If you are going to polish the Enhydro quartz, i recommend Egg shaped; and also don't throw away the left over pieces, the smaller ones could be used the break up water under high frequency.....
Yes the shards can be used to make HHO. Need EQ to be as round as possible.
How is the Sonofusion experiment with Enhydro quartz going
I still think that an egg shaped enhydro quartz has huge potential in sonofusion, (more so now than ever )it all depends on where you place the cavity in the egg
I have made a good bit of progress I now have a solid plan to slow down the fast moving neutrons with two layers of a certain type of metal long enough to generate electricity
The collector plates will be placed around my reaction chamber to harvest energy, well at least in theory
Changing atomic elements or making elements appear mysteriously? It sounds like impossible alchemy, but experimenters recently did this, without Big Science particle accelerators. These scientists learned from a metaphysician, Walter Russell (1871-1963). During vivid spiritual experiences, Russell had seen everything in the universe, from the atom to outer space, being formed by an invisible background geometry. Russell not only portrayed his visions in paintings, he also learned science. He was so far ahead that in 1926 he predicted tritium, deuterium, neptunium, plutonium and other elements.
Recently, professional engineers Ron Kovac and Toby Grotz of Colorado, with help from Dr. Tim Binder, repeated Russell's 1927 work, which was verified at the time by Westinghouse Laboratories. Russell found a novel way to change the ratio of hydrogen to oxygen in water vapor inside a sealed quartz tube, or to change the vapor to completely different elements. Their conclusion agrees with Russell: the geometry of motion in space is important in atomic transmutation. Kovac shorthands that idea to geometry of space-bending.
Elestial Quartz (also known as Skeletal Quartz) is the name given to various types of quartz all of which have formed with terminations or points covering every surface in a layered or etched pattern. This is the result of unstable conditions during the crystallization process. Within the crystal, plainly visible cavities in geometric patterns can sometimes contain clay minerals of varied colors.The cavities can even include carbon dioxide and water displaying both the liquid and gas phase of formation. This is visible even to an unaided eye with the appearance of a moving water bubble. This is known as an “enhydro”. The cavities within the quartz often have a layered or ribbed aspect seemingly hollow giving rise to the term “skeletal quartz”. Madagascar and Brazil is where most elestials can be found.
The youngest form of quartz on earth, it is unlike any other form of quartz. Flowing terminations (usually not sharp) have formed over the faces and body of the crystal, and are usually tabular, rectangular or square, with rounded corners. Markings on the surface can have the appearance of cryptic hieroglyphics, a cosmic alphabet of sorts.
“Signs and symbols rule the world, not words nor laws.” -Confucius.
