AC on the rotor field windings
  • AC on the rotor field windings
    Hey. No tecnical literature talk about ac on the field windings on ac
    generators and motors. has the capitalists something to hide here? the
    magnetism on the rotor will not be constant using ac. it will wary same
    as the sinus wave. it will induse the same normal sinus wave ac in the
    stator windings as the constant magnet dc powered rotors do. The
    benefits is this: the magnetic lock effekt will be wery redused,
    60-70%? also the back emf counter effect will be redused, 60-70%? it
    can be drawn more power from the stator windings because most of the
    thermic effect from the back emf voltage/current is redused. i will do
    tests on standard 2 pole gensets. when the rotor spins making 50 or 60
    hz, it flips north /south poles. the result is that the stators get
    constant north pole and the other stator gets constant south pole. i
    think that is ok, it will generate ac ok. The logics on this is wery
    simple, just do it right electrically and mechanichally. there is
    histories about self running generators and motors. a 4-pole can maybe
    runs as motor and generator, half by half. the same thing will go for
    motors to. they will be overunity machines. se the link, this guy
    runs a modified generator. YouTube - 3000 Watt Generator Powers Itself, Grinder & Drill Press.mp4
    Hi,
    I think, because the classical Opinion is, that, when you put Power on the other windings, you will have no gain, because the Power to overcome the Forces from the generated Field or the Field, what is build up to generate Power and the Resistance from the Load, what goes back into the Generator will not lesser then the Power what will be generated.
    And you still dont know, if this Motor is not set up like a Rotoverter, and its that why, it is more efficient as a normal Motor or if the Generator is modified.
    Something what me still bother at WITTS is, that they cry out load, that they have the Solutions for the World, but still wanna take a Fee, and not a small one, that you can get access to the Information. I have my Doubts on her Concept.
