Leaked footage over Fukishima reactors Melted rods hurry before its taken down
  • Leaked footage over Fukishima reactors Melted rods hurry before its taken down
    Check out these very clear video of Reactors.Already removed by user! Sorry.
    Just thought some have not see the real damage.
    Very likely that this vid will not be up for too long. So i uploaded to Energetictube.com as well. Click here to watch it @ Energetictube.com.
    EnergeticTube.com - Where technology goes Live!
    ETaffairs.com - Your Portal Here on Earth
    Already removed by the user.
    Thanks anyway
    Vtech
    General D.Eisenhower
    http://www.nvtronics.org
      I backed it up at Energetictube.com
      My appologies for my mis-spelling Fukushima in the thread title. Actually i named this thread poorly. The term "melted" was one that was passed along by the original uploader. I shouldn't have used it because i can't claim to see melted rods. I do see a pile of rod like objects all over the place, could be spent rods that were stored in levels above the exploding reactor. Pure speculation by me. That is why i would like to know a bit more about what we are seeing in that video. Anyone with any knowledge of the inner working of such a plant would have better information. Please chime in if you can explain anything about what we are seeing.
      Thought there was a good chance that the vid my not be up at Youtube for long, so i backed it up at Energetictube.com.
      Here's a link to it at Energetictube.com
      Looking like containment isn't very likely any more.
      Not sure exactly how old this is but it only had 1 viewer when i saw it on youtube. Was refered there by uploader, and not sure how he got it.
        Thanks for the vid, ill analyze it and see if I recognise anything significant.
        Those in the helicopter are dead men even if they don’t know it yet.
        The radiation is here in the Philippines now. I can detect it but cannot make readings because it is a very simple device and too unstable in its output to calibrate. I measured 0.2uAmps and up to1.3uAmps across two steel plates potentialised at 12.v and 5 inch apart. Yesterday, there was only 0.2u amps at best and usually 0. I admit this is very crude and could be misleading but as a trend the results are up. Humidity is lower than yesterday
          Even mainstream media
          (NBC NEWS) admitted, last night, that "radiation" from Japan had hit the west coast of US.They then went on to say there was no risk, amount of radiation much less than an x-ray, etc.Without differenciating between radiation, which goes right thru you, as in an x-ray, and RADIOACTIVE FALLOUT, which you inhale, ingest, etc, and stays in your body for a long time, causing cell damage.And most people keep believing them.Even tho 4 days ago, they were saying "No way radiation from Japan could reach the US."
          Ahhh, well the experiment is coming to an end, only a matter of how long, till the experimenter decides to pull the plug.Jim
            We need to put this into perspective.
            We are talking about milisieverts and nanosievert and it does not sound much. When I worked at a nuclear facility, I believe the maximum yearly dose was one millisievert per year and a chest x-ray is 50 nanosievert. An old wristwatch would give a reading on a Geiger counter no less than a spec of plutonium some short distance away so why be worried?.
            The best explanation of this is given by Hirose Takashi. And he confirms what I have said. This is taken from an interview for counterpunch.
            Hirose Takashi: What They're Covering Up at Fukushima
            “Yo: Every day the local government is measuring the radioactivity. All the television stations are saying that while radiation is rising, it is still not high enough to be a danger to health. They compare it to a stomach x-ray, or if it goes up, to a CT scan. What is the truth of the matter?
            Hirose: For example, yesterday. Around Fukushima Daiichi Station they measured 400 millisieverts – that’s per hour. With this measurement (Chief Cabinet Secretary) Edano admitted for the first time that there was a danger to health, but he didn’t explain what this means. All of the information media are at fault here I think. They are saying stupid things like, why, we are exposed to radiation all the time in our daily life, we get radiation from outer space. But that’s one millisievert per year. A year has 365 days, a day has 24 hours; multiply 365 by 24, you get 8760. Multiply the 400 millisieverts by that, you get 3,500,000 the normal dose. You call that safe? And what media have reported this? None. They compare it to a CT scan, which is over in an instant; that has nothing to do with it. The reason radioactivity can be measured is that radioactive material is escaping. What is dangerous is when that material enters your body and irradiates it from inside. These industry-mouthpiece scholars come on TV and what to they say? They say as you move away the radiation is reduced in inverse ratio to the square of the distance. I want to say the reverse. Internal irradiation happens when radioactive material is ingested into the body. What happens? Say there is a nuclear particle one meter away from you. You breathe it in, it sticks inside your body; the distance between you and it is now at the micron level. One meter is 1000 millimeters, one micron is one thousandth of a millimeter. That’s a thousand times a thousand squared. That’s the real meaning of “inverse ratio of the square of the distance.” Radiation exposure is increased by a factor of a trillion. Inhaling even the tiniest particle, that’s the danger.”
            Taking background readings of radiation are misleading, it’s the intensity of the radioactive material you come into contact with and many of the particles are gasses.
              Mandaluyong is showing increased radiation levels.
                Recommend watching...
                I would highly recommend watching, "The Battle of Chernobyl". It has some very intimate documentation of the disaster and the heroic efforts to quell the radiation leak.
                The sad part is that you can never do anything with the melted down magma from the uranium fuel rods. In Chernobyl there is a very large mass of it that has a half life of 200 000+ years! This is literally a permanent fixture on this planet. Biological systems and even electronic mechanized robots can not function in this environment. What this means is that Chernobyl, and possibly Fukushima will forever serve as a grave symbol of humanity's inability to utilize technology. These places will not recover completely and life will never flourish there again. These are mistakes by the human race!
                Big freaking mistakes! These reactors should not be allowed to continue to be built! Anything is better that this. I would live with out an electrical infrastructure if it meant these plants could be shut down. These are FAR to unstable times to be running these insane devices.
                If we are not already successfully building and utilizing Low Energy Fission devices then we need to put a hold on what we "Think" we can do as a species with Nuclear energy.
                  Microseverts, Microrads, Rads
                  Reports are using the term microseverts. A microsevert is equal to 100 microrads The allowable average yearly dose per an adult human is 5 rads or 5,000,000 microrads (50,000 microseverts). Again, that is a yearly dose, a daily maximum average dose would be that divided by 365, or 13,690 microrads (137 microseverts) per day. If the reports say hourly dose, then divide by 24 and you get 570 microrads (5.7 microseverts) per hour.
                  VIDBID
                    Exactly what I was saying
                    mbrownn, its not the radiation, its the irradiated fallout.They are now saying there is radioactive iodine in the water supply, twice the safe dosage for children; there is no safe dosage of radioactive iodine.Its concentrated in the thyroid, as is any iodine which we ingest.
                    In addition to the very permanent monuments to stupidity and hubris of chernoble and now in Japan, there is the spent material.No country has yet developed a viable program with dealing with the waste.They are just piling it up; where?,.....in pools next to the power plants, cause they don't have anywhere else to store it.
                    Civilisation is a 13000 year old experiment.And it doesn't work.;-( Jim
                      I have just posted the video on conspiracy central file sharing site to try and make sure the video spreads.
                      http://concen.org/tracker/torrents-details.php?id=23306
                        They are admitting to in excess of 400 milisieverts per hour.
                          Wrong question
                          Nuclear power station only exits via government. No rational sensible educated human being would accept this as a safe form of power....
                          Oxymoron; your talking about the Gov't., and then talking about rational, sensible and educated.One of the main reasons for limited Gov't., is that due to greed, hubris, complacency, laziness and 'unintended/unforeseen consequences' in any human endeavor there will be screw ups; its human nature.
                          Gov't actions are so sweeping, and effect so many peoples lives, that LOTS of people can be adversely effected.For the same reasons, you want to restrict technology; Due to human nature, there will be screw-ups.
                          If a gas station, or a coal fire powerplant has an accident, some people will die, some may have to be evacuated, and there may be some negative environmental impact.Cherynoble and now Fukishima make it clear this technology exceeds our ability to manage it.
                          Actually, all this talk about 'alternative energy' and "solving" the energy problems is wasted effort.There is no solution, the way the problem is being framed; the problem is consumption.And no, I don't simply mean conservation, although people are on a consistent path towards greater and greater per capita consumption.
                          The problem is there are simply to many fu**ing people in the world, with thousands more being born every minute.And no one is addressing this, except the Chinese.Well, everyone says, yeah, the Chinese.India's population is actually growing faster than China, and will surpass them within 20-30 years.This is the elephant in the room, that no one is talking about.Reduce our population by 1/2, say, and all of our resource problems are greatly reduced, or eliminated.Don't address population growth, and any attempts to address resource problems; Food, Energy, employment/economics are quite simply insoluble.Gonna have about as much effect as p*ssing in the ocean.Jim
                          • #14
                            Even consumption can curved by a simple modification to the AC grid system. I don't know how to do it myself, all we need to do is collect and reimpose the the power on the neutral lines. Which eventually go to ground anyway.
                            We have been measuring the neutral line coming out of the shop. The power is of course at a different scale but watt for watt 80 percent of it is still present on the wire. But then gets dumped to ground.
                            So the right mind could make this happen, through a low voltage potential, collecting that energy then an apparatus to step it back up to grid power levels. At minimum this would yield a 50% drop in consumption and could be incorporated into all transformers. If someone had a good mind to do it.
                            Population control is not an option. Unfortunately!
                            Matt
                            • #15
                              Great, matt
                              Assuming what your saying about the neutral line, etc, could be made to work, you would just be feeding the beast.
                              Working out, on your own, small scale operations, like turning waste plastic into fuel, or the friction boiler, so individuals can adopt "Living off grid" as a metaphor, and a phylosophy, and a way to prepare for whats coming, yes.
                              Alternative energy to 'feed the beast', and prolongue the machine for a few more years; NO! When I say off the grid as a metaphor; the most accepted path to off the grid is first develop a small system, that can be used as a backup, in case of disruption. Then build on that, so that the grid becomes your backup, and eventually becomes irrelevent.
                              We all live at the end of very long, tenuous supply lines, or grids.We have become totally dependent on them for our 'necessities', and have greatly increased the list of what we think of as necessities. Originally Food, Potable water and shelter from the elements was the list.We now have Medical care/insurance, Public safety (911, Fire, Police, ambulance, ER and hospitals)
                              Energy in various forms (Electric grid, Transportation fuel, etc) Employment,Financial services, communication and information, and the list goes on.All of these necessities come to us through supply lines. If you use "Off the grid" as a metaphor, or pattern, you CAN do the same thing; initially, develop a 'backup' system, then, build on that knowledge to develop a system independent of the 'grid', and simply have the grid as a backup.
                              This is the only sensible coarse I see, for any thinking individual.Catrina showed us what happens when you call 911, and no one answers.Gas shortages, well we got lots of examples of that.Financial crises we see collapse of 'employment grid', and whole housing/mortgage financial services grid.And the list goes on.Anyone who feels any confidence in the existing Grid structures is burying their head in the sand.
                              Anyway, thats what I am doing; gradually working to divorce myself from as many of these grids as I can. I see no other coarse.Jim
