Thanks 7, i'll check that out. Did you see above I got this waveform when I joined up the wave ?
http://v4j0ja.bay.livefilestore.com/...008.JPG?psid=1
I just got an LED to light at 10 meters with only a ground wire to the normal ground connection and outdoors amongst the trees. There is a lot of stuff to interfere with it and in the sunlight I couldn't get close enough to the light to film it well, as I got really close I think I became the dominant capacitance. I am convinced that to transfer using a ground connection with low power low frequency should also be used. I read somewhere that between 6 Hz and 20 Khz is best.
Tesla says that to get the most power from the transmitter and best transfer resonance is needed, but it will work without being in resonance. The principal of the transfer itself does not rely on resonance to actually work it is just much better.
I have a variable capacitor.
With this particular setup I think this is as close to resonance as I will get, when I join the wave the amplitude became a lot more and the wave form is Phase locked and i believe in resonance of some kind.
High frequency through the ground is not as good as low frequency apparently. I see this as true because when I first built it and was using it at only 2.5 Khz an actual ground connection worked but as I kept increasing the frequency the ground became less usefull. It will not be possible to build a small device to be in resonance at only 2o Khz or below so any actual ground/air transfers will have to be done out of resonance but at maximum possible power at lowest possible frequency, lower frequency will also alleviate some EM radiation that is wasting power.
Most of the exciter one wire transmission video's I see are only showing the HV live wire lighting by AV plug or by EM radiation, and done indoors amonst electrical equipment, which is not really very telling. I think I used induction to transfer the energy.
I issue a challenge to anybody to show one ground wire Energy transfer, outdoors over ten meters using less than 4 watts of input power to the transmitter.
I'll upload the video soon. The LED light is dull but it is on.
Next is to try to use the ground and then to light a CFL at ten meters. It'll take a while to get two good earth stakes in where i want them.
