside of the surface, gravity pushes us towards that surface (i.e. weighs us down, i.e. presses us against the surface)Last edited by marxist; 01-28-2011, 04:44 PM.
electromagnetic spectrum
there is a thread over at disclose tv and there is an image of an old westinghouse EMS chart YouTube - Dolphin play bubble rings File:Juliasetsdkland1.jpg - Wikipedia, the free encyclopedia .... ......david
hi
And also:
Do you mean 'infinitely small' or 'infinitely far away'?
You mean gravity will pull towards the inside of the shere, away from the sphere's surface (i.e. pull us off the surface), if we imagine to be sitting on the inside of a sphere's surface !?
The Electromagnetic Spectrum
Hi David,
The link on the "Electromagnetic Spectrum" from the Westinghouse Research Laboratories is a good chart for information the one you referenced is quite small so here is a better copy.
I'm still confused and it appears so are some other members on your thinking here ..... possibly you slowing down a bit and explaining this new theory step by step in clearer detail.
Thank you in advance,
Glen
