Bashar Free Energy Space-Time Antenna Replication
  • Not channeling... wide band....
    I'm not channeling ... at least I don't think I am... :-)
    I'm more of a wide-band guy.
    But here are some thoughts regarding a possible theory of operations.
    Search for LOOP antenna. One interesting thing about them is they
    respond MOSTLY to the magnetic component of an electro-magnetic
    wave. Further, I have read that to make one, you want a pretty
    THICK wire, or THICK "copper tube", because people have tried
    various thicknesses and have found that around 14AWG or thicker,
    you start to get a GAIN that is the best and flattens out beyond that.
    As for Bashar's "in a sense .. capacitor ... transformer" comment,
    I was thinking that transformers, unlike just a coil, are doing the job
    of stepping up or down voltage (and current in the inverse direction
    of voltage).
    What if, and this relates to my speculation about the Hubbard Coil...
    What if you could translate from HIGH-FREQUENCY to
    LOWER-FREQUENCIES using a trick of geometry.
    When studying transformers, it is true that the turn ratio of the
    two interfacing coils is what you are mainly concerned with,
    since most people will build transfomers with a "shared" geometry.
    In other words both coils are would around the same AREA.
    But, another degree of freedom you have which affects the
    magnetic field is AREA. Two coils can be construction for
    different areas. The both could have the same number of turns,
    but the math predicts you still can get a voltage transforming
    affect simply by changing the area each coil sees. For example,
    one coil is lower in the cone than the other coil.
    The other thought is that unlike RADIO, we really don't want
    to be tuning for a single frequencies. We want to be wide-band
    and BLEND all the frequencies of our device into a grand
    symphony of power. So if we had several LOOPs ... and could
    mix those frequencies into a UNIFIED oscillation, we could
    heterodyne the waves.
    The paper I found shows PROOF that there are TWO peaks,
    in terms of GAIN, that you can achieve the best results.
    One peak is a power-of-two RATIO of your frequencies.
    This peak is a "negative" peak.
    The other peak is the PHI ratio of frequencies.
    Take a look at the Hubbard coil... boom... Phi Ratios.
    So sacred geometry here would dictate that every construction
    detail we consider that involves geometry should be looked at
    to see if PHI ratios can play a role.
    Tesla was explaining that not only do you care about the diameter
    and length of your coil, but also you need to care about
    the length of the wire itself -- in terms of the frequency.
    So hence the geometry decisions can be the "macro" ones,
    the big stuff your building, and also the "micro" ones, how
    close things are (affecting capacitance), wiring crossing,
    materials used, frequencies involved, etc.
    So back to the CONE idea.
    Let us suppose that the physics we are interested in here are
    not just "resonance", but also heterodyne,
    LINEAR response curve for your inductors up as HIGH frequency
    as possible.
    It occurs to me, from looking at Hendershot's work, that basket
    weave coils and honeycomb coils afford coils that are
    very NICE in terms of having minimal capacitance. Hence,
    their response curve is off-the-charts. This IS what you want
    for wide-band. Yet, we see this "resonator" thing that looks
    like a capacitor -- and was reported to "be damaged by arc discharge".
    So, it stands to reason that this is the "escape path" for the energy
    in the oscillations. It is a "nearby" capacitance that is LARGER
    than anything the coil has inside itself. AC currents can flow
    to large capacitance surface EASILY. Be sure, as Tesla warned,
    that you don't have SHARP pointed surfaces, unless you do want
    ARCing. Tesla was all about getting RID of ARCing, because he reasoned
    it was a waste of power. Rather, we want a nice oscillation with
    "safe" nondestructive movement of power from coil to capacitor
    and back again -- TANK CIRCUIT.
    This argues that the Bashar Coil should have capacitance ... but NOT
    in the coil itself ... but rather NEAR the coil. By NEAR, I mean pretty
    darn close to the wires. To far away, and the capacitance is not
    providing the path-of-least resistance out.
    I believe it is true that the coil will oscillate in various ways.
    There can be the oscillation associated with the diameter of the LOOP.
    There can be the oscillation depending upon the "width" of the coil.
    There can be the oscillation depending upon the length of wire.
    If each of these were brought into PHI ratios of each other, intentionally,
    the results might be better due to this heterodyne idea.
    As far as the interface from coil to capacitor is concerned, it can be
    "wireless". In other words, you want them NEAR .. but they have
    no physical connection -- just a proximity connection.
    So you just need this resonant cavity so to speak -- for Ghz frequencies.
    It occurs to me that the wire-length (which will influence the number of
    turns), can be selected such that the frequencies are much lower, but
    a RATIO to the power of N down from the Ghz frequency.
    For example, by dividing by PHI^18 or PHI^19 or PHI^20,
    for example, you could get a much lower frequency to tell you
    how many TURNS you need in your LOOP bundle of wires.
    Again, though, this LOOP of wires you do not want to wrap in the
    conventional solenoid way ... because capacitance is too high.
    You want to select honeycomb or basket weave, or some other
    winding style that is minimal capacitance.
    So a plan is forming in my head for how to construct a cone shaped,
    multi-LOOP antenna, out of coils wound in the honeycomb style,
    each loop being a PHI ratio of the one above AND below.
    This incorporates ideas from the Hendershot device, the Hubbard PHI
    ratio coil, Lenz's Law, magnetic resonance, heterodyne,
    etc.
    In other words, one way to think outside the box is actually to
    instead be thinking in terms of all the physical properties and
    constraining rules of physics, and exploiting them to your advantage.
    Unlike 1927, 1928, we have the web, we have great computers,
    we have amazing materials, we have some brilliant people.
    Reception of "ambient" power should absolutely be doable within
    this decade -- if not already being released this year.
    • Cone Shaped PHI Coil Project
      Here is a photo of the "Cone Shaped PHI Coil" I'm working on.
      It took me about 4 hours of work so far to make this thing.
      I'm using poster material for the cone former -- cut to 102 degrees.
      The length from Apex to base is about 16 in, big enough to
      hold the Hydrogen Line diameter on the cone.
      Various "PEGS" are hot-glued at the PHI ratio diameters, the lowest
      one being the Hydrogen Line.
      Various PEG diameters are used:
      a) Pencil (7mm)
      b) dowel 3/8 inch
      c) tooth picks .0984 inch
      I selected 7 rows arbitrarily -- 7 representing "Heaven".
      The smaller rows are too small for me to deal with.
      I might instead put a cap-stone here -- a little metalic
      conic shape like a jigger or something.
      The PEGS are hot glued only on the bottom, providing a slot
      for the wire to enter from the top. This affords a way to
      wind the coil in the basket weave fashion (ala Hendershot),
      with the coil "eddy current" spirals parallel to the side of the cone.
      Under the cone is a hand-made capacitor, 2 plates of household foil.
      The capacitance is too small ... below the level of my meter.
      I'll do the math later, but its probably in the pico farads.
      PHI was used in many of the mathematical decisions here:
      1. The 33 apex angle per Bashar -- very close to PHI
      2. Each coil is a phi ratio diameter from each other on the
      former. I selected 7 diameters.
      3. Phi is used for the number of pegs at each level based on
      diameter of PEG to give PYRAMID angle for wire crossing.
      An ARTIST could do a much better job than me.
      It looks organic...
      • Hydrogen Line Coil Wound
        Progress Report:
        I've wrapped the bottom coil. I selected 20AWG magnetic wire.
        This turned out to be a bit tricky because some of the pencils would
        pop off the former and I would have to hot glue them again.
        This only occurred for the first few winds. Once the structure was
        established, it was easier to gently place the wire where it belongs.
        20AWG is nice because it is low resistance, but the wire is pretty
        thick and ridged for such a delicate former.
        I was shooting for a lower frequency for self-resonance, but the scope
        revealed otherwise. I suspect that the capacitor I made in the coil
        has having an ODD effect in that inductance is linear, but
        the self capacitance has really DROPPED. I estimate the self
        capacitance may be approx 24pf -- an amazing value.
        This is sort of a crude extrapolate guess based on the math.
        So I wonder if the reactance (due to capacitance) values are subtracted.
        Something kinda complex is happening in that the capacitance
        in the coil is likely from the wire crossing and yet there is another
        direction for capacitance on the side inside the cone.
        If you think of them as springs that push back after you push them,
        the coil experiences two of these sorts of pushes, but that have a
        different PHASE because of where they occur on the wire.
        As such, if you sum their vectors, this could be reducing capacitance.
        I'm just guessing really based on my vague understanding
        of phase and reactance.
        I wanted a self-resonant frequency that was a power-of-PHI
        multiple of the hydrogen line. Since the coil was approx. 1.04Mhz,
        when 27 loops was touched, this is the loop I'm tuning for.
        I thus have made this coil PHI^15 lower in frequency than
        the hydrogen line.
        Each of the next coils will be calibrated to these ratios -- and I will
        wind them many more than 27, and then TAP until I find the frequency
        I need. That is the plan.
        Another thing to report.
        I put scope probes on the coil and connect my house-plumbing GROUND
        to one lead of the inner-cone capacitor.
        After doing so, the scope is showing wonderful oscillations
        that are approx 100mV peak to peak. This is very cool.
        I've never been able to get that much from my GROUND.
        So I am encouraged by this choice of frequencies.
        I have to be careful not be be too excited though since
        this frequency IS within the AM radio band and there can
        be radio stations near me helping.
        • More thoughts on this PHI coil approach...
          I have some more thoughts to pass along for those who
          are interested in this thread and this experiment...
          A van de graaff generator is a machine that can produce huge
          electro static voltages.
          It occurs to me that in this PHI Coil on a Cone experiment, if the
          inner capacitor is NOT grounded, and if the capacitor works,
          then charges can built up on the surface because of the
          self-resonating coils that are nearby stirring things up.
          The van de graaff generator might use a belt of silk running over
          metal pullys and deposit one of the charges on a large metal sphere.
          You need LARGE spheres to create a modest capacitance.
          But I've learned that coils around diamagnetic pipes, such as
          copper pipes, can do the same thing, and leave a HUGE charge
          on the pipe that stays there LONG after the coil has been turned off.
          You can touch the pipe minutes later and get a really bad shock ...
          just like a van de graaff generator.
          So having the capacitor IN the cone, near the coils, is a recipe
          for building charges. Unlike the van de graaf generator, the
          charges have an escape path back INTO the coil. Paper is used
          as the dielectric here, and if the voltages are not too high,
          there should be no BURNs in the paper. Since I anticipate this
          coil will give a modest amount of power, everything should be fine.
          Some other thoughts that have occurred to me related to scaling
          this design. You can start with the dimensions I am attempting
          with a coil former that has a 120 degree wedge, cut from a circle
          that has a 16 inch radius. The cone here stands about a little
          over 16 inches tall.
          Later, it is always possible to create more PHI ratio frequency
          coils LOWER in frequency be creating an even large cone,
          wire that lower coil, and then place the smaller CONE over the bigger cone.
          Hence, this design has a very convenient way to SCALE if you want to.
          If there are promising results here ... the next idea would be
          to turn this back into a Bashar coil with TWO cones that
          interpenetrate.
          • Some Data for 7 Loop Cools on PHI Antenna
            Assuming 7 loop basket-weave coils, each a phi ratio of each other.
            loop 7 (HL): d= 8.31 in, h=14.03 in, s=14.63, f=1.420 Ghz,
            f(diameter)=1.349 Ghz f(coil) = 1041352.688 Hz
            loop 6 ----: d= 5.14 in, h= 8.67 in, s= 9.04, f=2.298 Ghz,
            f(diameter)=2.183 Ghz f(coil) = 1684944.125 Hz
            loop 5 ----: d= 3.17 in, h= 5.36 in, s= 5.59, f=3.719 Ghz,
            f(diameter)=3.533 Ghz f(coil) = 2726296.750 Hz
            loop 4 ----: d= 1.96 in, h= 3.31 in, s= 3.45, f=6.017 Ghz,
            f(diameter)=5.716 Ghz f(coil) = 4411241.000 Hz
            loop 3 ----: d= 1.21 in, h= 2.05 in, s= 2.13, f=9.736 Ghz,
            f(diameter)=9.249 Ghz f(coil) = 7137537.500 Hz
            loop 2 ----: d= 0.75 in, h= 1.26 in, s= 1.32, f=15.753 Ghz,
            f(diameter)=14.965 Ghz f(coil) = 11548779.000 Hz
            loop 1 ----: d= 0.46 in, h= 0.78 in, s= 0.82, f=25.488 Ghz,
            f(diameter)=24.214 Ghz f(coil) = 18686316.000 Hz
            The details of how many turns of what gauge wire will be worked
            out as I go, shooting for these f(coil) frequencies @ each loop,
            matching this expression:
            f(coil) = f(diameter) / (PHI^15)
            Hence, the energy in this Ghz range, hitting the tank circuit
            of that loop will provide some energy that will help
            in the self-resonant oscillation at the lower f(coil) frequency.
            This provides a simple "passive" way to translate power
            from higher frequencies to lower frequencies.
            Each coil will also have a transfromer effect to its neighbor,
            boosting voltage as the area increases.
            Further, the inner capacitor of the cone interfaces with the
            winds of each coil providing a "strange" alteration of the
            resonant frequency (pushing it higher then an AIR coil).
            • Hello, I have recently taken interest in this. Coil geometry is going to be a huge importance to understand ourselves. I dont think Bashar, being a highly evolved being is going to tell us. Its obvious we need to figure it out ourselves. That is the TRUE test. Hermetics involved similar ideas. WE together need to figure out how to surpass our limits of space and time, then we can be like bashar. Untill then I will be working on a replication. Looks very interesting and reminds me of the geometry in a rodin coil. It also goes along with how these 2 parts to electricity are helical structures spiraling into eachother. To me it looks like the structure of a magnet. Id bet phi fractals will help. Resonating in harmonious vibration from the cosmos leads me to believe hooking it up to a good antenna would be sweet. Have a look at this video of a crystal radio with a uranium doped crystal detector.
              Antenna experiment. Flying my kite with wire. - YouTube
              The current limits to crystal radios are the coils and how we tune them to select a frequency. The idea is to tune them to harmoniously vibrate with what is around. so instead of selecting certain frequencies, we could instill multiple frequencies and mix them. harmonics will come by themselves. This coil looks like it will be very harmonious and is a good key to understanding how the geometry works. Take care all, and @ morpher44...I really enjoy your comments and persistence. I think getting down with earth and tapping into our spiritual side may guide you to high planes of understand where someone like bashar might exist. then you could ask him yourself haha. I will be posting my replication soon enough, keep up the good work!
              Warren
              • Bashar Cone Former
                Warren
                I'm curious how you are going to do the cone shaped former.
                Some people have tried to make tower structure from long dowels,
                and then wound around the tower structure. I just used poster board
                and made a cone that was flimsy. I stuff it full of cloth to make it
                more ridged while winding, then removed the cloth.
                There is also the copper PIPE in a spiral approach.
                Also, if you watch one of the Bashar videos when he describes the spiral,
                he starts from the base and does a CCW spiral to the apex, and
                then connects to the down-going cone base, and does that same
                CCW motion down to its apex. MEANING, that the spirals are
                spinning in the SAME direction to augment each other rather
                than to FIGHT each other. That choice is probably important.
                I thought it didn't matter when I made my big coil, but after
                thinking about this a little harder, I think it does probably matter.
                You want the vortex fields to be spinning so that both coils
                benefit.
                If you use a poster-board former, the math need to impose
                a PHI spiral onto a 102 degree WEDGE shaped former before
                it is made into a cone would be a bit tricky. This is an interesting
                computer graphics problem -- or math problem. It occurred to
                me that one way of winding would be to follow that spiral
                exactly. You might even be able to tape the wire down in loop
                segments that you then have to solder together when bringing
                the two sides together into the cone shape. This would be
                tricky, but an interesting experiment as well.
                • internal ramp theory
                  OMG. I had watched this video about one month ago and was
                  impressed.
                  https://www.youtube.com/watch?v=YTgxGJfXRQ0
                  Today I just noticed it again and was STRUCK by how similar
                  the internal ramp idea is to the coil I'm building. The internal ramp
                  spiral up the pyramid looks like it maintaining the PHI ratio.
                  I bet you it is. If this is so, the ramp could house wiring and do
                  the same exact thing that I'm trying to replicate. I.e. the notion
                  of heterodyning PHI frequency for largest possible gain -- done
                  "passively".
                  Synchronicity?
                  • Morpher44
                    I just happened to glance at this thread. Yes, you are right, both coils turn together, not bucking one another. If you are standing on the North Pole looking down, the natural flow is CCW.
                    If you are at the South Pole looking down, the natural flow is CW. It seems opposite, but is not. If you were on the moon looking at earth, both vortexes turning together, same direction.
                    Place your coils with CCW on top if you are in Northern hemisphere. Maybe with axis in alignment with declination of magnetic lines of force according your latitude? Or, have setup on gimbals to rotate axis to magnetic lines of force?
                    Hope this helps?
                    tishatang
                    • If you were in the southern part of the world, and flushed a toilet, the water goes down in an opposite direction. This is NOT an illusion, as the vortex energy of the planet is what makes that happen, in an opposite direction.
                      What if, the two coils don't have to "buck".
                      If we are to tap this planet's vortex as an energy source we need to understand it, and to work with it, as was mentioned by Tesla and others.
                      I don't recall him ever mentioning anything about "bucking coils". Yes, No?
                      If you spin a gyroscope very fast it would never get off the ground, but if you were to spin two gyros in opposite directions, together they may overcome Earth's gravity. But, a mechanical device may not be able to spin fast enough to do this.
                      Why is it that most UFOs seen are round, oval or saucer shaped? Could this be a clue...
                      The moon does not rotate. Which makes some of us wonder if our moon is not something other than a normal moon, possibly an artificial moon of sorts, brought here for a special purpose, long ago.
                      We'll find out more about our moon soon, as there are bases, mining, and and space crafts seen flying and landing on it. As possibly even air to breath. And the NASA is not letting us know anything about it, only that they have not been back in 40 years. Right!?!
                      Nick_Z
                      • Actually the moon does rotate, exactly once every month. It all depends on perspective. From earth, it does not seem to rotate. If you were on Mars, you would see it slowly rotate as it goes around the earth. You would see all of the moon once a month.
                        NASA is a big censorship disinfo puppet. We have a giant planet bigger than Jupiter orbiting our sun the last ten years. Link here:
                        "PLANET EARTH - HOUSE OF THE RISING SUNS" - PART 5 OF 5 - HD SWEET! - YouTube
                        They have since erased this planet if you download the dates shown in this video. But, it is real, I checked the NASA site when this video came out. When I went back later, it was whitewashed away.
                        Comets are not dirty little snowballs. One, twice the size of Jupiter went flying through our solar system about ten years ago? See lecture Nassim Haramein.
                        (PART 1) Nassim Haramein at the Rogue Valley Metaphysical Library. 2003. (4 HRS) - YouTube
                        I had a small clip of this in his long lecture. But, it is not on my channel anymore. YT took it off my channel???? Censorship abounds in this world of lies and disinfo. Change is coming soon.
                        • Wizard Hat Coil - Phi Coil Data to share
                          This coil I'm working on that uses the PHI ratios in a very fractal way
                          all around the design, I've decided I'm going to call the
                          "Wizard Hat Coil". It looks like a Wizard Hat, with strange PHI
                          ratio separated basket weave coils on it.
                          I have some data to share.
                          I wound LOOP 7, the Hydrogen Line diameter, and determined the 27
                          winds was the correct number to tune exactly the lower frequency
                          derived using
                          f(low) = Hydrogen Line Freq / (PHI^15)
                          Today I got a bit of time and wound LOOP 6. I realized to tune this coil,
                          the LOOP 7 coil can either be shorted or unshorted, since it is likely
                          to have a mutual-inductive response to the LOOP6 coil.
                          See attached. As predicted, the shorted and un-shorted measurements
                          are different. They cross and cross again above and below the 27th
                          winding. I'm not sure if I should use 27 winds though, because
                          I want this coil to actually be self-resonant at 1.684944Mhz.
                          I need to think about this and decide which winding number is right --
                          i.e. 27 or a bit more to go to 1.684944Mhz. Opinions?
                          This is getting interesting.
                          I realized that my pulse generator only goes as high as 2Mhz,
                          and my next coil up is to be 2.73Mhz. Hence, LOOP6 was the last
                          one I can calibrate using this signal generator technique.
                          My scope can go up to 60Mhz. It may be possible for me to
                          pulse one of the lower coils in the cone at each frequency and
                          then see on the scope which winding gives the highest voltage.
                          If that doesn't work, tuning the other loops may be a challenge.
                          • 27 windings...
                            I've decided to solder at 27 windings for both LOOP7 coil and LOOP6
                            coil.
                            Tonight I tried various things and I've found a hook-up situation
                            that is now yielding greater than 200mVAC peak-to-peak
                            on my scope with an Earth Ground connection to one side
                            of the hand-made inner capacitor of the cone.
                            Btw, I did manage to measure that capacitance and it was reading
                            about 5.5nF. My meter was just haywire the other day.
                            That measurement sounds pretty good and is near the 7.8nF
                            of Hendershot's handmade cap. His cap was much more foil --
                            more surface area. People have attempt to make his capacitor
                            and measured up in the 20 nano-farad range...
                            The circuit is simple. One plate is connected to Earth Ground.
                            Other plate left floating.
                            LOOP7 bottom lead connected to ground of scope probe.
                            LOOP7 upper is wired to bottom of LOOP6.
                            LOOP6 coil upper is wired to scope probe.
                            Hence LOOP7 and LOOP6 are connected in series.
                            Remember that these two each self resonate at a PHI ratio
                            from each other -- per the windings and location on the coil which
                            has a PHI ratio AREA for the circle.
                            Further, they have a mutual-induction relationship that is
                            transformer in nature. Lastly they share a hidden capacitor
                            in the Wizard hat, being brushed gently by the Lenz's Law
                            oscillating magnetic fields.
                            On my scope I see the "unpowered" oscillation "passively"
                            heterodyning like I hoped, with a BOOSTED gain in the peek-to-peek
                            voltage. 200mVolts is a pretty decent voltage. Possibly enough
                            to move a magnet .. per the Hendershot Fuelless Generator.
                            For moving a magnet, the current is the important consideration.
                            If you could wind a coil with at say 5 ohms, but many many
                            turns, then you could send 40mA peak-to-peek to the coil
                            from this Wizard hat.
                            The Wizard hat may do better if it had line-of-site to the sky
                            and wasn't in my house.
                            More studying and experiments to perform, but I wanted to pass
                            along these results, which is just 2 coils on the Wizard hat former.
                            • moon does rotate.
                              Nick_Z
                              Does the Moon Rotate?
                              • response to Tishatang
                                Originally posted by Tishatang View Post
                                Morpher44
                                Hope this helps?
                                tishatang
                                Tishatang,
                                Yes this does help. Thanks.
                                I was thinking I should figure that vector out exactly in my
                                "lab/bathroom", and hang a little vector model from a string
                                and orient it to help me remember the exact declination, etc.
                                I wonder if its possible to get one of those compasses in a sphere
                                they make for automobiles and observe which way it TIPs.
                                This helps: Earth's Magnetic Field Calculators - Instructions | ngdc.noaa.gov
