I just had a thought.
Is there any reason I should not connect the negative of the primary to the negative of the secondary and ground ? Because if I do that I think I would be pumping a lot of energy into the ground.
I am collecting the collapsing field to charge another battery, but if I disconnect it the protection neon fire's, I think if I connect a ground there it will stop the neon fireing but that seems like a waste. Or is that part of the effect ?
Do I need to get higher voltage Mosfets so they can take the field collapse without a recovery battery or ground connection there ?
The charging of the second battery is very good with particular setup, but that is not the goal.
It seems wrong to collect the collapsing field with this.
Any thoughts
Any thoughts
