Particle Physics and the 2012 Scenario
  • Particle Physics and the 2012 Scenario
    The Universe, all encompassing as it is does not forewarn of
    immenent events in any traditional standard way. In order to
    know what may happen, a mind ought to be surrounded with enough
    practical knowledge to view something natural in a seemingly
    obscure way such as the ancient people of civilizations long
    since in recorded in history might have forewarning of an event
    in the near future.
    Nature has shown peculiar tendencies at even the most mundane
    of events taking place triggering a bewildering outcome. Reports in
    of unplugged appliances running when used in the correct way and
    spontaneous combustion. How we have placed our energy on the line with
    experiments absorbing enormous quantities of electrical charge to
    accellerate particles into collision at even greater scales than
    before fortells of a singular event in which there is no recovery.
    It would be of such magnitude as to effect a change in the natural
    timeframe of reality, visible only from the past within a certain window
    of observation as who knows what in the sky now sketched in books and
    sitting in museums.
    While our planet is being wiped clean of natural resources, most notably
    it seems in the region where the now-conquered ancients in question made
    their home, these particles are being thrown around in resolution for
    what relevent purpose as one may question. The pollutants of the ocean
    now viewed only as transparent to the eye, masked with chemical
    technology and left to circulate the globe will be priority while
    the goal of science remains a conquest to find invisible proof
    of the mathematical theory.
    Steorn has introduced the world to radiant energy; perhaps it will not
    be long before their product catalog will be available with a few more
    famous and historic devices in partnership with nations wishing to
    adapt and grow economically, releasing a bit of burden on Earth.
    2012 Scenario
    Soon, a body of monstrous proportions will shortly become visible in the direction of Cancer. It will not, however, emit any light as the light of a Sun only becomes intense when it enters into a secondary magnetic field such as our solar system. It begins to rotate on entering such a field. It deforms space around itself and generates currents which give rise to its brilliance. If it were luminous beforehand, its light would set up a force of repulsion, and it would be deflected from its path. With no luminosity it becomes subject to the pressure of our Sun, but its own momentum will ensure that it enters our system.
    It will first be seen as a reddish light, later turning to blue. After reaching the area of the large planetary bodies, it will encounter the repulsive force of the Sun, but in its rear it will then have the weight of large bodies, also imparting a force of repulsion to it in the opposite direction. The force of repulsion of the planets behind it, the light it gives off and its great mass will cause the present Sun to move further away from the magnetic centre of our system. Then the two Suns will settle down in their new orbits, the one of greater mass and lesser light being nearer the centre.
    Two Suns in the solar system will create difficult problems. The orbits of all the planets will be changed. Mercury will move into the area between the present orbits of Venus and the Earth. Venus will move out to a position between the present orbit of the Earth and Mars. The Earth will feel the effect before the new Sun settles down in its definitive orbit. As the luminosity of this body increases, the pressure of this light will cause the Moon to move out of its orbit, and it will settle in a position that will turn it into a planet. With this displacement it will take with it part of the etheric mass of the Earth, which will impart to it a stabilised movement. The Earth, in turn, under the pressure of the twin Suns, will move out into the area now occupied by the planetoids. In short, there will be a general displacement of all the bodies belonging to our system. Pluto will be ejected from the system, and will wander though space until it finds some new haven. (Amos 8:9), "And it shall come to pass in that day, saith the Lord God, that I will cause the sun to go down at noon and I will darken the Earth in the clear day".
    The entry of a new Sun into our system would throw the Earth out into an orbit between Mars and Jupiter now occupied by the planetoids. All the planetary orbits will be altered. There will be turmoil but this will be bearable as the repulsive force of the new Sun will speedily restore order. When the new Sun reaches it maximum luminosity the Earth will already be in its appointed place in the system. There will certainly be a change in the fauna, but life will continue, probably under better conditions than before. The entry of this new body into the system was predicted by Nostradamus in his famous Centuries, vol II, stanza 4r: "La grande estoile par sept jours bruslera Nuee fera deux soleils apparoir." (The great star will bum or seven days, and cloud will make two Suns appear.)
    One of the satellites of Mars will be torn from its present orbit and thrown into space. As it is a relatively dense body, it will be attracted towards the centre of the system rather than repelled outwards. Its trajectory will be such that it will become a satellite of the Earth. Everything depends on its direction of travel when it establishes contact with this planet. If this happens to be against the direction of rotation of the Earth, the shock produced by its contact with the etheric covering of the Earth will smash it to pieces. If it is with the rotation of the Earth, then the satellite will attach itself to the planet. The Earth itself will not be affected by this impact, as its etheric covering will protect it. According to the calculations, a shower of rocks is all that will reach the surface of the planet, principally in the area of Europe and North Africa, Asia Minor, the north of South America and the south of North America. The impact will turn this now splendid Martian satellite into fragments weighing about 50 lb. each, which will lay waste these areas. After that, everything will become normal again and we shall have a new sky in which to travel, and we will have a new Earth. (Isaiah 65:17), "Behold, I will create new heavens and a new earth. The former things will not be remembered, nor will they come to mind". (Revelation 21:1), "Then I saw a new heaven and a new earth, for the first heaven and the first earth had passed away, and there was no longer any sea".
    The Earth will begin its new millennium with a new source of light to illuminate it. Many people will vanish forever from the face of the Earth but a small community, obedient to the laws of God, will remain, and present suffering will cease. There will be peace and abundance, justice and compassion. The unjust souls will get the punishment they deserve, and the just will get their recompense. On this day, many will understand the triumph of the just and he will see why God did not immediately punish the wrongdoers. The Sun which is to come will be called the Sun of Justice. Its appearance in the heavens will be the warning signal of the coming of the One who will shine even more than the Sun itself. The UFO's (Watchers) are studying all the effects that its appearance will bring in its wake. If they are permitted, they could, with suitable apparatus, send electromagnetic pulses against it, and prevent its entry into our system by causing it to become incandescent outside our system. However, to prevent its arrival would be tantamount to opposing the will of God and allowing the injustice of the elitists here to continue indefinitely. Those with clear consciences and those at peace with their Creator need fear nothing. Let it come. If man were to reform himself, it is possible that the Creator would have compassion on him.
    GB
      Below is an illustration, showing the magnetic centre of the solar system, the earth, and the binary Suns. It also shows how the earth will be attracted to the magnetic centre, while being repelled by the binary Suns. If the magnetic centre lies between a planet and a Sun, the force of attraction is predominant and the planet is drawn in. However, if a Sun is between the planet and the centre, the force of repulsion predominates and the planet moves out, its path disturbed. The binary Suns will rotate around the magnetic centre, thus the axial rotation and the orbital revolution of the planets will move according to the two forces of repulsion and attraction acting on the heavenly bodies.
      GB
        Is it a joke the second Sun thing?
          Most solar systems have a binary Sun, and our solar system is no different. Here's a short video showing our binary solar system. This other Sun won't emit any light as the light of a Sun only becomes intense when it enters into a secondary magnetic field such as our solar system. Once it enters into this field, then it will deform space around itself and generate currents which will give rise to its brilliance.
          GB
            more material about this theory?
            Hi gravityblock,
            you describe an interesting scenario.
            Please, where does the image you posted in posting #3 of this thread
            http://www.energeticforum.com/renewa...tml#post132331
            come from?
              Originally posted by marxist View Post
              Hi gravityblock,
              come from?
              I sent you a PM regarding the image.
              GB
                GB
                Nasa discovers a new super giant, named Tyche, on the edge of our solar system, which is 4 times the size of Jupiter made of hydrogen and helium. Since Tyche isn't far from the secondary magnetic field of our solar system, then it should be lighting up soon. This is probably why NASA has released this information now, because they won't be able to hide it much longer.
                GB
                  [URL="http://www.youtube.com/watch?v=BJXVlc-XMso&feature=related"]This is probably why NASA has released this information now, because they won't be able to hide it much longer. GB
                  Just about a day after I thought your post was insane... you come up with this. Helium and Hydrogen planet. Huge one. Sure sounds like a sun to me. Not planet.
                    YouTube - Footage of TWO SUNS! Nibiru aka Planet X, Nemesis, Wormwood, Brown Dwarf, or Binary Star?
                    Or is it a Sun Dog, as they say?
                    (The video does not at all look like ANY pictures of Sun Dog's that i have personally seen)
