Originally posted by synchro
Ismeal Aviso self charging electric car
test.
Altrez:
Take a look at this JLN plasma ball microwave reciever. It might help to attach the wire to the kind of metal reciever JLN shows building instructions for at this following link:
Plasmoid ( ball lightning ) generation with a microwave resonator by Jean-Louis Naudin
Plasmoid ( ball lightning ) generation with a microwave resonator by Jean-Louis Naudin. I think what we need to do is find a safer way to generate the 2.5ghz waves.
-Altrez
I'll suggest a possible half baked (no pun intended) explanation for the battery voltage increase in the microwave oven test. Since you have a huge amount of power that is exciting a wire at a high frequency and you are only connecting it to one side of the the battery I think we can assume that some electrons in the wire are acting to 'stir the pot' a bit in the battery. So you are adding a bit of energy to the battery. The battery may even act to some extent as it's own rectifier. Many small effects can be seen with very high power level excitation. I'm just not sure this is related to Ismael's devices.
Oh and Altrez I saw that beer. No more microwave testing while drinking
Originally posted by ewizard View PostI'll suggest a possible half baked (no pun intended) explanation for the battery voltage increase in the microwave oven test. Since you have a huge amount of power that is exciting a wire at a high frequency and you are only connecting it to one side of the the battery I think we can assume that some electrons in the wire are acting to 'stir the pot' a bit in the battery. So you are adding a bit of energy to the battery. The battery may even act to some extent as it's own rectifier. Many small effects can be seen with very high power level excitation. I'm just not sure this is related to Ismael's devices.
Hahaha busted! I think you are close in your observations. Still in all the test made for an exciting Thursday evening
-Altrez
Aviso MEG.
Ismael has a new MEG video. He describes the ground scouring microwave charging effect demonstrated by Altrez as "Inductive Collapse".
YouTube - Ismael Aviso MEG test with 1000 Watts load
Microwave battery loop.
I saw a youtube video awhile back where an inventer had a group of 12 volt head lights looped back to a few 12 volt lead acid batteries through an inverter and a mystery component concealed in a cardboard box. I realize now it must have been a microwave oven. I tried to search for it, but I can't locate it right now. He was in a garage or warehouse with a witness and ran the unit over several hours. Does anyone remember seeing this one?
I don't know how safe or what the long term effects would be on a battery from running a microwave signal through it, or where you would tie into the oven; However this would be a very simple way to generate free power if it was safe and didn't burn the battery out.
I imagine the oven just plugs into the A.C. inverter, and wires into the negative poles of the lead acid batteries, with maybe a timer to space periodic bursts of energy out from the oven. I'll continue to search for the video.
Update:
I found the video I was thinking of by Peter Sumaruck, and there is no evidence of a microwave oven. This seems to me like a very very bad idea for anyone to try at this point without "Myth Buster" type safety precautions. Here's the link anyway.
YouTube - Zero AmpLast edited by synchro; 03-06-2011, 04:32 PM.
a bit oot...
i think now i get why the egyptian had only iraqi jars to have theor big lamps for their projects..
it's because they never used it to power the lamps up in the first place..they only used the jars to trigger the source the way possibly aviso using the batteries to power the car by triggering the ambient energy..
the question is, how to do that with radioshack components?
after reading this:
Directory:Ismael Aviso Self-Charging Electric Car - PESWiki
i kind of puzzled about the sentence:
"..It's not A FREE ENERGY Car, due to antenna collect power from AMBIENT like from Cellsite & other form of transmitting signal to boost the power of the battery.."
is it expensive to create such power compared to the power generated to run the car engine?
Ismael Aviso says, in a interview, Aviso Interviewed on Smart Scarecrow Showthat was inspired by Harry Bull’s “two weights propulsion, Harry W. Bull:Harry W. Bull: Reaction Motor (Popular Science Monthly, Jan. 1035) to develop a levitation device that he is claiming.
Probably Ismael is using a coil, replacing the “spring propels” to oscillate the weights back and forth.
David
“Simplicity is the ultimate sophistication” Leonardo da Vinci
I believe that the solution is simpler than everybody thinks.
Ismael seems a simple guy and I do not see him doing complicated electronics.
(He confessed that did not finished first year of high school)
I think, that he just switches a simple DC circuit, with a battery and a motor, 10.000 times a second, and then in parallel, adds a pulsing high frequency signal from the antenna.
David
