I've got something that is very unique when it comes to your simple galvanic battery. I'm calling it the Glue Battery because it replaces the water in your normal water battery. The glue is the median instead of water.
I got the idea from messing with Bedini Earth cells/cement cells; I wanted a cell that was just alike the cement cell but dries faster. So I used Elmer's glue and even all purpose caulk. To my surprise after the cell dried it still produced power! I found this quite interesting because to my understanding when glues dries all the water is removed, so why does this cell work?
Also since its glue it will hold the plate together which could slow down the galvanic reaction. Also the Glue protects the exposed plate to oxygen in the air, so this could also slow down the galvanic reaction too, and we could just be reading the potential of the plates.
here's a video of the cells and how I made them
YouTube - Glue Battery
Using bigger plates will give better amps, using wire doesn't give the best amps.
I'm thinking maybe I should add some metal flakes or something to the glue to make it more conductive since the water is being removed.
To make the cells is very simple. Take one Copper wire and one aluminum wire and place both in glue and let sit to dry.
If you a glue thats not Elmer's or all purpose caulk let me know your results.
![Smile](http://www.energeticforum.com/core/images/smilies/smile.png)
