Ismeal Aviso self charging electric car
  • #31
    A typo or no overunity?
    I too, at the present time, am sceptical of Aviso's inventions. I just read the following article on Peswiki which outlines the results of his MEG:
    Aviso Envisions 1 Million Self-Charging EV Retrofit Stations by 2011 End
    The test results of the MEG running a 800 W resistive load are outlined below:
    Duration: Total of 4 hours
    Load: 800watts Resistive Bulb [estimate]
    Input: 12.8V
    Battery capacity: 6,000 watt-h.
    Battery remain: 12.7V
    Volts drop: After 4 hours =0.1 volts
    Unless the battery capacity is a typo, which it could be, a 6000 Wh battery should be able to run a 800 W load for about 7 hours before the voltage drops to a level that it can no longer provide useful power to the load.
    If he wants to show that he is credible in his demonstrations he should purchase one of those BK Precision battery capacity meters that Bedini always uses to show how much energy has been drained from his batteries. Using a $10 multimeter, whose readings can easily be out by 10% or more, to show the voltage drop in the battery as evidence of overunity is insufficient evidence.
    • #32
      Like anyone i hope he has something real on the go... and it wouldn't surprise me in the least hearing it came from the Philippines, but...
      .. man that thing is built like a Sherman tank... was there zero concern for weight?! If he's capturing free energy, he certainly wasn't concerned with "not getting enough". wild.
      hope it works and hope it gets out there. work him hard for open source - if its the real deal Ash!
      • #33
        Anyway, it doesn't matter if Aviso is the real deal or not, we are moving to such a future ... at first electric vehicles (Most of the car manufacturers started this in 2009-2010), then more efficient electric vehicles, and then electric vehicles which require no charge at all, and then spaceships and then ....
        http://blog.hexaheart.org
        • #34
          Back to the Future
          We had a great future behind us. Electric cars were around a 100 years ago.
          Tesla had all the answers a 100 years ago. Man went to the moon in 1969.
          In the 70's they were predicting that in the future we would work less and have
          more. Now people work two jobs and barely make ends meet, when before one
          income was enough to support a whole family well. Why have we denegraded so much ? Seems like we have to reclaim what we lost first then move ahead.
          FRC
          • #35
            Micro wave ground scouring Aviso car.
            Originally posted by Tysla View Post
            can anyone give me cliffs as to what is going on here exactly? everyone else is so well read up on this category i can't catch up. simplest terms possible please.
            Aviso powers a carrier wave recieving antenna with the bemf from the D.C. motor. Channeling this obstructive power from the motor improves the motor's efficency. The loop antenna recieves cell phone tower transmissions in the 700 Mhz range. This carrier wave broadcasting antenna beam may be miles in diameter. The low impedence tesla coil is excited by the cell phone tower transmission and shorted to the capacitors. Aviso then multiplies the frequency up to 6 giga Hz through this set of cascading capacitors. This full sine wave smaller then broadcast signal is then sent to the negative ground of the lead acid battery. This low end microwave band signal scours the negative ground of all it's electro-magnetic strength, and spontainiously generates a charge in the positive plates of the battery; Like surpassing the Currie point where the heat strips the magnet of it's field. The surrounding field pressure pushes into the positve plates. The power is generated inside the lead acid battery. His overunity M.E.G. probably works the same way.
            • #36
              Micro wave ground scouring proof of concept test.
              I'm on holiday again in sunny Costa Rica where the winter weather's warm. I have a favor to ask of someone: Please run a piece of magnet wire through the microwave oven door, and attach the uninsulated end to the negative pole of a depleted 9 volt rechargable Ni-Cad battery. Turn the oven on and compare the voltage readings from before and after. Get back to the thread with the results. Thanks.
              • #37
                Originally posted by synchro View Post
                Aviso generates a carrier wave antenna with the bemf from the D.C. motor. Channeling this obstructive power from the motor improves the motor's efficency. The loop antenna recieves cell phone tower transmissions in the 700 Khz range. This carrier wave antenna may be miles in diameter. The low impedence tesla coil is excited by the cell phone tower transmission and shorted to the capacitors. Aviso then multiplies the frequency up to 6 giga Hz through this set of cascading capacitors. This full sine wave smaller then broadcast signal is then sent to the negative ground of the lead acid battery. This low end micro wave band signal scours the negative ground of all it's electro-magnetic strength, and spontainiously generates a charge in the positive plates of the battery; Like surpassing the Currie point where the heat strips the magnet of it's field. The surrounding field pressure pushes into the positve plates. The power is generated inside the lead acid battery. His overunity M.E.G. probably works the same way.
                WOW! What??
                What is the difference between a carrier wave antenna an a normal antenna. Holy cow troops, cell phones operate in the middle of the AM Band??
                Did I not understand something with all this explanation?
                • #38
                  I found this article about the DOE test:
                  Philippines DOE Comments On Aviso Electric Car
                  • #39
                    correction.
                    I added the word "beam" to the comment. Meaning "cell phone broadcast antenna beam". I also changed "generates" to "powers" in the opening sentence. Please reread the original now for an improved understanding. Sorry for the unclear wording.
                    The important point is, Ishmael claims he is capturing a cell phone transmission broadcast signal from a nearby tower, and multiplying the frequency to microwave band width. It's no longer a radio wave, but so small it excites molecular electrons and generates heat. I think he may be frying his battery. He reports electrical fire smell when he trys to speed up. Someone has to try the proof of concept experiment I suggested above to find out if this really works.
                    • #40
                      I added the word "beam" to the comment. Meaning "cell phone broadcast antenna beam". Sorry for the misunderstanding.
                      The proof of concept works. I tested on a 9v rechargeable and it went from 9.42v to 9.48v in 6 seconds. However the wire at that point caught fire in the microwave thus ending the test.
                      Any ideas on how to keep the wire from burning up?
                      It did work however.
                      -Altrez
                      EDIT: After 5 minutes of rest its up to 9.53v
                      • #41
                        Test.
                        Altrez:
                        Thank you! That took courage. The results are awesome. We need to figure out just what exactly happened there. This may be the first time in human history anyone has performed this experiment.
                        • #42
                          Altrez:
                          Your idea
                          I am not sure what is happening. If I were to guess I would say the wire acted like an antenna channeling the microwaves into one side of the battery and some how exciting the other side as well.
                          • #43
                            test.
                            Altrez:
                            I wonder if you could upload a video? Ishmeal Aviso is generating the microwave from back EMF. This demonstrates the possible authenticity of his overunity claims. We need to be patient and harness more input from the forum group. Aviso also has an MEG that apparently is running 800 watts of incandescent light bulbs practicly for free.
                            • #44
                              Altrez:
                              Here ya go!
                              YouTube - 9vtest good
                              The length of wire makes a difference as well. If we could figure out the right length and gauge I bet the effects would be a lot better.
                              -Altrez
                              • #45
                                Test.
                                Altrez:
                                The battery must be acting as a dipole rectenna; Both recieving and rectifying the full micro sine wave and transforming the A.C. wave to D.C. current, or maybe the D.C. charge is pulled in from outer space from the kind of ground scouring effect we discused earlier. There's clearly an additional micro volt that appears from somewhere. There's no electrical current going into the battery. At this point the effect is a mystery!
